Old 12-08-2018, 03:25 PM   #31
Damotm
Default Re: Engine Oil Spec for Longevity?
Hpr5 gives me tappet noises on start up, whereas nulon 5w30 runs sweetly
Sent from my G3125 using Tapatalk
Damotm is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2018, 05:00 PM   #32
383hq
I wouldn't over think it.
An engineer would tell you 15W/XX (anything) is good until -20 deg C.
Thats MINUS 20 degrees....
I'm not saying thinner is not better, I'm simply saying that anywhere in Australia you'll be fine.
If you don't live at Threadbo or in Tasmania in winter, you can even use a 20WXX although even then I'd doubt it gets below -10.
383hq is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2018, 05:01 PM   #33
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Embodiment of the AFF spirit in his efforts with ACP.
Hi Damotm, welcome to AFF! Can i ask what engine/vehicle are you referring to & is that 5w30 the standard factory recommended oil grade?
cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792
Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007)
Maka is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2018, 05:18 PM   #34
roKWiz
Cabover nut
roKWiz's Avatar
3 of my little Ford Traders run Penrite Diesel 15W40 mineral here at the foot of the Vic alps throughout winter and Penrite Diesel +10 20W60 mineral in summer.
In the hotter temps the oil tends to thin out under heavy loading particularly driving at hwy speeds.
While the XF runs 15W40 year round.
Old 12-08-2018, 05:39 PM   #35
Damotm
cheers, Maka
Hi Maka, yes its an 07 BF 4 Litre petrol. Cheers
Old 21-06-2020, 11:14 AM   #36
Bigredbf
Originally Posted by ebv8 View Post
just don't wait till 15000km to change your oil, doing so will make sure your engine lasts untill the warranty runs out and not much more, halve it and do it at 7500km or 12 months max.
oil is cheap these days and buy a 10 pack of filters on ebay and oil changes are cheap insurance
i have a 2008 e-gas and the book says 15w-40 which i find strange as its the same engine as yours and it takes 5w-30.
you might find in the book it recommends 7500km oil changes if you do highway, traffic, towing, high speed, low speed, stop start, continuous driving, and so-on...basically tells you to do it at 7500kms
I think egas run hotter then petrol
Bigredbf is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2023, 12:41 PM   #37
NCII40
XR6T BA 2002
NCII40's Avatar
Check oil manufactures data sheets
You want a good CCS value to protect at cold starts
Just for a example only
HPR5 is @6400,
vs
Castrol edge 5w @6030
Cold Crank Viscosity
Low temperature viscosity
(mPa∙s) Max (CCS)
0W
6200 @ -35
5W
6600 @ -30
10W
7000 @ -25
15W
7000 @ -20
20W
9500 @ -15
25W
13000 @ -10
XR6T 2002 BA
NCII40 is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2023, 12:32 AM   #38
Late braker
2008 BF XR6 N/A 199,000km. My mechanic uses 10w40. Has some minor leaks- rear main seal, valve cover and burns a little bit of oil every few thousand kms. I just keep an eye on things and top up as necessary with 10w40. Service every 15,000km as per the book.
Late braker is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2023, 02:01 AM   #39
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Omnicraft fully synthetic 5W30 in all our Euros, but we do services every 10,000km instead of the 15,000km interval.
Caprice takes Nulon 25W60 high zinc mineral cause flat tappet hydraulic camshaft, car gets oil changes when I can be bothered because its done 17,000km in 6 years.
I had fully synthetic 15W50 in it initially and it got super liftery on the dyno once, so I went up to 25W60 and no dramas ever since.
Old 06-03-2023, 09:18 AM   #40
roKWiz
Cabover nut
roKWiz's Avatar
and I though 20W60 was a heavy grade.
Thread Tools
Display Modes
