02-03-2005, 07:36 PM | #1 | ||
ANOTHER FORD DRIVER
i just got a ef tbar i want to put it in my ea, my question is what do i need to do this
02-03-2005, 08:30 PM | #2 | ||
windsor user
you need to get the longer rod from the EF as well
then it should just go in... |
03-03-2005, 01:52 AM | #3 | ||
Team Urinal Cake Racing
wont work if u got the h/d bar as it runs across the rear bar the ea one goes under the spare tyre well
03-03-2005, 03:03 AM | #4 | |||
V8 Ghia & BF2 XR6 + Wagon
As mentioned, you need the rod that goes underneath it.
Windsor now harmonically balanced for EARTHQUAKE free driving!: |
03-03-2005, 11:05 AM | #5 | ||
ANOTHER FORD DRIVER
i got the rod but it looks like it needs to be longer
04-03-2005, 03:35 PM | #6 | ||
Are you sure you're not using the EA rod?
That's why you need the rod that was originally underneath the EF shifter cos its longer. If you have the right rod & shifter combo it should fit if its screwed right down then wound back out so it's straight, then do lockng nut up.
04-03-2005, 04:09 PM | #7 | ||
ANOTHER FORD DRIVER
it looks like the ea rod is bigger then the ef rod
04-03-2005, 04:40 PM | #8 | ||
PM me if you want
get a thin tent peg and cut it to length and add the required slight bend to it.
04-03-2005, 04:59 PM | #9 | ||
I put one on my EB, you have to get a bit of rod as Dellboy said and bend it into shape. Both the EA and EF rods are too short.
2003 Narooma Blue BA XR6 5spd Manual. Pacemaker 4490 Extractors 2.5" Exhaust High Flow Cat SS Inductions "Growler" CAI Underdrive Pulley Mal Wood H/D Clutch Custom Tune 18" XHP Sabre's 12" Kicker Sub 169.2 rwkw
04-03-2005, 07:51 PM | #10 | ||
Boooostn'
i put an EF shifter handle on my NA 3spd, and all I did was go to ford and buy the rod from them for an EF and it fit no worries at all... EF rods are long enough for it.
