Old 25-07-2017, 09:27 AM   #1
xr8 007
xr8 007's Avatar
Default 2006 LS Engine light P0400
I have a 2006 LS Focus. I keep getting the engine light come on, as per the OBDII scanner spits out code P0400 (exhaust gas flow something). Did the obvious google search and seemed that most people changed the EGR valve and Intake manifold control valve purge solenoid.
The only symptoms the car demonstrates is that it runs abit rough on idle when its warmed up and sitting in traffic however I more inclined to blame the engine and trans mounts for this as the idles are ok however the car vibrates abit.
So I changed both however the engine light keeps popping back up. Any ideas on anything else I can be changing or looking at? Thanks heaps in advance.
Build Thread: BA XR8 with all the goodies.
fordforums.com.au/showthread.php?t=11247663
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2017, 09:49 AM   #2
DZFord
DZFord's Avatar
Default Re: 2006 LS Engine light P0400
Consider blocked / clogged up EGR passages. There is an EGR tube under the intake manifold, as well as the passages in the cylinder head.
The EGR flow is monitored by the MAP sensor (or TMAP sensor in this case as it has the intake air temp sensor incorporated). Your MAP sensor readings seem all OK?
Of course, there could be an ECU error in controlling the EGR / wiring fault, but this is difficult to check without an oscilloscope, as the EGR stepper motor is apparently pulse with modulated.
Old 28-07-2017, 01:35 PM   #3
xr8 007
xr8 007's Avatar
Thanks heaps for the reply DZ.
Silly question but you asekd if my MAP sesnor read ok? Is there a way of checking?
Old 30-07-2017, 05:52 PM   #4
DZFord
DZFord's Avatar
Not a silly question - just use your scan tool to graph manifold pressure against engine load/RPM. Ensure it increases / decreases as expected - eg. increase in manifold pressure with increase in load.
