Old 18-08-2019, 07:43 PM   #1
Ford Falcon XR6
Ford Falcon XR6's Avatar
Default Fitting aftermarket head unit
Hi Everyone
Quick question I have a 2001 Au fairmont ghia the factory cd player is stuffed. I want to fit an aftermarket head unit but don't want to lose my premium sound. The patch harnesses for the new head unit doesn't have an extra plug for premium sound. Is there a way around this to get everything to work?
Thanks
Ford Falcon XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2019, 07:49 PM   #2
PG2
#neuteredlyfe
PG2's Avatar
Default Re: Fitting aftermarket head unit
Originally Posted by Ford Falcon XR6 View Post
Hi Everyone
Thanks
I have an aftermarket head unit and was able to retain the premium sound (though I did replace the front/rear speakers and tweeters and left the stock sub woofer). The speakers run off an aftermarket amp and the sub-woofer runs off the factory amp.
I can't quite remember how it was done (someone else did it for me). I can have a look in the next day or so to see how it was done if you wish.
Old 18-08-2019, 09:09 PM   #3
Ford Falcon XR6
If you could have a look that would be great. Thanks
Old 19-08-2019, 12:00 PM   #4
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
All you need is to have some RCA connections tapped into the factory amp wire that plugs into back of premium sound unit and plug that into back of aftermarket unit and the sub should work as normal.
PridenJoy is online now   Reply With Quote Multi-Quote with this Post
Old 19-08-2019, 02:20 PM   #5
foxtrot3
foxtrot3's Avatar
Hi. From memory the premium sound amplifier in the boot is a "modified" alpine unit (I seem to think the gain/level controls were covered or removed) but it still had RCA plugs on the end of the case. If you dont want to put plugs on the front end of the wires you can run new rca leads to the amp and just hook up to the trigger wire to turn it on. Cheers MD
HI
I'M MICHAEL
Old 24-08-2019, 11:13 AM   #6
Bill M
Bill M's Avatar
When I replaced my OE head unit with an Alpine I wanted to keep the steering wheel controls. The Aerpro patch harnesses ended up costing nearly as much as the head unit.
Bill.
AUII XR6 VCT ute
20 years and still going strong!
Bill M is offline   Reply With Quote Multi-Quote with this Post
