Old 06-07-2015, 06:58 PM   #1
cmmillar
Default Low washer fluid level
Hi Mondeo drivers, Still loving my 2010 Mondeo, however the warning light for low washer fluid level keeps coming on even though I've filled up the washer tank. Any ideas? I tried looking on this forum, but couldn't find the answer. Thanks in advance!
cmmillar is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2015, 01:37 AM   #2
russellw
russellw's Avatar
Default Re: Low washer fluid level
If it's on all the time then check that the wire to the sensor isn't damaged or disconnected. It's one of those where no signal = a negative signal.
Russ
Old 07-07-2015, 04:27 AM   #3
cobrin
Challenge Accepted!
cobrin's Avatar
here's a trick for you, I had similar issue about a year ago.
Blow into the filler neck with all the lung power you have, obviously lips sealing the tube and then release and move your face out of the way (in case you get splash back) then go check for the error.
It shouldn't show the error anymore.
TIP: now is time to get washer fluid instead of water and fill it when near empty. I find it's much better for the pump/system than water alone. (if currently using water only that is)
Old 07-07-2015, 07:57 AM   #4
cmmillar
Hi Cobrin and Russellw, thank you both for those suggestions. I will try both and let you know how I go and yes, I am just filling with water, will get some washer fluid instead. Thx
Old 08-07-2015, 11:02 AM   #5
sailaway
sailaway's Avatar
Timely post as I filled mine for the first time yesterday after warning came on.
Handy to see if mine stays off and if not some fix its here to try.
Good luck with yours.
Pete
Melbourne
2010 Ford Mondeo Zetec TDCi Diesel
Colour: Frozen White
sailaway is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2015, 12:53 PM   #6
cmmillar
Would you believe it hasn't come back on since I made this post! I've been waiting for it to come on so I could try these things and now it's suddenly stopped! Will remember this for next time though. Good luck with yours sailaway!
Old 09-07-2015, 11:54 AM   #7
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
The switch on these things are pretty simple (just a float switch). You can check to see if its the switch by shorting out the plug its connected to. Should act the same as if the tank was filled.
Daniel
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2015, 01:03 PM   #8
sailaway
sailaway's Avatar
Same here all okay.
Thanks
Pete
Melbourne
Old 19-09-2018, 04:45 PM   #9
steerage250
Same problem with my 2012 Mondeo. It looks like I have to crawl underneath (and probably take-off the big cover) to get at the switch - can anyone confirm that is correct ?
steerage250 is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2018, 09:25 PM   #10
cobrin
Challenge Accepted!
cobrin's Avatar
I noticed mine ('09) were easier to get to with the LH/F wheel arch off.
Undecided replacement...
