Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Furious Performance
Furious Performance Specialists in Automatic Transmission & Fluid Transfer Products Website Link
Closed Thread
Old 08-06-2014, 11:10 AM   #1
Furious_8
Sponsor
Lightbulb Furious Performance Ford Forum Shop...
Hello & Welcome,
This Thread is a dedicated Ford Forum Members page informing you of our great Furious Performance Products.
Each product can be bought through our website links and paid for using bank deposit or PayPal.
Thanks Rhys
*Fitting times are a guide only...
REGULAR TRANSMISSION COOLER KITS
Ford AU/BA Falcon Automatic Transmission Oil Cooler Kit (1998-2005 Radiator Cooler Transmission)
  • Extra Large PWR (255mm x 280mm x 19mm) Cooler with 10mm Push On Hose Connections.
  • 1.6m Length of 10mm ID hose Transmission Cooler Hose.
  • Stainless Steel Brackets to mount cooler in front of A/C Condenser.
  • Brass Fitting Adapters to Allow Full By-pass of Radiator so no cutting of factory Lines.
  • Fitting Kit with all Bolts, Nuts, Clamps & Instruction Sheet to allow for easy installation.
Price: $230 (inc GST) + Australia Post Express 5KG Satchel: $25 (inc GST)
Notes: Install Time 2.0 Hours for Regular Mechanic*
Will Need ATF topped up & Recommend having at least 1 Litre of recommended fluid handy...
__________________________________________________ ___________
Ford SX Territory Automatic Transmission Oil Cooler Kit (2004-2005 Radiator Cooler Transmission)
  • Fitting Kit with all Bolts, Nuts, Clamps & Instruction Sheet to allow easy installation.
Price: $ (inc GST) + Australia Post Express 5KG Satchel: $25 (inc GST)
Ford BF 6Cyl Non Turbo Falcon 4 & 6 Speed Automatic Transmission Oil Cooler Kit (2005-2008 Heat Exchanger Unit Cooler Transmission)
  • Two 1.6m Lengths of 10mm ID hose Transmission Cooler Hose.
  • Billet Male Aluminium Fitting Adapters to Allow Full By-pass of Factory Heat Exchanger no cutting of factory Lines.
  • Brass Heater Hose Joiner to allow complete removal of Heat Exchanger Unit.
Notes: Install Time 2.5 Hours for Regular Mechanic*
Ford SY Territory 4 & 6 Speed Automatic Transmission Oil Cooler Kit (2005-2011 Heat Exchanger Unit Cooler Transmission)
Notes: Install Time 3.5 Hours for Regular Mechanic*
Also fits turbo models with Factory Top Mount Intercooler
Please view this write up for more information www.fuitech.com.au/Ford Transmission Cooler Kit Installation.
Ford FG 6cyl Non Turbo Falcon 4 & 6 Speed Automatic Transmission Oil Cooler Kit (2008-ON Heat Exchanger Unit Cooler Transmission)
Notes: This kit is designed to suit Female End Factory Plastic Pipes however some base table top utes and XT falcons with 6 speed upgrade may have male end pipes.
Ford FG 6cyl Non Turbo Falcon 5 Speed Automatic Transmission Oil Cooler Kit (2008-ON Heat Exchanger Unit Cooler Transmission)
  • Billet Female Aluminium Fitting Adapters to Allow Full By-pass of Factory Heat Exchanger no cutting of factory Lines.
Price: $380 (inc GST) + Australia Post Express 5KG Satchel: $25 (inc GST)
http://www.furiousperformance.com.au...ans-oil-cooler
Notes: This unique kit is designed to suit Male Steel & Plastic Factory Pipes most commonly on the 5 speed but also rare 4 speed & 6 Speed models.
BRAIDED LINE TRANSMISSION COOLER KITS
Ford BF 6cyl Turbo Falcon 6 Speed Automatic Transmission Oil Cooler Kit (2005-2008 Heat Exchanger Unit Cooler Transmission)
  • Extra Large PWR (255mm x 280mm x 19mm) Cooler with -8AN Screw On Connections (with Temp Switch Provision).
  • Davis Craig Slim Line Fan with Temp Switch
  • Stainless Steel Brackets to mount cooler Under Drivers Side Head Light.
  • Two Lengths of -8 Stainless Steel Braided Hose with Speedflow Hose Ends Fitted.
  • Billet Aluminium Fitting Adapters to Allow Full By-pass of Factory Heat Exchanger and Connect Directly into the ZF Transmission Housing.
Price: $1309 (inc GST) + Australia Wide Regular Shipping calculated during checkout.
Notes: This unique kit is designed & Tested by Furious Performance.
Will Need ATF topped up & Recommend having at least 2 Litres of recommended fluid handy...
COOLER KIT EXTRA ITEMS
Silicone 90 Degree Heater Hose Joiner
  • Use this hose if removing Heat Exchanger Coolant Thermostat found on some Ford Territory.
  • Black 3/4" ID Silicone Hose.
Price: $21.34 (inc GST) + Australia Wide Shipping: (calculated at checkout)
http://www.furiousperformance.com.au/aeroflex-air-water-90-bend-19mm-0.75-silicone-hose
Notes: Please view this write up for more information www.fuitech.com.au/Ford Transmission Cooler Kit Installation.
AUTOMATIC TRANSMISSION FLUIDS
Valvoline MaxLife ATF
  • Recommended For 3 Speed C3, C4, C5, C6 & BorgWarner 35-51 Transmissions
  • Recommended For 4 Speed BTR (Falcon/Territory), AODE (Mustang), 4R100 (SuperDuty), A4LD (Transit), CD4E (Tribute), 4N27 (Focus), 4R55 (Explorer) Transmissions.
  • Can be used in 5 Speed 5R55 (Falcon/Explorer) Transmissions.
ZF LifeGuard Fluid 6 ATF
[LIST][*]Recommended Genuine Fluid for 6 Speed ZF6HP26/6R60 (Falcon/Territory) Transmissions.
Furious_8 is offline
Closed Thread
Thread Tools
Display Modes
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
