Old 17-06-2018, 04:44 PM   #1
DayTE
DayTE's Avatar
Default 2010 LV XR5T A/C problem
My partner has a Focus as listed above and we are having some A/C problems with it.
In Tassie we never noticed a problem with it, but since heading to NW Qld it is having a few issues. As in it cuts out under acceleration - gentle - and will not reset.
Hold on before you say condenser.
Here are some signs and symptoms.
Refrigerant level is ok. This has been checked, weighed out, weighed in. Pressures at idle were fine.
Fans are fine.
Filter on evap is fine. A little dirty, but not clogged by any stretch.
Condenser is not damaged or blocked. Spraying/hosing water over it does not help.
On the drive north we could only get it to run in 35+ temps on fan 3 and very gentle acceleration. If it cut out we needed to turn to A/C off drive for a bit then turn it back on.
Around town you need to cycle it on and off in between accelerating and braking to try and get it to run.
On a trip to the coast recently mid 20's to 30 deg we could only get the system to run on fan 4. But running in fan 4 it never cut out even under WOT acceleration.
When running temps are cold. As in below 10 deg cold, so when it does work it works reasonably well.
Anyone any thoughts??
2002 TE50 Build No 165
DayTE is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2018, 05:24 PM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: 2010 LV XR5T A/C problem
Sounds more like the ACPT switch. The unit has a self diagnostic function:
On the climate control assembly, PRESS the "OFF" and "FOOTWELL" buttons simultaneously for exactly 2 seconds, then PRESS "AUTO" within 1.5 seconds. The self-diagnosis which then starts lasts a few seconds. An animated display appears in the EATC display during this time. Any faults found are displayed on both displays in the form of diagnostic trouble codes.
Let us know what it returns (if anything).
Russ
Observatio Facta Rotae
Old 28-06-2018, 06:25 PM   #3
DayTE
DayTE's Avatar
Thanks Russ, I will give this a try in the next day or so.
Old 19-08-2018, 03:12 PM   #4
DayTE
DayTE's Avatar
So, it's only taken me two months to get to this, but I can't perform the test any way as the car doesn't have climate control only A/C. It doesn't have the required buttons.
And I can't find anywhere how to perform a self test on these systems.
