Go Back   Australian Ford Forums > The Sales Yard > Spare Parts and Other Accessory Items > Genuine Ford Parts
Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member.
Old 01-09-2021, 05:15 PM   #421
GTLEGEND
Default Re: Genuine Ford Parts
Originally Posted by kcodezd View Post
Hi GT, I am after a Sx, Sy Territory rear tailgate garnish, the part that attaches to the lower part of the glass. Can you advise availability and price delivered to Brisbane.
Thank you.
Hi KCODEZD,
Have a look at the below pic and advise which part you are referring to as there is a trim on the interior and exterior. I will also need to know what model SX/Y you are chasing along with month/year as they differ accordingly or a VIN would make it easier.
Old 01-09-2021, 05:31 PM   #422
kcodezd
0o\==^==/o0
kcodezd's Avatar
Originally Posted by GTLEGEND View Post
Hi KCODEZD,
Attachment 104769
Thanks for getting back so quickly GT. Part nÝ is 41018 for vin 6FPAAAJGAT9C68748.
Oldest to youngest
1971 ZD Fairlane
1978 W123 Mercedes Benz 280e
2004 BA XR8
2007 W211 E63 ////AMG
2008 Fiat Ritmo -for the kids to learn with
2009 SYii Territory Ts
kcodezd is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2021, 08:13 PM   #423
GTLEGEND
Hi mate, can get that part for $240 + delivery. I have no idea on the cost of freight and it will depend on the size of the box as Aus Post will not take items over 1M long.
I can try to see if I can get the box dimensions and weight and go from there if you are interested..
Old 02-09-2021, 08:35 PM   #424
kcodezd
0o\==^==/o0
kcodezd's Avatar
Thanks Legend. Count me in. Especially if you can keep delivery under $40.
Oldest to youngest
1971 ZD Fairlane
2004 BA XR8
Old 02-09-2021, 08:40 PM   #425
GTLEGEND
Ok will try and get an accurate freight quote. I have located one that I can get dimensions off. Let you know sometime tomorrow..
Old 07-09-2021, 01:59 AM   #426
sadbabyman
Originally Posted by aussiblue View Post
I have just ordered this sunload sensor from ebay USA https://www.ebay.com/itm/Genuine-For...UAAOSwyDNdt8gm I will let you know here how it goes compatibility wise. I will also test it and pull the old one apart to see what light dependent resistor or similar component it uses. EDIT: Damnation just found it cheaper here: https://www.fordpartsgiant.com/parts...-19e663-a.html AU$85.15 including shipping. Ended up being able to get it there i.e. FordPartsGiant as I was still waiting for a shipping quote from the ebay seller.
Hey I was wondering if there was any update to this?
Thanks
sadbabyman is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2021, 09:41 AM   #427
I had one attempt at removing the old one so I could try fitting the new one but health (recovering from minor surgery) and other issues has delayed any further attempts for the time being. Playing around with the top the dash to get the old one out also made it start working again.
Old 11-09-2021, 09:48 AM   #428
GTLEGEND
For YTRY4:
Old 11-09-2021, 07:56 PM   #429
mad2
Regular...with metamusal
easier to get out of a Terri than the Falcon.
mad2 is online now   Reply With Quote Multi-Quote with this Post
Old 15-09-2021, 10:11 AM   #430
GTLEGEND
For SJG66..
AU V8 Power Steering.pdf
Old 15-09-2021, 09:35 PM   #431
T3rminator
T3rminator's Avatar
Hey GT Legend,
Whats the cost for a OEM front crankshaft oil seal for a 2004 BA MK2 Falcon, 5.4L 3v, barra 220?
Thanks.
Rides (past and present)
T3rminator is online now   Reply With Quote Multi-Quote with this Post
Old 15-09-2021, 09:40 PM   #432
GTLEGEND
Originally Posted by T3rminator View Post
Hey GT Legend,
Thanks.
Hi mate,
The front crank seal in the timing case is the same for both 3V and 4V V8 engines.
$50 plus freight if required.
GT
Old 16-09-2021, 08:18 AM   #433
sadbabyman
Hey mate, was looking for the two bolts that mount the air intake box to the sheet metal just underneath the pcm. Car is a 08/2011 FG petrol NA 6cyl manual sedan
I was also curious if genuine sets/kits/assemblys of screws/bolts exist for sale from ford? Things like the radiator shrouds, lower air deflector and other plastic exterior parts that use metal screws or plastic scrivets. I'm not after specific ones as of yet just looking for a convenient solution if it exists.
Thanks mate
Old 16-09-2021, 09:16 AM   #434
T3rminator
T3rminator's Avatar
Hi mate,
GT
PM sent.
Old 16-09-2021, 10:44 AM   #435
GTLEGEND
Thanks mate
Hi Mate,
Have a look at the image below, believe you are referring to bolt labeled HS1. They are $3 each plus postage if required.
Ford do not do fastener kits, you have to buy each individual one bu one unfortunately.
Old 16-09-2021, 01:22 PM   #436
GTLEGEND
Originally Posted by TURBO_GHIA View Post
*Re: Genuine Ford Parts
Originally Posted by*GTLEGEND*
Hi,
Set of rear door glass hinges would be $250 including freight, how ever there is only RHS available at this point in time, the LHS wont be available until April/May next year due to the COVID lockdown where the manufacturer has been closed all this time.
Any update on these ?
First batch of hinges are now available, unsure what the back log of orders are so they have either all sold out again until the next batch arrive or there are a few still left available. Hopefully not too long before there is constant supply.
Old 17-09-2021, 12:12 PM   #437
YTRY4
Hey GT,
Do you know the part number and rough cost for an fgx xr6 turbo drivers side(fuse box) engine loom?
I know the FG mk2 was BR29-14K011-ke/BR29-14K011-kc part number I believe.
YTRY4 is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2021, 12:32 PM   #438
GTLEGEND
Originally Posted by YTRY4 View Post
Hey GT,
In FG2 the part numbers you list for that loom is one of about 40 different part numbers for that same part.
In FGX there are 14 different part numbers for that part. Maybe a VIN would narrow it down to the correct one you are after.
For turbo from what I can see it will either be ER2Z14K011JB or ER2Z14K011KB. The JB is $390 and the KB is obsolete.
Need a bit more information to clarify..
GT
Old 17-09-2021, 12:37 PM   #439
YTRY4
GT
Darn, that is just a part number I found on eBay for an fg mk2 turbo loom being sold.
I donít have a specific vin as itís part of a conversion process to go from FGX G6e to FGX g6e turbo, I specifically have been trying to find the entire fuse box loom from an fgx turbo automatic car to save me cutting into the original engine loom.
I need the turbo automatic engine loom on the drivers side(including fuse box) as it has the boost solenoid loom section attached and the correct wiring loom to dual thermo fans compared to the NA FGX being a single fan.
Old 17-09-2021, 12:47 PM   #440
GTLEGEND
Part Descriptions:
JB: WIRING - ENGINE CHARGE TEMP. SENSOR (4.0 DOHC PETROL EFI TURBO 24V VCT, HIGH FRONT LAMPS W/SIGNATURE DTRL)
KB: WIRING - ENGINE CHARGE TEMP. SENSOR (4.0 DOHC PETROL EFI TURBO 24V VCT, WITH QUAD HEADLAMPS)
These are the only two where turbo engine is mentioned.
Old 17-09-2021, 01:12 PM   #441
GTLEGEND
Old 17-09-2021, 02:45 PM   #442
Bossxr8
Peter Car
Bossxr8's Avatar
Part Descriptions:
Ones XR and the other G6ET?
Thread Tools
Display Modes
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
