20-05-2013, 07:59 PM | #211 | ||
Blue Blooded
20-05-2013, 08:05 PM | #212 | ||
Indeed it was i like my little trophy
I may finally have more Killerwasps than you if you havn't got forced induction yet lol |
20-05-2013, 09:05 PM | #213 | ||
Blue Blooded
20-05-2013, 09:25 PM | #214 | ||
Mustang GT mmmmmm......
Fitted BA GT-P rear springs to the XR6. Small difference but noticeable improvement.
Not as soft as before. Same as BF XR8 springs. 0.5mm thicker in wire diameter compared to XR6.
I have become a Mustanger. |
20-05-2013, 09:41 PM | #215 | ||
Now in the quad cam zone
not today, but i finished painting my engine bay yesterday
http://www.fordforums.com.au/showthr...267077&page=24
SOLD! "BARNEY" 2003 BA GT #332, Phantom, Boss 290, FR20 Simmons. XYZ Brakes - 355mm Rotors - 8piston Front Calipers & 4piston Rear More Mods soon!! |
2 users like this post: |
21-05-2013, 11:58 PM | #216 | ||
Put this on my back window:
It was taken on my phone in bad light so its hard to tell, but its that one way vision stuff. It cut out so much glare, and covered up all the scratches on the window, too. |
27-05-2013, 10:55 AM | #217 | ||
put new shocks in the VX and got my Historic Rego plates for the VH
CURRENT RIDES BA GT Mk1 #0009 - Narooma Blue SY Ghia AWD Black VZ LX8 Adventra Holden HX 50th Anniversary AU Saloon Car racecar 1980 GS1000ST - Wes Cooley Rep
27-05-2013, 10:57 AM | #218 | ||
Wrapped my dump pipe in Thermo-Tech 900* wrap which has done wonders for the under bonnet temperatures.
03 BA Turbo 6466 external gate Hi comp motor Built BTR 4k TCE stall FG inlet and exhaust manifolds |
27-05-2013, 11:24 AM | #219 | ||
Took my car to Willowbank after spending 4 hours adjusting the suspension for racing ... still laid a single pegger skid for 100m...
27-05-2013, 11:46 AM | #220 | ||
Call me 'Al'
Location: On a flattened-out cardboard box out the back behind the wheelie bins.
Spilt krill oil tablets all through it. Will probably be 'finding' them every time I clean it for a year
27-05-2013, 11:50 AM | #221 | ||
Put another TFI module on the ED to make it run , and I installed it and connected it with the ignition on
Fords are cool |
27-05-2013, 05:27 PM | #223 | ||
SY TS AWD LPG TEZZA
Washed and waxed my Territory. Now going to go and give the XF a bit of a clean.
1st car 75 XB Fairmont wagon 302C converted to 351C. 2nd car 82 ZK Fairlane 351C 4spd AOD LPG/Avgas 3rd car 97 EL Falcon police car 4L auto dual fuel 4th car 90 XF ute (work car) 5th car 06 SY TS AWD Territory Orbital LPi 6th car 95 XG ute 7th car 2014 SZ Territory TX Petrol Fords all my life. |
27-05-2013, 06:59 PM | #224 | ||
Got out the pressure washer and gave it a real good clean and degrease, rebuilt the starter motor, re-adjusted reverse gear, took 99% of the play out of the steering, pumped the tyres up and gave it a quick wheel alignment - goes like a brand new one now
Oh; that was my ride on mower |
27-05-2013, 09:47 PM | #225 | ||
Blew a quick $1150 on rego
29-05-2013, 05:01 PM | #226 | ||
Changed the bearing/hubs on my BA, put new pads in at the same time.
The hardest part was having to go shopping for a 36 mill socket for the retainer nut on the hub, had to go to a specialist tool shop. Ford wanted $190 per hub, genuine article off Ebay, $75, you do the maths.
jaydee351 4DV8 |
29-05-2013, 05:08 PM | #227 | ||
Retuned it on C16 race fuel .. went through 2x 25L drums at $12 a Litre Woooooooooooo
29-05-2013, 07:03 PM | #228 | ||
Taught my son how to change the oil in his BFXR6!!
01-06-2013, 10:56 PM | #229 | ||
Clevo power!
Killed it...
These straight 6's are pretty tough engines, but they don't like sucking water Drained the water out of the airbox, took the plugs out, cranked it, put them back in. It ran for a bit sounding very bad, metallic knocking/rattling noises then siezed. This was on the Central Arnhem road NT, waited about 2 hours till the 3rd car that came had a satellite phone (no phone service), called my mate, waited 2 hours for him to get to me. Then he towed me 2 hours back on the dirt road. If I was anywhere else in the country I'd just get another engine to drop in, but here it'd take ages and cost heaps to freight one in. So I'll just have to push it out to the tip... sad really, lots of perfectly good stuff on it. Anyone want any XH parts? Free, pick up only from Gapuwiak, NT!
The beast: XB coupe, 302, manual all the way! Fixing up thread The purple monster, daily BA XR6 turbo. Scale Lego Technic XB Coupe with working bits! Build thread |
01-06-2013, 11:05 PM | #230 | ||
Pulled the oil pressure sensor out of the au 5lt. Its decided to squirt about 4 litres of oil on the road on way home then oil light cam on. Its squirting out were the copper spade goes into the sensor. Changed air filter ,plugs,plug leads and cleaned throttle body out. Also picked up a parts motor for my hilux rock crawler truggy. Excitement all round
Sent from the family throne |
02-06-2013, 12:17 AM | #231 | ||
Lacking Imagination
hahaha... family throne!
Last night, i started putting the 5L Back together ready for the conversion.
My 11 Second AU Fairlane 364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W |
02-06-2013, 09:56 AM | #232 | ||
hmm eyebrows
Go the Windsor!! Is it going back into you Fairlane?
1999 Range Rover 4.6 V8. Soon to have a new blue oval bent eight. |
02-06-2013, 02:06 PM | #233 | ||
Lacking Imagination
yep, fitting it this week.
hopefully get the 6 out on Wednesday Night, and get it in thursday arvo / friday as i have a few things that need changing.
02-06-2013, 11:20 PM | #235 | ||
hey all new to the forums, got ba xt in winter white recently and just yesterday through in some lowered kingsprings and today gave it a detail while it was raining haha gonna hit it with a cut and polish once the weather clears up
02-06-2013, 11:38 PM | #236 | ||
Crappy day in Sydney today. Cold and wet, hate it.
02-06-2013, 11:41 PM | #237 | ||
Brad
Pulled rocker cover off and fixed oil leaking into spark plug wells and fixed belt squeal squeal.
03-06-2013, 12:36 AM | #238 | ||
Fairlane Ute
Installed a PS2 to the factory screen, just cause.
03-06-2013, 01:05 AM | #239 | ||
Lacking Imagination
Changed ABS Module ... only to find that a sensor is faulty lol
04-06-2013, 01:00 AM | #240 | ||
Washed it. Started to clay bar the car. Got about half way through.
GT 335 11.3@124.1mph 383rwkw/513rwhp Forced Performance Tuned |
