12-04-2011, 02:18 PM | #151 | ||
Torquer
To change the subject, I emailed European Parts to find out if they had an aluminium gear knob for the TDCi with lift up reverse and this is the response I got:
Hi please see here: http://www.european-parts.net/catalo...roducts_id=367 choose your correct version. Mit freundlichen Grüßen Best regards Sascha Mayer Extremely unhelpful I might add, the option I'm thinking it may be is the "6 speed with actuator". But what the heck is an actuator? I've tried googling and found zero. The knob would have to be a shorter version I image to leave room for the reverse lever, they are nowhere so I also think it may not exist.. Am thinking about the LED tailights as well, but not sure about what they actually look like.
2007 LT Focus TDCi S Bluefin Remap - K&N Apollo CAI - 2.5" Turbo-back Straight Pipe - 24mm Rear Sway bar - LT Zetec Bodykit - Black Projector Head Lights - LED Tail lights - DMB Overlays - Alloy Pedals - Scuff Plates - Sports Gear Knob - LV XR5 Springs - LV XR5 Wheels - Pirelli P-Zero Nero |
12-04-2011, 07:12 PM | #152 | ||
Thailand Specials
They werent too helpful when I asked about the Code:RED stuff, they have two things there for sale, the unit that plugs in through the OBDII port and flashes it, then some other one which plugs to the ECU i think.
Code:RED themselves didnt ecen reply to my email. Also we did the bonnet latch yesterday, what a total bastard that was. Has anyone here got a KN Panel filter on their TDCI? I'd like to do that for our next step to try compliment our makeshift cold air induction, lol. Last edited by Franco Cozzo; 12-04-2011 at 07:24 PM. |
15-04-2011, 09:43 PM | #153 | ||
Thailand Specials
Is our filter the circular one? I might order it from EP depending on shipping costs, also anyone know of a workshop in Victoria who fits and stocks diesel power moduals? They're remappable right? Not just a plug-in reflash like Bluefin and Code:RED?
I'm also interested in getting my hands on another airbox for some testing without butchering mine |
17-04-2011, 05:48 PM | #154 | |||
17-04-2011, 08:41 PM | #155 | ||
This is the cheapest I could find after a quick search.
http://cgi.ebay.com/ebaymotors/K-N-H...#ht_4080wt_952 I'm also interested in what people think of the Pipercross filter (this is the cheapest for this one after a quick search). http://cgi.ebay.co.uk/PIPERcgi.CROSS...#ht_1235wt_905
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. Last edited by In Focus; 17-04-2011 at 08:46 PM. |
17-04-2011, 09:02 PM | #156 | ||||
Thailand Specials
Thought you died ... only jk. Chicka, you also have the diesel power chip right? Hows that going for you? Also how much did it cost? Is that remappable as well? Quote:
Anyone here see any performance benefits from it or a better induction noise? Last edited by Franco Cozzo; 17-04-2011 at 09:08 PM. |
18-04-2011, 05:21 PM | #157 | ||
Torquer
Damo, with an exposed pod filter the intake sound is very loud and before the bluefin made about a 10% increase in performance as an estimate with a few other airflow adjustments. I think just changing the filter in the stock airbox will make little to no difference as it is extremely restrictive.
I've just ordered a Code:Red filter system, as my current setup is not actually 'Allowed'.
18-04-2011, 06:11 PM | #158 | |||
Thailand Specials
25-04-2011, 09:25 PM | #159 | ||
Thailand Specials
Was talking to a workmate today, we're thinking of trying to make our own airbox out of aluminium, anyone have rough dimensions of the factory airbox?
Also does anyone know how the factory airbox comes out of the car? Thanks much. |
25-04-2011, 09:48 PM | #160 | |||
But I came across an idea somewhere on the Interweb of getting reflective tape or something similar to attach to the surface of the airbox facing the filter. The idea being that it will reflect heat away that would otherwise be absorbed by the plastic. Worth a thought?
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. |
25-04-2011, 10:38 PM | #161 | |||
Thailand Specials
Obviously there is going to be somewhere for the air to get into the airbox (oops left that out) and the filter will be closer towards the pipe that goes to the turbo, baffles are going to be in there so that the air just goes from the intake tube right to the filter, rather than hit the edges of the box and eventually find its way there, it might only be a little bit, but every little bit helps I just hope without the factory airbox in there, it frees up enough space to do something like this. I might have to get a smaller pod filter to enclose in there rather than the big cylinder KN filter. |
25-04-2011, 11:07 PM | #162 | ||
big Damo
I think you are a mechanic. My TDCI at 50km/hr has steering wheel moving off centre an inch or so each way same around 70-80 yet at 110 km/hr its steady. I do have a couple of out of round tyres on it and balancing does not stop this steering play. Is the play a steering issue or is it just the out of round tyres causing this flutter? |
26-04-2011, 10:57 AM | #163 | ||
Torquer
I pulled out the factory airbox among other bits. It's quite simple, it's just screwed onto some mounting points around the edges. Take the cover off first and then go from there, my original filter was so dodgy I was surprised it was getting any air at all.
This is a pic with the cover off, I've since removed the whole box and the intake pipe.
26-04-2011, 05:13 PM | #164 | |||
Thailand Specials
As in steering to centre position but the car pulls towards left or right? Turbo Diesel, not much room to play with there, so there is no airbox there at all anymore? This is going to be challenging, tiny amount of room. |
26-04-2011, 06:42 PM | #165 | ||
Torquer
Nope, took it all out along with that restrictive intake rubbish behind the grill. The filter actually gets air directly from the front of the car now, not through a thin pipe from the engine bay.
There is actually a lot of space below the airbox, heaps in fact. That's why you'd mount a CAI vertically instead of horizontally. Don't know why you'd want to go through all that effort when there are plenty of good ones out there damo!
26-04-2011, 07:22 PM | #166 | ||
Damo
car doesnt pull either way just the steering plays/flutters an inch or two off centre- must be the out of round tyres? |
26-04-2011, 07:51 PM | #167 | ||||
Thailand Specials
I guess it might be tyres as I have the exact same car now and it doesn't do it. Quote:
Mainly just to be a bit different, plus we haven't seen anyone with the off the shelf items in their car yet (curious as to if LHD/RHD cars are different) and ease of installation. |
27-04-2011, 06:03 PM | #168 | ||
Thailand Specials
Bit of a setback today, replaced all my headlights and highbeams with Phillips Xtremevision +80s, except that the main beams seem to suck *** compared to the stock lights, I'll have to check if they're sitting in the housing properly and i didnt accidentally touch the globe.
There seemed to be dark spots and the lights would only illuminate about 20m in front of the car. |
01-05-2011, 12:19 AM | #169 | ||
I've had my TDCi for a few weeks now and I have to say I am very impressed with the way it drives and the economy is fantastic. I am getting from 5.5 to 5.7 average depending on where I go. I live in the country so about 95% is highway driving but when I'm in the suburbs I don't exactly take it easy on the pedals. I would recommend the Focus TDCi to anybody. Also my other cars have always been Falcons. And I still prefer to drive my Focus for economy and it's zippy in traffic too. The torque is brilliant when you hit about 1800 rpm.I got 850klms out of the last tank so it saves me about 40 dollars a week in fuel so it's definatly fuel efficient.
01-05-2011, 12:56 AM | #170 | ||
Thailand Specials
Thats good to hear, Kilmore ey, a local near me I also live in the Macedon Ranges.
I fixed my light issues, the globes werent sitting properly in the housings.... Oops! |
01-05-2011, 10:32 AM | #171 | ||
Shame about the log book 60000km service -$530!!!
Currently using the petrol focus on the 750km/week commute and tossed the TDCI at the wife who only does 400km a week round the suburbs.(to hold off paying the $530) TDCI doing 6.2 round town air con on a lot stop start very good, petrol focus did 8.8 on same work. However the petrol focus is doing 6.3 on the long commute not bad at all running on 95. |
01-05-2011, 11:56 AM | #172 | ||
Thailand Specials
Mines going in for its complimentary service tomorrow, lets see what they have to say about warranty and my driving lights. Or if they smash them off parking the car. If they do, I'm going to smash $600 worth of teeth out of their mouths.
I don't plan on servicing my car through Ford dealerships, I'm going to use my local mechanics who do log book servicing What I'll do is buy genuine Ford parts though. Whats involved in the 60,000km service? Look on the bright side, lucky you don't own a Honda, $700 services come every 40,000km |
01-05-2011, 03:16 PM | #173 | ||
I dont use Ford dealers-apart from the 3000km.
The 60000 service is a B service which occurs each 60000kms. extras over A service -Renew induction air filter element -Renew diesel fuel filter -Brakes-thorough check -ECU self test...? How does the independent non Ford guy do this? I use that fixedpriceservice.com.au website to check the guy I use is price competitive, I trust him so if he is within $60 I,m not fussed. I would rather have the car done right than have it done by teh cheapest and fail on the side of the road. |
01-05-2011, 06:02 PM | #174 | |||
Thailand Specials
ECU self test, if they have a scan tool, they just hook it up to the OBDII port and get it to check for any error codes and check that all systems fucntion correctly. |
10-05-2011, 10:05 PM | #175 | ||
Thailand Specials
Are the XR5T and TDCI intercoolers the same item?
14-05-2011, 10:02 PM | #176 | ||
Thailand Specials
Also noticed my window lock switch doesn't work, it won't light up or lock the windows when you press it.
19-05-2011, 07:25 PM | #177 | ||
Thailand Specials
Whats the go with the steering settings in the menu? I noticed it was set to comfort, does changing it really affect anything?
21-05-2011, 01:38 AM | #178 | ||
Hey Big Damo, which menu are you talking about? The menu you access with the left hand stalk, or some service techs menu?
21-05-2011, 09:46 PM | #179 | |||
Thailand Specials
22-05-2011, 02:04 PM | #180 | |||
2009 LV MkI TDCi Focus Hatch |
