Old 20-11-2006, 04:34 PM   #61
FTGAutosalvage
Commercial Sponsor
FTGAutosalvage's Avatar
Originally Posted by THORNSPAWN
With the engine on TDC one tooth will be on the sensor.
The trigger wheel has 3 teeth on one side and 1 on the other, it should be the center one on the side with 3 teeth that you'd need to leave if that makes sense.
yeah my thoughts exactly
FTGAutosalvage is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2006, 04:45 PM   #62
BlackLS
*Me looks for a AU Ex-Taxi*
Old 22-11-2006, 02:22 AM   #63
janek
Ripping it up
i've actually been looking at doing (or attempting this) for quite some time now. BA stockos are cheap, and the possibilities are huge... but i dont want to lose my sexy vct rocker.
*** for the ecu not being able to control vct? what about an au vct ecu? ( i know theyre sohc, but maybe it could be modified to control it?) and surely you can get a ba ecu and disable everything but engine management? the edit has been amazing so far, maybe it can do just a little more? the auto trans works on road speed/tps to determine shifts, not engine load/speed, so the auto box and the engine dont need to work (or just get a manual :P)
I'll definately be one of the earlier travellers down this route.. ive opened a new savings account and named it "engine fund" :P
and finally, how come the dual vct being disabled would cause flat spots/poor performance? I've disconnected the wiring to my vct, and the car just doesnt rev as hard, but performs well in any case...
food for thought
janek is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 09:30 AM   #64
bodes-sh
^^i think it was mentioned above...the dual vct, it seems, is also somewhat mechanical as well as computer controlled
Old 22-11-2006, 11:33 AM   #65
janek
Ripping it up
As is the SOHC VCT
its mechanically triggered, but computer controlled.
Old 22-11-2006, 12:07 PM   #66
Sapper
Back to the AU
Sapper's Avatar
Just a thought. With the idea of running a ba and au ecu to control different functions of the car/engine, would it be easier to simulate the unused components of the ecu rather than try to edit them out?
2001 Ford AUIII Falcon XR8 Manual - Can't get enough of the AU
2001 VW Bora V6 4Motion - If I squint it almost looks like a Sierra Cosworth
Sapper is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 12:44 PM   #67
Robe
For the benefit of the only non-tech AU owner here, me, please explain in simple terms why this story is generating so much excitement and interest.
Thanks
Rob Ewart
Bog standard silver BF Wagon, except for the Elvis doll , on gas.
Victorian Rock'n'Roll Dance Association
www.VRRDA.com.au
2015 Victorian Rock'n'Roll Dance State Championships
23 May 2015, Furlan Club, Thornbury
Robe is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 02:49 PM   #68
Dauphin
Irregular member
Dauphin's Avatar
I would imagine that the BA motor is more efficient with its power and fuel economy. Is it more valves per cylinder, double variable cam timing, etc? An evolution up from the AU VCT.
Old 22-11-2006, 03:37 PM   #69
janek
Ripping it up
exactly. and if the ba ecu can be used, ba turbo motors are just one step away.
If the dvct can be working, its the guaranteed cheapest 30kw you will ever get. Same reason why many people creamed (and still do) over the au vct... its just an extra bit of goodness into an already awesome car
Old 22-11-2006, 03:40 PM   #70
jonbays
TL40 Wagon?
Thanks
Well simply put the DOHC 4 valve head is the only real way to get more power out of the old six.
The BA head wont fit the E-AU series block so you need to swap the whole engine. Then theres the Engine management issues and engine accessories to worry about.
Bottom line you can spend thousands like me tuning up the SOHC engine to give 140rwkw or just buy a BA engine and fit it and you would have about the same and a nice new engine to boot.
Old 22-11-2006, 03:43 PM   #71
I6corp
Was V6corp
I6corp's Avatar
Then spend those thousands on the DOHC, and get even more power.
Car: 99 AU I Forte Sedan
Colour: Blue
Engine Mods: K&N Pod in a XR8 Pod Box; Performace fuel pump; 2 1/2" Exhaust
Planned Engine Mods: ; Extractors; Tickford CAI; Twin Mufflers; Shift Kit; Hi-Stall; Cam; ECU Flash
Bling Mods: Tinted Windows; JVC CD/DVD HU
Planned Bling Mods: TS50 Front; High Series bonnet; Rebel Skirts and Rear Bar; SL Springs; Clear Side Indicators; Rear Spolier; Mags
I6corp is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 03:49 PM   #72
dansedgli
dansedgli's Avatar
AU VCT and BA DVCT are completely different. I doubt there is any way to get the AU ECU controlling the BA DVCT properly.
BA conversions seem to be the new fad. Getting one to work with the stock ECU will be the real test.
My engine and box are already bolted in, waiting on my new intake and exhaust manifolds then Im an ECU away from having it all working.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 03:52 PM   #73
janek
Ripping it up
i'm sure the programmer savvy ppl out there will be able to do it
Old 22-11-2006, 06:10 PM   #74
Ford_V8
Has anyone successfully made this conversion and got everything running smoothly with an E-Series yet?
Ford_V8 is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 07:58 PM   #75
janek
Ripping it up
Doubtful... The au transplant is a new thing
Old 22-11-2006, 08:18 PM   #76
Casper
Contributing Member
Casper's Avatar
I believe its been done once or twice.. at massive cost.
Older, wiser, poorer.
Old 22-11-2006, 08:38 PM   #77
dansedgli
dansedgli's Avatar
With the BA ECU??
Old 22-11-2006, 08:47 PM   #78
Casper
Contributing Member
Casper's Avatar
no idea
Old 22-11-2006, 09:32 PM   #79
FTGAutosalvage
Commercial Sponsor
it can be done with the BA ecu with a lot of wiring , i spoke to capa a little while ago and they were talking about getting a wiring harness made that would make the whole thing stand alone. basically hook it up onto the ba motor plug the PCM in and a flash tune and bingo!
i havnt spoken to them in a while to see how its all going.
Old 22-11-2006, 09:35 PM   #80
dansedgli
dansedgli's Avatar
I sent them an email asking about that yesterday. Have to wait and see what they say.
What are the chances of getting a complete loom from you guys, Darren? Maybe it possible to dissect what is needed after some messing around.
Im nearly at the ECU stage now.
Old 22-11-2006, 09:47 PM   #81
FTGAutosalvage
Commercial Sponsor
it can be done , it has been done B4
you need to get the BEM and the HIM module, dash & engine bay looms , then cut them up and take out the required wires/plugs
i have sold a few conversions this way
i will phone Tony at capa tommorrow and see where it is going.(if i remember)
Old 22-11-2006, 10:18 PM   #82
EA2BA
PM me if you want
EA2BA's Avatar
stripping wiring apart and doing what people say cant be done, sounds like my projects ..... hahahahaha
Old 22-11-2006, 11:03 PM   #83
janek
Ripping it up
its possible, and at a reasonable cost, but the killer is time... when i get my beamer registered, ill rip into it... i think 6 months would be enough to iron it all out.
i'm thinking of getting the loom and bastardising it, then mounting it in the engine bay in a convenient location. but that mean i wont have easy access for editing...
ive got dozens of spreadsheets and plans oing on this...
Old 22-11-2006, 11:04 PM   #84
dansedgli
dansedgli's Avatar
Err why?
What is there to document?
Engine going in is easy. ECU a bit trickier.
Old 23-11-2006, 12:54 AM   #85
janek
Ripping it up
basically im trying to document it into as much of a step by step process as possible, to minimise my work and downtime. essentially im trying to get it done on paper then implementing thaat into reality... As you said the ecu is trickier
Old 23-11-2006, 09:07 AM   #86
EA2BA
PM me if you want
EA2BA's Avatar
exactley what i did for my 4 speed auto converision, did the whole lot on paper and worked out how to intergrate the 4 speed auto loom to the existing loom, and at the end of the day it went smooth and worked without much hassle.
Old 07-03-2007, 02:22 PM   #87
REDAUXR6II
REDAUXR6II's Avatar
Hey All,
Anyone got any new information about the BA transplant into an AU?
I would love to try and put a BA Turbo engine into my AU, has anyone tried this yet???
REDAUXR6II is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2007, 11:09 PM   #88
crusher
Dirty ute club member
crusher's Avatar
Very interesting reading.
Any updates on ECU? Whats the go with getting the DVCT working in the AU?
Would an aftermarket ecu like wolf, motec etc be able to run the DVCT and rest of the car?
Just interesting reading for now but later on...you never know.
2000 AU2 XLS Daily
1992 Toyota Celsior: 4ltr quad cam goodness
UZN106 Hilux: Absolute mongrel bitsa also with 4ltr quad cam goodness...Forced induction in the planning
crusher is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2007, 11:17 PM   #89
FTGAutosalvage
Commercial Sponsor
we have put in the hard yards, now its someone elses turn to do the fine tuning of the conversion.
Old 07-03-2007, 11:32 PM   #90
StookEB
If some one is serious about this maybe its time we brought BOG into this to give expert advice about the BA ecu's.
Now driving an unbreakable Hilux, which is becoming full of rust :
StookEB is offline   Reply With Quote Multi-Quote with this Post
