Old 02-09-2006, 10:04 PM   #1
davidd5457
Default KF Laser - Make a smooth runner
My son's KF Laser (1.6 carb manual) runs on a little after turn off of igniton. It also "hunts" or "surges" when you back off and then put throttle on. It's a jerking sensation.
Any ideas??
davidd5457 is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2006, 11:06 AM   #2
VippiN
What a performer!
VippiN's Avatar
Checked the timing?
1981 Ford Laser KA :: E5 :: 2002-2003
1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW
1990 Ford Laser KF TX3 :: BP :: 2010-2011
1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW
2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW
1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020
2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-*
1998 Ford Falcon AU XR6 :: HP Intech :: 2021-*
VippiN is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2006, 01:50 PM   #3
M14A-Mclaren
Foo Fighter
M14A-Mclaren's Avatar
Sounds like it is dieseling. Could be timing as said, mixture problem, carbon build up or the carby isn't closing. Does it do it when it is cold? Try spraying some carby cleaner in there, see if it helps.
M14A-Mclaren is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2006, 11:05 PM   #4
davidd5457
Default Timing Mark Question
The timing was VERY advanced - so I adjusted it to the big timing mark - 3 or 4 notches from the bottom of the marking bracket. I thought this was 4 degrees. Is it the Top Dead Centre mark? If so, how many marks do I go "above" it to make the timing 4 degrees?
