Old 22-04-2016, 11:48 PM   #1
Grogan
Question Ford Fairlane 500 build date query
I am trying to get the year of my Ford Fairlane 500 that has the small [Ford Motor Company of Australia Limited] badge
ID plate has the following
Prefix Serial No Sido No Model
JG37HC 39472 628080 24837
ENG--------Trans --------- --------- Paint --------- Trim
Y -------- R -------------- ---------- E ------------- R
And rego sticker has the CHAS - QPZX757 AND -1969 FORD
Stamped into the top Radiator cross member is JG37HC 39472
2nd question: is the rego sticker wrong?????
Grogan is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2016, 10:02 AM   #2
Simple6
Simple6's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Tech article on rear bushes.
Default Re: Grogan
Well 24837 is a ZB Fairlane 500 so it'll be a 1968 or 1969.
I'm short on time here at the moment, so I can't find the exact page on here to the decipher the 'C' in your VIN - which would give us a specific build date.
The rest of it just says that it was built in Brisbane and should be a 302 auto in Polar White with Champagne trim (? Though apparently Champagne trim was a ZA item and isn't listed as available with ZB).
Have a search of the classic forum and the tech resources because that information is out there.
1976 XB Falcon 500 Wagon - BUILD THREAD
Sherwood Green | 3spd/250CI | Running Whitewalls on a 2.5" Drop
Simple6 is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2016, 10:46 AM   #3
Pedro
Pedro's Avatar
Default Re: Grogan
You may find some information here .. http://www.uniquecarsandparts.com.au...ifications.php
Pedro is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2016, 02:43 PM   #4
Grogan
Default Re: Grogan
Thanks very much I found build date is May 1968 but a little confused You say Brisbane as build factory on model 24837 when JG37HC indicates Broadmeadows the plot thickens
Old 23-04-2016, 02:48 PM   #5
My32Doors
Default Re: Grogan
Brisbane build is JH.
My32Doors is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2016, 11:26 PM   #6
Simple6
Simple6's Avatar
Default Re: Grogan
Sorry mate, stitched you up, Broadmeadows is correct...
Old 25-04-2016, 11:33 AM   #7
Grogan
Default Re: Grogan
If you say that MODEL 24837 (as per ID plate) is a ZB where do I find this information ?
Old 26-04-2016, 11:42 AM   #8
Simple6
Simple6's Avatar
Default Re: Grogan
http://www.fordforums.com.au/vbporta...er=desc&page=2
There's a link to the 'Tech Resources' at the top of each page. Filter through there and you'll find a wealth of information.
Old 26-04-2016, 02:22 PM   #9
Grogan
Default Re: Grogan
Thanks found what I was after Linking the HZ to something I could identify
Old 26-04-2016, 02:23 PM   #10
Grogan
Default Re: Grogan
Sorry ZB not Hz
Old 26-04-2016, 03:40 PM   #11
BFGasUte
Default Re: Ford Fairlane 500 build date query
Hello,
Mistakes were made with plates at times, so if things dont seem right it may be a simple human error.
BFGasUte is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2016, 04:18 PM   #12
Grogan
I have just found the VIN No: CD254930 stamped into the L/H front shock tower and the numbers on the old rego sticker I believe would be the plate number last on the car even though the sticker has it marked as CHAS-QPZX757 and in large print PZX 757.
As above this is the first time this VIN number has come up in my search for info.
Old 19-11-2018, 02:09 PM   #13
cwicks
Hi, doing some searching my dad who has a Fairlane 500 that we believe is a 59 model produced in Australia. So far we haven’t been able to find the chassis stamp with the VIN, but the I.D. plate seems to be completely wrong numbers. Is anyone able to help?
Serial prefix 1R.11.61 serial number 60466 model number 1212
Thanks!
cwicks is offline   Reply With Quote Multi-Quote with this Post
