24-01-2013, 01:41 AM | #1591 | ||
DJR Fan
Hi all, I read here every now and then, and a lot of very good info shared here.
I'm new to the solar family. I have a 5kw system - 5020w of Trina panels and a Samil Solar river 5200 dual inverter. Due to not enough north facing roof , I have some on the west roof too - 16 panels on north and 10 panels on west. I'm yet to see 5kw produced. About 4 is the highest. I do get a good spread of time of generation per day about 14 hrs of generation, probably due to having a spread of panels on north and west roofs. Do I fit more panels (plenty of space on the west roof) , like 6 kw worth of panels to get the 5kw from the inverter or this is normal as the panels are spread over 2 roofs. |
24-01-2013, 02:50 AM | #1592 | |||
Missing a sock...
My system has 2.3kW of panels facing NNW with a 2kW inverter - only a few times have I seen the inverter crack 1.9kW of output. You've got 3kW of panels facing the right way for peak generation, the others on the west side don't "see" the sun at it's peak the same time as the north facing ones do - hence why you don't see anywhere near close to 5kW generation. I would strongly suggest that you don't fork out your hard earned for any more panels on the west side. I don't know what state you're in, but in QLD you can't add any more panels to your system without penalties. Sit back and enjoy the system you've got DJR - it's very rewarding! On a happier note: I got the first non-power bill for summer. I used to hate summer, but not today. $565 credit for the quarter - Niiiice! Cheers!
Real friends + great times = sheer bliss! Considering becoming an organ donor? Click here QLD Events, Cruises and Get Togethers: Click here Gain success instantly - lower your standards. It's not government funded - it's taxpayer funded.
24-01-2013, 04:56 PM | #1593 | ||
Missing a sock...
DJR, forgot to add this:
You've got a 5kW inverter and 5kW of panels. Adding extra panels may exceed your inverters rating - on paper that is. Wouldn't matter if the additional panels are mounted under your house, it's illegal in all states to add additional panels that will exceed that your inverter can handle. In my case the inverter can take up to 2.5kW of panels (I have 2.28kW), but will only give up a max of 2kW throughput. You would have to consider what the max your inverter can handle before thinking about adding more panels. Probably not worth the expense mate, unless you want to fork out for another inverter? Cheers! Edit: Just done a quick google on the inverter you stated in your original post. Max input is 5.2kW - you can add one more panel before having to upgrade your inverter!
24-01-2013, 06:02 PM | #1594 | ||
DJR Fan
Hi Supershifty,
I wondering with having the dual inverter, if it could potentially go to 5kw on each bank. I thought I read or heard somewhere some time ago that you could have say 7kw, 8 kw,10 kw or more worth of panels, but the inverter will only deliver what the inverter is rated to. As I'm seeing 4kw max, I was wondering if I went overboard with panels could I bump up to the 5 kw the inverter could produce. At the end of the day, I probably wont do anything about it. This system should be more than enough for our needs. I haven't got a bill yet so naturally I'm keen to see what the rebate will amount to. Thats interesting that they will slug you for getting more panels, especially after the incentives for people to go solar and save the earth etc.... I'm in Brisbane too, are you with Origin or AGL? |
25-01-2013, 12:52 PM | #1595 | |||
Missing a sock...
Your inverter can only handle 5.2kW worth of panels - ie 27x190w or 26x200w panels. You have 26 panels, so you can only add one more panel to your string before having to go to a larger inverter. I think I get your logic when you say you're only getting 4kW peak generation and wanting to add extra panels to bring it up to 5kW, fact is that by law that the potential max output of your string/s may not exceed your inverters rating. When I mentioned about penalties in my previous post. I signed up when the rebates for feed in tariff were 44c, my system is alike yours where the string/inverter are pretty well matched, for me to add panels means I have to upgrade my inverter, upgrading my inverter means I lose the 44c and drop down to whatever the paltry sum is now. It's a complicated area to explain in a post as there is so many variables that apply to different circumstances. Here's a link to a faq that applies to QLDers that will help explain what I'm babbling about: http://www.cleanenergy.qld.gov.au/demand-side/323.htm I'm with AGL, recently switched from Origin as they were offering a better deal if I combined my gas/elec bills, in hindsight I was no better off. See my rant here: http://www.fordforums.com.au/showpos...&postcount=939 Hope this helps. Cheers!
27-01-2013, 11:50 AM | #1596 | |||
I cant remember the exact place I got that bit of info from but it was off the inter web .....info is everywhere and if you are real lucky it may actually be correct sometimes this is a good site to chase down a bit of info..... http://www.yourhome.gov.au/technical/fs67.html interesting that it states the orientation should be your latitude plus 15 degrees.......thats a very easy way to figure out the angle on another note I have just clocked up the 150th install that I have been involved in keep the info flowing fellers.....we all win in the end!
--------------------------------------------------------------- G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II... may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon! |
01-02-2013, 11:14 AM | #1597 | ||
a "new" energy comparison site has just got off the ground in South Australia that may be of some benefit to some
the site is found here w.energymadeeasy.gov.au/understand-your-bill-and-contract/comparing-energy-offers I havent checked the site out yet but according to Leon Byner this morning savings of 50% are not uncommon yes I know, I thought the same but the lady who stated this saving had done all her homework and checked and rechecked her figures anyhoo! would be worth a captain hook!.......may just save someone a quid if you do have a squizz would you report your findings and thoughts (good or bad) back in here please
01-02-2013, 12:24 PM | #1598 | ||
Rob
de regulation kicks in today for south australia, so there is probably a few good deals floating around if you search. more competition generally = lower prices.
01-02-2013, 12:27 PM | #1599 | ||
well hopefully anyway........I listened a bit to what Leon had to say but had to do a couple of deliveries and didnt hear all of it
possibly interesting times ahead...........or maybe not!!!
01-02-2013, 01:59 PM | #1600 | ||
Pethy FG XR8 Ute
ok guys i have been on the phone with the bloke who installed my solar and he is saying my system sounds like its running fine
ok its a 3kw system SMA SB 3000TL-20 with 15x 200w suntech panels STP200S/24AD 24V monocrystalline north facing roof with no shade ok i was told on here it was under performing as people with the same size system are making more that mine. mine its only making 16 units a day. the best i have seen is 16.7 since beginning September it was making 15 units and has only risen to 16 in Jan ...is this normal as its only risen 1 unit though there is more sun now ??? this is a good day and this is a day where its a bit cloudy why does it go from 2.136kw on a normal sunny day (its like this for heaps and on a cloudy day it jumps up to 2.367kw and on other days with cloud when the sun comes out it can get to 2.4kw ?? was wondering if these settings are correct and the couple missing are Min on time 120min (1-1440mins) opperation condition MPP System-Find device OFF any ideas as to all this is right or is this the max it can do
FG XR8 Ute 2010 Nitro, Mods so far: Herrod CAI, headers, Ballistic cats, Cat back Manta dual 2.5" with X pipe and hotdog mid section, Mellings oil pump, Summit racing 60mm twin throttle body, and Yella Terra plenum Powerbond 25% under drives, Sports bar, now fitted with Koya Inox R1's, the rears are 20x10 with a 40mm offset and the fronts are 20x8.5 with a 35mm offset total of 285.5 rwkw and 642nm when Herrod cams in 290rwkw GSXR 750K7 with goodies, dyno'd 136rwhp, 10.567sec for the strip |
01-02-2013, 02:05 PM | #1601 | ||
Pethy FG XR8 Ute
is there any way i can what each panel is making ..to see if they are making different out puts??
01-02-2013, 02:08 PM | #1602 | ||
you should see quite a bit of 18 kilowatts with the occasional 20 plus with a 3 kilowatt system.....but a number of factors come into play
north facing is ideal however what is the angle of your panels? a cloudy day will often produce more power than a bright sunny day.....I dont really know why,more reflected light maybe?.....where is professor julias sumner miller when you need him and his famous words "why is it so?" I cant give an accurate answer as to whether your system is setup correctly by those figures, thats one for the more technically minded I'm afraid, hopefully one will be along shortly to help you I dont reckon that is the max it is capable of.....I think it is holding out on you somewhere
01-02-2013, 02:10 PM | #1603 | |||
however touch the panels and you will void your warranty.....I wouldnt recommend it
01-02-2013, 02:17 PM | #1604 | ||
Rob
seems to drop off pretty quick in the arvo. by 5pm its down to under 1kwh already. i realise wa doesn't have daylight saving but on a nice sunny day here, mine will still be producing above 1kwh and close to 2kwh well after 5pm. admittedly mine is 3.8kw of panels so not comparing apples with apples.
it doesn't seem massively down but it does seem down. my 3.8kw of panels have seen peak outputs of 3.6kwh in the middle of the day. (who knows what it reads when i'm not looking at it, thats just the highest figure i've seen). |
2 users like this post: |
01-02-2013, 07:23 PM | #1605 | ||
Im in Mandurah WA and i average about 20kwh a day on a 3kw system. Pity i only receive 8.4c per kw back.
02-02-2013, 07:00 PM | #1606 | |||
Pethy FG XR8 Ute
what panels size and how many etc and inverter do you have
02-02-2013, 07:01 PM | #1607 | ||
Pethy FG XR8 Ute
oh and whats your max kw you get during the day
06-02-2013, 01:27 AM | #1608 | ||
We have a 6.9 kw system with 30 panels on a Nth facing roof at 27 degrees.
Our quarterly bill was around 450 to 500 dollars. With the dry weather in SE QLD for half the year we will make around $3500. The year before we got just over $3000. Thats a turn around of about 5 grand each year. Our system will pay for itself in less than 4 years |
06-02-2013, 02:12 AM | #1609 | |||
Too many Fords........ :)
Especially if there is no shade. It's almost like a couple of panels haven't been plugged in. Do you know what configuration the solar array is wired in?
Current Projects 97 EL V8 wagon - cool cruiser, or street bruiser? CLICKY 93 XG panel van - at your door in 60 secs, or the first hr is FREE........ yep, that's the goal. 95 XG ute - awaiting a head gasket...... grrrrr. 74 XB GS pano..... factory optioned with all the good stuff..... not much there now. ........long term resto. XB Coupe and Van TV Ad you know........ there's a little bit of Bathurst in every Ford Falcon.... think about it Last edited by SPArKy_Dave; 06-02-2013 at 02:30 AM. |
06-02-2013, 02:18 AM | #1610 | ||
Pethy FG XR8 Ute
2 lines of panels with 7 and 8 in a each row ..they are 200w suntech panels
06-02-2013, 02:34 AM | #1611 | |||
For 15 200w Suntech's to be on an SMA3000TL, which will be the single MPPT version (3000TL-20), you would have to connect the panels in three equal lots of 5 Panels. This would then require string isolation fuses on the roof, as over 2 strings will typically need that for reverse current diode protection. If the panels are connected in un-even strings to a single MPPT inverter, then the shortest string will drag the longer string down to its level. Akin to a charged and flat battery equalizing.
Current Projects 97 EL V8 wagon - cool cruiser, or street bruiser? CLICKY 93 XG panel van - at your door in 60 secs, or the first hr is FREE........ yep, that's the goal. 95 XG ute - awaiting a head gasket...... grrrrr. 74 XB GS pano..... factory optioned with all the good stuff..... not much there now. ........long term resto. XB Coupe and Van TV Ad you know........ there's a little bit of Bathurst in every Ford Falcon.... think about it Last edited by SPArKy_Dave; 06-02-2013 at 02:40 AM. |
3 users like this post: |
06-02-2013, 02:43 AM | #1612 | ||
Take a closer look at the panel wiring on the roof.
How many individual cables go into the junction box/rooftop isolator from the panels? You should be able to determine that, by feeling where they go into the conduit, and/or cable gland.
Current Projects 97 EL V8 wagon - cool cruiser, or street bruiser? CLICKY 93 XG panel van - at your door in 60 secs, or the first hr is FREE........ yep, that's the goal. 95 XG ute - awaiting a head gasket...... grrrrr. 74 XB GS pano..... factory optioned with all the good stuff..... not much there now. ........long term resto. XB Coupe and Van TV Ad you know........ there's a little bit of Bathurst in every Ford Falcon.... think about it |
06-02-2013, 04:59 PM | #1613 | ||
Pethy FG XR8 Ute
righto cheers mate but i wouldnt have a clue what they did
but i will have to wait till i get back home to have a look as i flew back up to work yesterday .. but will be climbing into the roof and having a look
07-02-2013, 12:22 AM | #1614 | ||
Delta Solaria 3.0 inverter and 12 x 250w Hareon panels. Max production throughout the day that I have seen is 2890w/h. Hope you can sort yours out mate. We might only get 8.4c per kw/h back but every bit helps.
07-02-2013, 11:08 AM | #1615 | ||
just one thing to add to sparkys advice (which is very good and gratefully accepted) is that if you do see something wrong don't go changing anything
we've had a couple of instances here where minor changes were made in simple wiring placement and this was used as a reason to get out of the warranty may be worthwhile to get a sparky who has a bit to do with solar to take a few readings to give a definitive answer
08-02-2013, 03:52 PM | #1616 | ||
Woah, this thread is still going!!
Been very grim as of late for Solar here in VIC, very very quiet for the last month..
DAS IT MANE
08-02-2013, 04:19 PM | #1617 | ||
G'dat Stagg......good to see you back......I don't reckon this thread will die anytime soon
there's a lot of folks out there who are sick and tired of paying high power bills and can see solar as a way to ease the burden a bit hopefully this thread is a way of getting some good info out there so as to make an "informed" choice of what to do
08-02-2013, 05:02 PM | #1618 | ||
I'm talking with our BDM next week and looking at a group buy for a plethora of different sizes for Solar PV for us VIC folk
i.e. 5% off every system for 5 orders, 15% off for 10 orders etc but will get something set in stone next week!!
DAS IT MANE
13-02-2013, 04:11 PM | #1619 | ||
Pethy FG XR8 Ute
welll i spoke the the installer again today
and he is telling me that my system is performing like it should be and me getting max 16odd units a day is normal i did ask him how he set it up and he said it was connected up in 5 panel lots (i fly home today so i will check it later) he doesnt believe people are getting 18 to 20 units a day out of 3kw system, just keeps saying they must have better panels etc he keeps going on about what the average system will do in a year blah blah i dont know what to do next
13-02-2013, 04:16 PM | #1620 | ||
Pethy FG XR8 Ute
hey Sparky ..what did yo umean by this
