Old 08-12-2011, 04:00 PM   #31
blueoval
Critical Thinker
blueoval's Avatar
Default Re: Transmission Oil Cooler fitted on XR8 II
I personally think ALL AU's need a separate trans cooler fitted regardless of it's daily uses. They are far more reliable being bypassed from the radiator and they last a lot longer that way. I view it as a bit of insurance.
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
Old 08-12-2011, 05:07 PM   #32
AndrewR_AUII
AndrewR_AUII's Avatar
Originally Posted by rowan194
My AUIII I6 trans overheated today, after spending about 30-40 mins in very slow moving (mostly stopped) traffic, then 5 mins of 80km/hr level road, once I hit some moderate hills it started vibrating under load. I noticed the coolant temp was up too (around "M" rather than "O"), that came down quickly but the trans was still playing up, I guess because the oil holds heat better.
My question is... will a tranny cooler help in this instance, considering that there's no airflow over the stock setup or an aftermarket cooler when the car is stopped?
Would think that once stationary, coolant temp will creep up and fans will turn on..so airflow. Still to fit my cooler (went to do it and saw Radiator is weeping...so waiting for new Rad at the moment). But am thinking about how to fit a temp sensor to Trans cooler so that if Trans temp creeps up, it also turns on fans. Wiring diagram suggests that it is possible. If I get anywhere on this will post it up.
AndrewR_AUII is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2011, 05:11 PM   #33
blueoval
Critical Thinker
blueoval's Avatar
I have a large aftermarket trans cooler AND a heat exchanger (looks like another smaller but thicker radiator) cooling water in front of my radiator. I have the twin thermo's sucking air in as well as a smaller 10" Davies Craig thermo blowing air into the heat exchanger to help. The temp never gets over the O in normal regardless of temp outside.
Consider getting the radiator flushed and cleaned?
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 08-12-2011, 05:35 PM   #34
rowan194
Might have to. When I gave my cooling system a bit of TLC a few months ago this is all that came out of the radiator's drain port:
(The brown stuff dripping; the other water on the driveway is rain)
I gave it a good flush and also a couple of days worth of tap water with the heater on high but the drain port was still blocked. This is the first time I've had an overheating problem since I first noticed a slow leak a couple of years back, and the overheating in that case was because the coolant level had dropped. It's spot on right now.
rowan194 is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2011, 05:56 PM   #35
blueoval
Critical Thinker
blueoval's Avatar
A high pressure flush from a professional will get out additional blockages. They take the radiator out, remove the tanks and properly clean the cores and unblock all the galleries. Then put it all back together and refill it with fresh coolant. Doesn't cost a massive amount, but if its never been done in its life, it will be very beneficial considering you are getting over heating issues like you are.
A fresh change of thermostat is also worth doing for the cheapness alone while you getting the radiator clean done.
See how that goes first, then if it comes back, look at more expensive areas.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 08-12-2011, 06:05 PM   #36
rowan194
By the time you've paid labour costs to partially dismantle and clean, plus the new coolant, wouldn't it be worth considering just replacing the rad?
Does the old one have any scrap metal value?
Old 08-12-2011, 06:38 PM   #37
blueoval
Critical Thinker
blueoval's Avatar
Doubt it. If you are intending on replacing the rad though, don't just get ordinary replacement. Go copper core radiator. that way it shouldn't rust and corrode. A bit more than regular but lasts heaps longer.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
