27-07-2011, 06:29 PM | #1 | ||
Hi, My mk1 Escort is having problems with the front end, I got told about a year ago by Bridgestone that I needed to replace the steering rack when I got a wheel alignment. Now the car shudders when I brake. It got worse over time. Question is - Is the steering rack the reason? I would like to know before I replace it.
27-07-2011, 07:12 PM | #2 | |||
Fixing Ford's **** ups
Nope. It'll be warped rotors. Get them machined or repalce them. That'll fix it
27-07-2011, 07:59 PM | #3 | |||
27-07-2011, 09:59 PM | #4 | ||
Any looseness anywhere in the front end will cause problems with wheel movement. SMCKA parts has a rack repair kit, if it hasnt been done for some time its probably needed.
27-07-2011, 10:16 PM | #5 | |||
Time also warps rotors, not just hard braking etc etc. I surpose there's a few questions I forgot to ask, which would eliminate the rack being a problem. Does it wobble when you don't brake at speeds round 70 KPH +? Is the car a "pig" to drive above 40 KPH? ie, the steering wheel wobbles and you're constantly correcting the steering whilst driving in a straight line and the wobble gets worst as you increase speed? Do you have a saw tooth effect on the tyre edges?
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises. Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone Last edited by svo supporter; 27-07-2011 at 10:22 PM. |
27-07-2011, 10:24 PM | #6 | |||
27-07-2011, 10:30 PM | #7 | |||
27-07-2011, 10:32 PM | #8 | ||
Shuddering threw the steering wheel*
28-07-2011, 12:39 AM | #9 | |||
Stuffed front end parts including rack = tyre wear problems. Brake pads need an even surface to press against to prevent wobbles once pressure is applied. Now I'll leave you guess what the problem would be from that.
28-07-2011, 12:58 AM | #10 | |||
28-07-2011, 01:00 AM | #11 | ||
Got a mobile guy that does my workmates cars, Ill ring him tomorrow.
11-08-2011, 02:22 PM | #12 | ||
Discs machined, problem solved.
11-08-2011, 02:47 PM | #13 | ||
Do you mind me asking how much machining the disks cost?
Regards, Tim ------------------------------ 1978 Ford Escort Panelvan |
11-08-2011, 08:25 PM | #14 | ||
My mechanic near work (RAA approved) did it for $99.50. I work at Royal Park, SA. The mechanic my wife takes her car to said he would do it for $77 Salisbury South.
12-08-2011, 01:56 AM | #15 | |||
****......Oops sory about the language. You got ripped severely. There's 2 places at Salsibury North, I am aware of, that do them for $35 ea.
12-08-2011, 01:14 PM | #16 | |||
12-08-2011, 05:50 PM | #17 | ||
Tippy-tronic Free Zone
Sometimes it is worth paying a little bit more it it is walking distance, rather than have lost hours driving around town (for 99-(2*35) = $29)
12-08-2011, 05:56 PM | #18 | |||
12-08-2011, 10:20 PM | #19 | |||
ABS and Torque Tyres. Both on Commercial Rd.
13-08-2011, 01:19 PM | #20 | |||
15-08-2011, 07:51 AM | #21 | ||
Rally Nut
The caps on the end of the tie rod arms are the main points of wear, the steering rack kit replaced the plastic bush with a metal bush. I did this in my quick rack some years ago and havent had a problem since (plenty of events on dirt)
I would suggest that if you intend to keep the car for a while I would just look for a quick rack & replace it (approx $210). dont forget to replace the bushes that hold the rack to the cross member, then have a look at the flexible steering joint |
15-08-2011, 07:24 PM | #22 | |||
01-09-2011, 03:43 AM | #23 | ||
Old Mate
I was hoping it would be the rack, quick racks are fun. I got a 1.2 (maybe1.4) from racetune in Perth. Can't remember how much it was but it's a bit cheaper if you trade in your old one, no matter the condition. Interesting at high speeds in the wet...
01-09-2011, 09:08 AM | #24 | |||
27-10-2011, 08:14 PM | #25 | ||
State of Confusion
I've got rack rebuild kits and brand new 2.9 and 2.4 racks in stock now. New shipment just arrived so may not be on the site until Monday/Tuesday after I sort it all out.
2016 FGX XR6 cab chassis 1970 Mustang base Sportsroof |
29-10-2011, 06:35 PM | #26 | ||
I see machining discs as a useless exercise these days as its not too often they come up within spec, next roady dont be surprised if you are done for undersize discs. They are cheap as anythin brand new now
example : http://www.ebay.com.au/itm/FORD-ESCO...item415cb5846b |
