Old 30-09-2017, 12:16 PM   #1
Edxr6
Default AU XR6 won't start
Guys,
I am thinking of purchasing a cheap 2001 series 2 AU XR6 auto, apparently the car won't start, kick's over fine. Has fuel and the smartsheld is working, any ideas I can start eliminating.
Edxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2017, 07:34 PM   #2
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
Default Re: AU XR6 won't start
Starter relay.
PridenJoy is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2017, 08:11 PM   #3
snap0964
Originally Posted by Edxr6 View Post
kick's over fine
Originally Posted by PridenJoy View Post
Starter relay.
Bit pointless ??
Confirm yourself it has fuel, injector pulse and spark.
snap0964 is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2017, 08:38 PM   #4
PridenJoy
Originally Posted by snap0964 View Post
Bit pointless ??
Not pointless. Car cranks over continuously without firing up when relay is faulty.
Old 30-09-2017, 11:56 PM   #5
Edxr6
Starter relay.
PridenJoy,
Could I interchange with another relay to see if this is the problem, if so, what relay would be suitable?
Old 01-10-2017, 06:02 PM   #6
PridenJoy
PridenJoy,
The starter (and ignition relay, either could be the problem) relay are in the engine bay near the battery. There's a diagram somewhere that describes which relay is which. Not sure if it can be swapped with any others without looking at them again but i would have thought they're easy to get from the wreckers, pick a part and such, to try.
Old 01-10-2017, 09:53 PM   #7
snap0964
Yes pointless. Starter relay will be fine.
The 2 relays are the ECU(or EEC) relay and fuel pump relay. With IGN on, check for 12v at an injector plug, ISC plug, or TPS plug. If there, the ECU relay is fine.
Focus on the easy things first.
Old 01-10-2017, 10:17 PM   #8
PridenJoy
Yes pointless.
Ok. You obviously know better than the auto elec that i witnessed replace the starter relay and ignition relay on two separate cars and rectified the problem with exact symptoms as OP.
People can either take the advice and suggestions or leave it. It's been given anyway.
Old 01-10-2017, 11:55 PM   #9
superroo
You can't stop the signal
superroo's Avatar
How do you know smartshield is working?
What is the warning light doing with the ignition on or white cranking?
Old 02-10-2017, 01:03 AM   #10
snap0964
Ok. You obviously know better than that auto elec that i witnessed replace the starter relay and ignition relay on two separate cars and rectified the problem with exact symptoms as OP.
Don't know, maybe get the auto elec on here to provide some details, rather than someone relaying something 2nd hand ? Just trying to give some simple universal advice to the OP to solve his problem. Why would you replace a starter relay when the starter motor operates correctly ? Why can't you say which relay caused the problem?, or whether it may've been simple bad connection problems ? Without knowing the complete details and testing, How do you know this scenario is exactly the same? When faultfinding, assumptions will cost you dearly.
And people should spend their time contributing to the thread rather than getting upset just because alternate advice doesn't match their 'staff answer'.
Old 02-10-2017, 02:28 AM   #11
The possibilities are almost endless but common faults include failed coil pack, blocked fuel filter, failed fuel pump, and failed PCM ...
Old 02-10-2017, 11:34 AM   #12
PridenJoy
I could waste my time and expose the many holes in this stupid post but it would clearly be ........... a waste of time. So yeh just carry on being a genious.
Old 02-10-2017, 07:29 PM   #13
Tickford.
🚫⏰4️⃣🐃💩
Tickford.'s Avatar
^^^ This. The engine is cranking over so it cannot be the starter relay. For any engine to fire up (not just AU's) it needs air, fuel and spark. Check for the three mentioned by snap0964 and go from there.
Are you 100% sure it's not Smartshield?
Yes you can. From memory, on the AU's the relay to the left of the starter relay is for H/beam, to the right you have the fuel and LO/beam relays. Basically, any of the relays on the second row from top in the "fuse box" next to the battery. They're all the same.
If you want to confirm, maybe try pulling out the "faulty starter relay" and see if the car cranks over. I bet you it won't.
Agree. Unfortunately you will always have people handing over advice and suggestions because they think they're experts on the subject. In this case the subject and question being on the AU Falcon. God help us all if the advice given is different to theirs.
Tickford. is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2017, 08:45 PM   #14
PridenJoy
Hi Jude How's that Tickford Fairmont going? You seem different on the forums to real life.
Old 02-10-2017, 10:20 PM   #15
Edxr6
OK Fellas,
I rang the gentleman today for a bit more information about the problem, he mentioned that a red hand lights up, if this is any consolation to the problem.
I appreciate all the help, and most importantly we have one common interest in these Falcons, so let's not get into a debacle over a possible simple fix.
Cheers fellas
Old 02-10-2017, 10:34 PM   #16
I have to agree that if the starter motor is turning normally its extremely unlikely that the starter relay is at fault. If it was at fault the starter would either not turn at all or turn very slowly (and in the latter case it's more likely corroded prongs on the relay or corrosion in the relay's socket). See the circuit here: https://fordforums.com.au/wsm/wire/a...html#page00009
Old 02-10-2017, 11:24 PM   #17
superroo
superroo's Avatar
If the light goes out after approx 3 seconds with ignition on, then all is good.
But if the stays on or flashes, then you have a smartshield problem.
System is separate to unlocking the car
Old 03-10-2017, 12:17 AM   #18
snap0964
Yeah, true. If they're going to have a go at you, at least use the spellchecker as well . . . .
I rang the gentleman today for a bit more information about the problem.
Can you get access to the car to do some diagnostics? Hearsay over the phone won't cut it - you need to satisfy yourself with some testing.
Old 03-10-2017, 07:27 PM   #19
Edxr6
Cheers Snap0964, diagnostics would not be possible at this stage.
Regards
Old 03-10-2017, 10:36 PM   #20
snap0964
So what's your plan with this thing ?
Old 11-10-2017, 10:41 PM   #21
Edxr6
Fellas,
The car had a bit a rust, didn't proceed with the purchase.
Thanks Guys, much appreciate the input.
