Old 06-03-2015, 10:53 AM   #1
Sprint
Sprint's Avatar
Question Consul to Cortina conversion?
Thinking about buying a Cortina mk1, well what I have on offer is actually a consul Cortina 62-63. I love the non airflow outside but I hate the dash and controls.
Is it possible to convert the dash from Console to Cortina? Round 67 gauges instead of the bar Consul speedo.
This is my first Cortina mk1, im usually a Escort guru but know little about early Cortina's. I plan to restore and convert to pinto/zetec/duratec etc as a sleeper.
Advice much appreciated.
Sprint is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2015, 08:13 PM   #2
chappy60
Default Re: Consul to Cortina conversion?
You could go for the 64 consul which had round gauges
chappy60 is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2015, 08:27 PM   #3
foxtrot3
foxtrot3's Avatar
Hi. A late model steering column can give you wipers/washers, park/head lights, turn sigs, headlight dip/high/flash and ignition switch, how many more controls do you need? Hot rodders have been changing gauges for years, there are matching speedo, tacho and quad (fuel/oil/temp/volts) gauge packs almost everywhere. Cheers MD
HI
I'M MICHAEL
foxtrot3 is online now   Reply With Quote Multi-Quote with this Post
Old 08-03-2015, 06:38 PM   #4
chappy60
he was talking about the dash not the steering column
Old 08-03-2015, 08:12 PM   #5
foxtrot3
foxtrot3's Avatar
Hi. The OP said he hated the dash AND controls, I think I covered both seeing the column would need to be changed to a collapsible unit to pass engineering inspection. By picking the right column you would only need hazard light switch (if wanted) heater controls (needed but left out of many modified cars, may argue not required in pre 70's car) and brightness control for dash gauges (hide in bottom edge of dash). Cheers MD
HI
I'M MICHAEL
Old 08-03-2015, 09:40 PM   #6
CQB-241
Car tragic
CQB-241's Avatar
The early controls are cool but the strip speedo not so great. Look for a ore-airflow Mk 1 Cortina GT (Lotus the same) pod (repops avail in UK). Replaces strip speedo and allows use of round gauges without metalwork.
CQB-241 is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2015, 09:54 AM   #7
dirty hands
Over Thinker
dirty hands's Avatar
pic says 67 cortina mark one ?
dont forget to add a racing start button
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2015, 12:09 PM   #8
CQB-241
Car tragic
CQB-241's Avatar
That is an airflow (post-'64) car. GTs had extra cluster where ashtray is.
The pre-'65s had a strip speedo except for GT and Lotus which had a binnacle that fixed to dash in place of speedo with a round gauge-containing cluster.
Old 09-03-2015, 07:59 PM   #9
dirty hands
Over Thinker
Sprint not sure if you can do what you really want with the dash
without some mods
shove a tacho where the air vent is
Old 14-03-2015, 07:21 AM   #10
chappy60
not all pre airflow cars had strip speedo's the 64 consul Cortina had round gauges and it did not have to be a gt or lotus to have this the gt had three large gauges 1st had fuel,oil pressure &temp in it 2nd was a tacho 3rd speedo standard car had 2 gauges 1st speedo 2nd fuel & temp and the early gt [strip speedo] had the tacho on the steering column which was a column change steering column surround with tacho placed in the hole where the gear change would of come out of
Old 03-05-2015, 06:07 PM   #11
TER2BO
REV8380
TER2BO's Avatar
I have a 64 GT gauge pod which according to others will fit over the strip speedo. Also centre consul ,chrome side strips for a 2 door GT ,grill and lots of other stuff in the garage which may be useful. PM me if your interested.
For Older Racing Drivers
2006 SY Turbo Territory - Dual Fuel, Debunged, F6 Lower Snorkel,Tune, 20"Rims and Pedders Suspension.
Previous Ford Rides
Tickford AU & SVO EA S/wagons - Dual Fuel
Mk1 & M2 Escorts - modified
1969 Mk2 GT Cortina - very orginal.
1964/5 Mk1 GT Cortinas Group N Racing
1965 Mk1 Lotus Cortina Group N Racing
1964/5 Ford Mustang Group N Racing
TER2BO is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2015, 12:31 AM   #12
marth06
Bar speedo's cortina's are rare. Leave it as it is.
If you can find one but there very rare too (there was one on eBay for $350), get the tacho from a GT that they added on to the steering columns on the 63 GT's.
marth06 is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2015, 12:36 AM   #13
marth06
Yep agree 100%
I have 64 pre airflow GT.
