12-10-2011, 05:54 PM | #241 | |||
They are a direct fit with an extra little pack you have to stick somewhere, I've got it stuck to the car, probably a bad choice but I've changed the globes from the low and high beams to the ones of the stock lights without having to remove it so should be alright. It's just as simple as 2 screws(one on each headlight) and 2 clips you push in with your screwdriver and out they come and direct swap with the plugs. The DRL's "work" but they aren't always on, you must have you lights set to the first on position, the DRL and halos come on at the same time then and are not amazingly bright, that's probably because they don't dim when you put on the headlights. I'll get a picture tonight of the light spread for you, I'll just do it up against my garage should be fine. The high beams are fine, but the lows are less than ideal I think, I'm going to be looking at getting a xenon kit for low beams and fog lights in the next few weeks, no stupid blue ones, just white ones so I can see better, also improve the look
2010 LV Focus LX Titanium Grey - K&N Apollo CAI - 2" Cat-back Exhaust -18" Black with machined front RS rims - DRL/Halo Headlights - Eibach prokit springs - Front Strut Brace - Black XR5 Spoiler Plans: Whiteline Rear Sway bar |
12-10-2011, 06:01 PM | #242 | ||
Barra Turbo > V8
Yeah i didnt think the light would be all that flash, hhmmm ill wait for your pics.
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
12-10-2011, 06:16 PM | #243 | |||
Also they look nice with the car compared to the bland chrome original ones.
12-10-2011, 06:24 PM | #244 | ||
Barra Turbo > V8
Yeah the chrome ones are horrid, at least mine has the black ones i guess.
12-10-2011, 06:35 PM | #245 | ||
Just remember not to go driving through any deepish water with that intake pipe down there won't you
12-10-2011, 06:55 PM | #246 | |||
12-10-2011, 09:28 PM | #247 | ||
Thanks for the pics of the Apollo, Conrad. Looks like my insulated cable bundle is thicker and more in the way for some reason, maybe because it's automatic. It also looks like you've got a very tight first bend in the hose.
I think I'm going to find a way of attaching a very short length of that hose plus the velocity stack to my shortened version of the stock intake. At least that'll give me a wider and rounder intake mouth.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. |
12-10-2011, 10:06 PM | #248 | ||
Yeah appears so! Under WOT I think it vibrates a bit in its current position, i'll keep adjusting it until it's good.
And yeah a very tight first bend.
13-10-2011, 11:02 PM | #249 | ||
Alright DJM83, hot off my camera.
My driveway is on a slope though so not the best angle it could be, just think of them a bit higher up on the wall if it were straight :P
14-10-2011, 09:25 AM | #250 | ||
Thailand Specials
Looks like a Halogen projector, awesome, where did you get em from and how much did they cost?
14-10-2011, 10:22 AM | #251 | |||
I've put in halogen Phillips 4000k bluevision bulbs as well just to get a bit of extra whiteness. $70 for them and came with parkers compared to $150 or so for a xenon kit and having the possibility of being caught with them being illegal(need headlamp washers for any kind of xenons to be legal)
14-10-2011, 11:54 AM | #252 | |||
Thailand Specials
The problem with Xenons is more that the aftermarket kits puts them in a halogen reflector which they weren't designed for, and this throws light all over the place, blinding other drivers. If its done properly with a HID projector which takes a lot of butchering of your headlight assembly and wiring modifications, you'd get an exact light cut-off like your halogen projectors. But I see this costing more than $600 haha. Yes the washers are also a problem, same with no auto-levelling system, but if its done properly I reckon you won't cause much fuss because you wouldn't be annoying other drivers. But yours look really good, can you get them without the DRL/angel eyes? |
14-10-2011, 06:40 PM | #253 | |||
All in all I like them alot, they look different and also are not just the bland chrome stock ones that come with it. Also goes with the black/grey colour scheme of my car.
14-10-2011, 06:52 PM | #254 | ||
I had to remove the air hose from my Apollo, noticed on my way home today there was a serious lack of go when I put my foot down, turns out because of the first bend I've got the inside has torn and was blocking half of it. I'll work something else out I guess, new hose and new elbow or something one day.
14-10-2011, 07:58 PM | #255 | |||
14-10-2011, 08:58 PM | #256 | ||
Barra Turbo > V8
Thanks mate, sorry for delayed reply after i hassled ya, been drivin back home.
Looks like a decent light spread now i dont think the UK Xenons are worth the hassle to be honest. Only reason i want them is because i like the factory look. I dont like the look of yours as much as the UK Xenons, but id still consider getting some as they are no where near the hassle compared to getting the Xenons to work.
14-10-2011, 10:05 PM | #257 | |||
For myself the only way to make it work would be to get a smaller diameter hose, which I think would limit much of the potential gain. My plan is to use the Apollo's velocity stack and 10-15 centimetres of its hose attached to my sawn off stock intake pipe. Hopefully it can rest just under the radiator cover, cable tied to the grille. Whether it's a good idea to have the hole facing forwards, I'm not sure, but I figure it's safer than having it poking through a foglight hole closer to ground level. And I'll work out a way of meshing the opening, anyway.
14-10-2011, 11:59 PM | #258 | |||
Thailand Specials
Just a bit of random information I have a Haynes manual coming for 2005-2009 Focus, be interesting to see what it covers. Last edited by Franco Cozzo; 15-10-2011 at 12:07 AM. |
15-10-2011, 01:37 AM | #259 | |||
oz built 308/315 - total 11490/11500 |
15-10-2011, 11:16 AM | #260 | |||
15-10-2011, 02:48 PM | #261 | ||
As seems to be usual with this car, I found less room than I hoped for the adapted Apollo intake hose (it's the bonnet locking mechanism, in this case), but this is what I've come up with. A bit ghetto, as the Yanks would say, and I'm not sure if it's too restricting of the radiator and/or going to be inclined to get hot. I'm also sure I'll have to get some more heat reflective tape than this electrical stuff...
Overhead shot without radiator cover in place. Side on, still no cover in place. You can see the mesh from a strainer. Cover back on. Black tape will be less obvious than silver tape... Any opinions? I'll be giving it a drive-test later, and if that doesn't show much, I may go back to the shortened intake or even the stock intake (I have a spare replacement snorkel), just to see whether it isn't as much worse as I imagine/remember.
15-10-2011, 03:06 PM | #262 | ||
You can call me Chris
Will it get any air on that angle? You're not having much luck are you!
'06 LS Focus Hatch -2 1/4" Lukey Exhaust -RDA Slotted discs/Greenstuff pads -Rear Whiteline swaybay -Lenso 18's w/Kumho rubber -Tinted Windows |
15-10-2011, 03:12 PM | #263 | ||
Ha ha, no luck. Well, the stock intake is aimed straight up at and under the radiator cover.
15-10-2011, 03:13 PM | #264 | |||
I myself am thinking of taking Russ' advice and making up some kind of PVC piping and having it go down to behind the side deflector next to the radiator and cutting a hole in that. I do like the idea of using the heat reflective stuff on it as well, might take that on, but I was planning on painting it bright green
15-10-2011, 03:39 PM | #265 | |||
15-10-2011, 04:05 PM | #266 | |||
15-10-2011, 05:58 PM | #267 | |||
15-10-2011, 06:17 PM | #268 | ||
Thailand Specials
I've got one of these coming:
http://www.european-parts.net/catalo...roducts_id=790 Lets hope it actually works with our cars LOL. It says it works with 2.0 TDCI, and MK2, but they don't reply to my emails, and Sascha from EP says it does. Be interesting. |
15-10-2011, 08:52 PM | #269 | ||
Well, it worked reasonably well. I didn't notice much at suburban speed, but the car was noticeably stronger up a hill that I go up regularly (improved torque, presumably). And today was warmer in Perth than it has been, so cooler ambient air is not responsible.
I took the car for an hour's drive, and gave it stick a few times. At the end, the intake pipe itself was remarkably cool still (and the tape and mesh hadn't shifted). The airbox was warm to the touch, and the throttle body hose was particularly warm, but still touchable; it looks like something that could use replacing, but it twists sideways and down to the standard airbox, so I'm not sure how easy it would be to substitute. All in all, no miracles were produced - nor expected - but I think it is an improvement on what I had, and definitely on the "naked" (hoseless) Apollo. I might remove the mesh, because it's not directly facing the grille (and potential stones etc), and before I installed the snorkel, I noticed by simply blowing through the mesh, down the tube and onto my hand that there was a noticeable reduction of flow compared to doing the same without the mesh.
15-10-2011, 11:32 PM | #270 | ||
Thailand Specials
I had a quick look at my front right tyre as I had it on full lock while parked, I noticed the very outside tread wear indicator is level with the tread, car has 15,000km on it.
Also with camber kit for the lowering springs, do I need front AND rear camber kits? Last edited by Franco Cozzo; 15-10-2011 at 11:41 PM. |
