Old 30-11-2009, 08:36 PM   #1
R0BD0G
R0BD0G's Avatar
Default fuel pump flow direction?
need to know what way the standard fuel pump flows on the 1600 crossflow. does the angle peice at the top of the pump feed the carby or is it fed from the tank?
1628 Escort Project Thread
67.3 RWHP - Paramount Performance Dyno
DJ Automotive Tuned with proper jets
http://fordforums.com.au/showthread....4&page=1&pp=25
R0BD0G is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2009, 07:49 PM   #2
Billit1000
Billit1000's Avatar
Don't know about your particular model, but they normally have in and out stamped on the pump.
When the flag drops...
The bullsh!t stops...
Billit1000 is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2009, 08:18 PM   #3
R0BD0G
R0BD0G's Avatar
not that i noticed
thanks though
Old 02-12-2009, 11:23 AM   #4
Engine Guy
These standard mechanical pumps are a 'lift Pump' hold the pump as if it was fitted to the block the lower pipe goes to the tank, the upper pipe goes to the carb/fuel filter
If in doubt take the pump off, connect a pipe to one end dip in some fluid and operate the pump by hand...remember to clear the pump out before refitting to the engine
Engine Guy
Engine Guy is offline   Reply With Quote Multi-Quote with this Post
