Old 28-05-2007, 07:17 PM   #1
Dayvo
Default Thermo Fan
Hi all , My son has a KF Laser and we are having overheating problems .
We have narrowed it down to the thermo fan .The fuse is ok ,and when i hook the fan directly to the battery it works , but if you let idle for a while it overheats but the fan will not cut in .Is there a sensor in or near the thermostat that tells the fan to cut in at a certain temp . The air con fan works when the air con is turned on but the engine fan doesn't
Any help would be welcome , Dayvo
Dayvo is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2007, 05:51 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
the fan should have a sender into the engine block or into the radiator at the bottom
for switching on and off ro cool
follow the wires from the fan
if the temp sender inlet manifold unit has two wires then that may be faulty
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2007, 08:55 PM   #3
Dayvo
Thanks for the info , will check it out on the weekend
Old 29-05-2007, 10:35 PM   #4
dirty hands
Over Thinker
Default info
one one diagramme i have the thermostat housing with two senders
on for guage and one for fan
dont know what is fitted to your car :
Old 30-05-2007, 06:03 PM   #5
Dayvo
It is a 1.6 has a carby not fuel injected if that is any help
