17-03-2018, 06:06 PM | #1 | ||
Hey I'm looking to upgrade my diff gears in the AU,thinking 3.7s or 3.9s would be ok..do ba xr6 have 3.7 or xr6 turbo....
[B]WTB (Syd)...AU 5.0 or xr8 4 speed auto transmission in good working cond /B] |
17-03-2018, 06:16 PM | #2 | ||
No. 3.45. M78 diff is shared in heaps of commodores and others. Skylines and pintaras are the most common donors for 3.9 and 3.7. They're a bit hard to get now be cause everyone wants them, new gears can be had for $400 all the way up to 4.11. I found a shop in Melbourne to supply and install for $1000
17-03-2018, 07:10 PM | #3 | ||
19-03-2018, 03:38 AM | #4 | ||
You'll find 3.73 gears behind 6 speed manual falcons. However, Turbo and V8 models are M86 and will not fit your housing. As mentioned, you can find the ratios you're after in old pintaras and skylines. But be warned, there are 3.89 and 3.91 ratio from those models. You want the 3.91 as the 3.89 are notorious for whining. I used the 3.89 in my BA and they whined like a banshee. To the point I went back to a 3.45 (I do miss the acceleration though).
2017 Ranger XLT 3.2L Hi-rider |
19-03-2018, 04:05 PM | #5 | |||
2009 Fg xr6 turbo
I haven't fitted them yet though $$$$$$ |
19-03-2018, 06:16 PM | #6 | |||
19-03-2018, 10:57 PM | #7 | ||
Thanks for the info ...so with the skyline diff is that from the regular 32.33 gts gtr type or the boxy shape earlier one the 31 and what model fords got the 6 speed manual...are these lsd centres
22-03-2018, 01:15 AM | #8 | |||
XR6T BA 2002
0431557226 Call Glen He built my diff, he used a VL turbo LSD 4 pinion and 389s from a skyline I have no Whine in my diff at all based in Keysborough. (GJV Automotive) He has a ebay store too, His username is Vicmelboz. He specialises in BW diffs You then need a speedo corrector behind the cluster If you have an auto then need to follow some instructions i posted on how to get the VSS to talk to the ECU to shift the trans properly https://www.fordforums.com.au/showthread.php?t=11464112
XR6T 2002 BA
22-03-2018, 07:35 PM | #9 | |||
Supposed to read "You'll find 3.73 gears behind 6 speed manual Turbo and V8 models, however the diffs in these are M86 and will not fit your housing." The longer first gear with 3.45 gears is a hoot rolling around town though
22-03-2018, 10:27 PM | #10 | ||
Yeh im running a turbo box with 3.23's
06-05-2018, 05:00 PM | #11 | ||
HSV - I just ate one!
fwiw, my BF series 1 XR8 6 speed manual had a 3.45 diff
06-05-2018, 07:06 PM | #12 | ||
Is changing just the centres to a higher ratio easily doable....like find a xr6 turbo grab the diff centre ,bolt her in an go do sum hectic donuts an burnouts...
12-05-2018, 02:53 AM | #13 | ||
