Site Support If something isn't working or you have a suggestion ( a nice one !! ) let us know here. |
28-03-2011, 01:16 AM | #1 | ||
Awesome
Location: In my own little world..Everyone here knows me :)
Hi,
I have a suggestion...A Nice one I hope I had a thought today when taking apart my engine. Would it be possible to have a definition/index of common terms that relate to things on the forum or to cars in general? For instance, Honing: Common definition would be? 4v: Common definition? Dizzy etc...I could go on. The one that got me today was Firing order. I had no idea what it was until I looked it up. I know it sounds funny, but when you are a novice, understanding the correct terms helps so much! There are a lot of users that do not know what certain terminology is correct for what they are looking for. Is it a good idea? Can something like this be created and would anyone else use it? Cheers Col
28-03-2011, 01:27 AM | #2 | ||
Just keeps gettin' better
I like the idea!
Reading alot of the threads on here I find myself having to look things up, otherwise I have no idea what is being discussed. Obviously, doing a search helps, but to have definitions for the various terms readily available would be extremely useful.
The greatest pleasure in life is doing what people say you cannot do. |
28-03-2011, 10:35 AM | #3 | ||
Chairman & Administrator
The Tech Portal has an encyclopaedia module that we aren't using but it isn't very well integrated with the forum itself. re are a couple of glossary style add ons for vb3.5 so we might try one of them. At best it looks as if they are only integrated into the navbar rather than hyper-linking the text.
There are also a couple of keyword redirectors that hyperlink keywords to another URL and I suspect that might be a better way of dealing with it with the redirect to either a tech article (like the Ford acronyms one we currently have) or to the portal encyclopaedia. Cheers Russ
Observatio Facta Rotae
28-03-2011, 01:20 PM | #4 | |||
Awesome
I am happy to help write something up if it helps. I just found out today what Fast glass is! Cheers Col
28-03-2011, 02:40 PM | #5 | ||||
Captain Malcolm Reynolds
Great idea, I really like it.
Could become helpful!
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car) Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla Quote:
28-03-2011, 04:01 PM | #6 | ||
The Cam Distoryer >:)
wouldn't it be possible, russ, to have a hyperlink that brings up a small amount of info when hovered over and then more when you actually click on it?
28-03-2011, 06:25 PM | #7 | |||
Cheers Russ
28-03-2011, 06:41 PM | #8 | |||
Cheers russ
28-03-2011, 06:48 PM | #9 | ||
can't do something like the add popup thingo's they have over here:
http://www.hotrod.com/techarticles/e...252/index.html
28-03-2011, 06:51 PM | #10 | ||
here is a wordpress plugin... not sure if it could be addapted or something?
http://wordpress.org/extend/plugins/hover/
28-03-2011, 06:54 PM | #11 | ||
http://www.autolinker.com/forum/content.php?21
cost's money but looks like it would do the trick... though looks like you would need to upgrade to vBulletin 3.7 (i have no idea how difficult or easy that is)
28-03-2011, 08:04 PM | #12 | ||
It's not perfect but if you hover your mouse over the expression in post 4 that is green and underlined you will see what I have implemented.
Cheers Russ
28-03-2011, 08:56 PM | #13 | ||
I've added a few more (as you can see in the first post) and am also gradually adding the common items from the acronyms technical reference.
Suggestions for other things to add are welcome. Cheers Russ
28-03-2011, 09:19 PM | #14 | ||
Great job Russ. Its spot on i think.
28-03-2011, 09:25 PM | #15 | ||
Awesome
Could you add ICC and ECU please Russ? I am always looking for what they stand for.
Thank you for implementing this so quickly! One very pleased member here Now I will be able to understand things a little better and not feel like a noob! (As my son says.) Edit: I see that ICC was already added.
28-03-2011, 09:33 PM | #16 | ||
Awesome
One little issue Russ.
I have noticed that one word is highlighting in sentences. Example: I asked him to look at it for me. Maybe him needs to be excluded?
28-03-2011, 10:04 PM | #17 | ||
HIM is gone given it is too close to him and the system isn't case sensitive.
I will add ECU. Cheers Russ
28-03-2011, 10:13 PM | #18 | ||
Is there a way to make it 'not' bright green? If at all possible?
----------------------------------------------------- 2012 Focus ST Tangerine Scream Continually having a battle of wits with unarmed opponents. Sez Photo's by Sez |
28-03-2011, 10:14 PM | #19 | ||
Just checking that part words aren't checked first.
Cheers Russ
28-03-2011, 10:15 PM | #20 | |||
Cheers Russ
28-03-2011, 10:16 PM | #21 | ||
Awesome
I think Blue would be good
28-03-2011, 10:19 PM | #22 | ||
blue is too much like hyperlinks though.
28-03-2011, 10:21 PM | #23 | ||
Well it's red with a blue underline at the moment!
Cheers Russ
28-03-2011, 10:31 PM | #24 | |||
And be thankfull that the only lucas parts on your car may have been the headlamps http://www.mez.co.uk/lucas.html Cheers again MD
HI I'M MICHAEL 2003 ACID RUSH BA FUTURA WAGON light up window switches | auto on cruise control | doubleclick window lift from remote Last edited by foxtrot3; 28-03-2011 at 10:36 PM. |
28-03-2011, 10:41 PM | #25 | ||
Awesome
Thanks for the laugh Michael. Very good.
I think Red is a good choice Russ. Stands out and when you search, words are highlighted in red so it kind of links it all together. Cheers Col
28-03-2011, 11:29 PM | #26 | ||
and it's not too harsh on the eyes! Thanks Russ!
29-03-2011, 12:15 AM | #27 | ||
Try
http://www.motorera.com/dictionary/index.htm and http://www.kmm-language.com/bookshelf_00000a.htm and http://carspector.com/dictionary/num/
regards Blue |
29-03-2011, 11:04 AM | #28 | ||
Awesome
Russ any word can be added yes?
I was thinking maybe you could put in OP. It took me ages to work out what that was. I know it is a forum shortcut but it would be good to add it. I suppose then you may have to add in IMHO and FTW. Perhaps not such a good idea then...
29-03-2011, 09:09 PM | #29 | ||
I've added OP along with honing and porting.
Cheers Russ
29-03-2011, 09:18 PM | #30 | ||
not here much anymore
TSB - Technical Service Bulletin
NLA - No Longer Available ONR - Obsolete Not Replaced BEM - Body Electronics Module BCM - Body Control Module PCM - Powertrain Control Module AFR - Air Fuel Ratio
2024 F150 XLT
