11-03-2005, 11:23 PM | #1 | ||
aka MotherNatures son
hey guys i went and took sum piccys of the esky today. its really dirty!!!!
can everyone give me some pointers on what i should to to fix her up to summernats standards.... thanks on the pic with the speedo under the needle is a 03798...... thats how many ks it done with the rebuilt motor . mum said theres enough spiderwebs in the engine to be scared really scared
1988 EA-EB Ford Falcon, The project EA body with EB engine, 4 speed auto, turbo blade rims, soon to have turbo or supercharger. :togo: 2001 Ford Falcon AU II Futura, The everyday banger, stock as it come from the factory, soon to change. :evil3: |
11-03-2005, 11:35 PM | #2 | ||
Well the boy has some work to do ..... ive only seen the piccys ...... but it doesnt look too bad considering the time its sat for ....
11-03-2005, 11:38 PM | #3 | ||
hibernating
my tip: start washing
11-03-2005, 11:49 PM | #4 | ||
Hehehehhehe
They have promised to wash it before he pick it up ;) then for the more serious mods as he calls them :P |
11-03-2005, 11:55 PM | #5 | ||
they call me Tibbo
To summernat standards just open the doors throw as much money you can fit inside it, close the doors and presto!
Seriously though good to see another Eski saved from the scrap heap
12-03-2005, 12:13 AM | #6 | ||
they call me Tibbo
I personally wouldnt wash it first up. Dont run the risk of pushing any wet leaves into the nooks and crannies of the body, especially into any small rust holes...
Throw on some thick rubber gloves for the spiders, start picking out all the leaves, foliage etc by hand when it is still dry.. Get most of it out by hand then with compressed air or a vacuum cleaner suck up the last of it. Once you have the bulk of the rubbish out of the way then introduce it to Mr. CarWash and Water
12-03-2005, 11:11 AM | #7 | ||
Beware of mood swings!
Location: Western 'burbs, put your bullet proof vests on!
Tip 1: Get rid of the freakin' spiders!!!
Once you get it to your place, give it a good clean out and start working on the most urgent repairs. That's a nice Escort you've got yourself there, take care of it and it will take care of you. And of course... enjoy. ;)
1993 EBII GLi Auto, 4.0L MPI rebuilt by JMM, JMM Dev1 kit, JMM Hi Flow Cat, still to hit the quarter mile. :Up_to_som
Dyno Sheet-14/07/05 |
12-03-2005, 11:28 AM | #8 | ||
windsor user
im hoping, with all that crap over the bonnet cowling, that its not rusted away...
its not good to have all that wet leaves on there.....:( other than that it looks like quite a straight esky. good luck with it lad |
14-03-2005, 05:47 PM | #9 | ||
have you seen my marbles?
summernats standards????? it'll take afew years and quit a few grand.....
start off with getting it cleaned up, take the motor out paint it and stick a 2litre in it, then you can go from there.....
comfortably numb... |
14-03-2005, 07:36 PM | #10 | ||
some mods you might want to think about.... :
if you want to regester it you wont be able to put twin sidesuckers on it due to the ADR's so a 38/38 or 40/40 down draft or a holly carb..... if your not going to drive it on the road a lumpy cam and lightened flywheel would get it going.... extractors and 2.25 straght through exhaust.... keep the 3.77: diff or go a 3.99:1/4.11:1 for acceloration- LSD... mk2 cortina radiator and thermo fans.... steering quik rack... eurathane buses all round.. billstein shocks...5 point rear end.... bore it out.... ported head... high compression pistons... electronic ingnition bigger brakes and of course convert to disks all round... 5 speed manual..close ratio short shift.. good tyres if you want more EFI... stroke it... turbo/supercharged...intercooler NOS.... /you will also need to change the valves so you can run unleaded petrol....
comfortably numb... Last edited by kiwikid; 14-03-2005 at 07:38 PM. |
14-03-2005, 07:42 PM | #11 | |||
That would a nice fun car to drive around I reckon. Take care of it!
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
14-03-2005, 07:44 PM | #12 | ||
you could always drop in a:
V8 SR20 ZETEC COSWERTH CA18
14-03-2005, 07:57 PM | #13 | ||
windsor user
lol, i dont think the poor boy will be able to afford all these mods you guys are suggesting, hes only 14 afterall
14-03-2005, 08:00 PM | #14 | ||
i realise that he was asking about working it to summernats standars.....
and even what i stated is just the tip of the iceberg.....
comfortably numb... Last edited by kiwikid; 14-03-2005 at 08:02 PM. |
14-03-2005, 08:09 PM | #15 | ||
Aww leave him alone, at least he has a car that he can do up and if he starts now you just never know...
Good Luck with it Lad_of_MBFNW. ;)
14-03-2005, 08:20 PM | #16 | |||
they call me Tibbo
14-03-2005, 08:24 PM | #17 | ||
how was i having a go at him.
you've got a great little car there. you dont have to all those mods to get going they can be made to go pretty quikly with little money, but for a summernats car it has to be made extreme... and extreme=$$$$$ now that you have an escort you wont be able to get enough of them...enjoy
14-03-2005, 08:39 PM | #18 | |||
Great list that you've put together for him I think.
18-03-2005, 01:21 AM | #19 | ||
Fairmont Ghia
Now now, play nice peoples!
:lookedat: Relax, it's only the internet! : Good to see the Escorts live on forever! Tim! |
20-03-2005, 03:09 PM | #20 | ||
Tricolore Tard
stick a 9" rear end supercharged 351 in it, she will be awesome ;)
Chris
24-03-2005, 07:18 PM | #21 | ||
thanks guys i dont think ill have the $$$$$ to do all of that lol
i want to take out the back seats (less waight and it should look kool). clean all the spiders out (ewwww spiders)....... i want a fair bit of power at the wheels but i got not much money so what cani do to increase the power??? i still whant to drive it arownd the streats so what mods can i do tho have the power and still drive it arownd on the streets of mbfnw????
24-03-2005, 07:23 PM | #22 | ||
Try and find a 4.1 diff centre out of an esky panel van. That will give you a little more oomph around town!
Current Rides: 2000 AU 5L XLS ute; 1970 Mustang project |
24-03-2005, 08:54 PM | #23 | ||
kool whats the stock diff in the escort 1.6?????
24-03-2005, 09:03 PM | #24 | ||
3.77:1
taking the back seats out wont do much, i took mine out to get reaplostered had them out for ages put them back i and it was still the same.. start with extractors, exhaust and high flow air fillter..
24-03-2005, 09:05 PM | #25 | ||
4.11:1 might be alittle bit steep unless racing it...
a rejetted weber 32/36 carby out of a 2lt would go in your favor...
25-03-2005, 09:26 AM | #26 | |||
No longer driving a Ford.
So, what's the latest news with your Escort? Got it home and started working on it yet?
25-03-2005, 11:29 AM | #27 | ||
Just a quick update ....... she isnt quiet here as yet ....... Just organising a car trailer to bring her home.
I actually saw her yesterday and the piccys didnt do her much justice. All of the crap on the bonnet is only a rug with the original grille in it ........ a wash & polish & she will come up well for starters for the boy ......... The spider webs are fair dinkum though ...... ewwww at spiders :P They pumped up the tyres when he first saw her & they are still up .... not bad considering they were brand new 10yrs ago and just went down ........ they will do him for a little while yet while hes playing before any rego comes near ;) Only thing that concerns me a bit is the rust on the quater panel ....... he might have to do a panel beating course at TAFE once his pre apprenteship mechanics one is finished to learn how to weld properly :P |
26-03-2005, 07:14 PM | #28 | |||
I'm glad to hear that he's got himself such a nice little esky, keep an eye out for rust on the c pillar, they're notorious for that unfortunately.
27-03-2005, 12:17 AM | #29 | ||
something else they are notorious for is heater dome rust, you dont want that....
27-03-2005, 12:44 AM | #30 | ||
ED Fairmont 4.0L
cool. escorts rule (not quite as much as a coon though) and I used to co-own a '76 Escort L coupe that was driven up fire breaks, through streams, cros country al on standard suspension and drivetrain and never complained a bit. It was me uncles, then my grandads, them mine/my older bro's. I handed over my keys after a few months and he had it for years - it only died a 3 years ago when a SUV driver in Welly tried to get in the back seat without getting out of his car first.
PS: There's also a '77 Escort 45 panel-van in the drive behind my Fairmont - but it's my little bro's this time... am I'm gonna make that baby purr - as long as he pays for the parts!!!!!!!! PS: me bro threw a Cortina 2L motor and box under the coupe and man did it fly! Couldn't even feel the road on the tires when screaming down the Wellington motorway!
B'jabbers! Last edited by darkfang888; 27-03-2005 at 12:48 AM. |
