18-02-2013, 10:36 PM | #1 | ||
Came across this thread just a couple of days ago after searching on and off for a couple of years on any info about scanning my AU's.
My hat off to the folk willing to chase up these kinds of details and producing tools like FORscan and then sharing their knowledge with mere mortals like myself. That said, I've got trouble connecting both of my cars (AU I XR8 and AU II dedicated gas wagon). I'm using an ELM327 v1.5 and followed the instructions from FORscan as far as I can tell. When pressing the connect button, the screen comes up with Connecting to ELM, please wait... Connecting to vehicle, reading vehicle info... Then, after a little while an error box pops up saying: 'Unable to connect to vehicle. Please make sure the ignition key is ON and try again' Obviously, I had my igition set to ON, but no luck for both vehicles. Found a similar thing previously when I tried to get the thing connected via a hyperterminal (as detailed earlier in the thread and on another forum). After the atsp1, atshE4 10 F1, 13, it came back with an 'FB ERROR' when the ignition was on and with a 'NO DATA' with the igition off. Also tried 'atrv' and it spat back 12.0V so seems to be doing something vaguely useful. Read on other forums that the wiring sometimes gets mixed up on these ELM tools (mine's the usual cheap job from HK/China). Any suggestions as to what I'm doing wrong or what the problem with my ELM tool might be? Anyone in Perth that's got a working ELM tool I might be able to check with? So close and yet so far Cheers, Volker QUOTE=SilverT2TE50;4629451]I hear ya - we'd really only be entertaining ourselves it seems. It looks like FORscan is going to (eventually) release an Android version anyway... This is still a great thread though [/QUOTE] |
19-02-2013, 03:13 AM | #2 | ||
T-Series Club Member Vic
I got mine today and the only way I could get it to connect at all was to select 'auto' in both the com port selection setting and the com port seed setting. I managed to clear codes and display static values in the dashboard but streaming worked only momentarily before locking up with an error. I'll retread this thread and then try again - will post what I learn...
20-02-2013, 12:04 AM | #3 | ||
I had the same problem with an ELM327 v1.4 module that I bought a couple years ago - just gave NO DATA. There were a couple of wires switched around but I can't remember which ones - I accidently fried it while testing it after re-wiring (applied 12v to the OUTPUT side of the 5v voltage regulator on the board -- whoops). Bought a v1.5 and it worked fine out of the box... I also have a bluetooth one that works fine. Seems there are a few bad ones out there.
20-02-2013, 02:36 PM | #4 | |||
Thanks for that. Found this link which may be of some use:
http://forum.multiecuscan.net/viewto...ee3da2b57a702d I have no idea of how an ELM327 is meant to be wired, but in the absence of any other options, I'll open mine up and see if the instructions on the above thread apply. Cheers, Volker Quote:
21-02-2013, 12:18 PM | #5 | ||
Rusticating
Forscan is working for me too, on an AUIII, with an ELM327 USB adaptor. Worth noting that it (Forscan) had some issues that were solved by downloading the latest (very recent) version. In particular the car would stall after about 30 seconds while running the oscilloscope function at idle. Fixed now.
Trans temp appears under supported PIDs, but the value is always 'No'. I was thinking maybe it's a binary, as in overheated yes or no. But it sounds like a temp reading should be available. No biggie for me as I have a trans temp gauge, but it would be fun to compare the two.
Territory SYII RWD, BFII RTV tray |
21-02-2013, 11:38 PM | #6 | |||
Trans temp on the AU seems to be a weird one that isn't in FORScan (yet). You can get it by sending 22092C from hyperterminal. Returns two hex bytes, which are trans temp in degC. What temps do you see on your gauge, out of interest, and where is it plumbed in? Mine runs about 70 to 85 degrees C once fully warmed up. That's with the factory oil-to-water cooler plus a small external cooler in series. Before I added the cooler it ran about 15 degrees warmer. |
22-02-2013, 12:06 AM | #7 | ||
Rusticating
Fanboy my temps are similar to yours, though it will also stay in the 60s indefinitely if lightly loaded in cool weather. I have a large aftermarket cooler only - the radiator heat exchanger is bypassed. My pickup is on the pipe that comes out of the box to the cooler.
That hexadecimal stuff is too clever for me! Ya know, Forscan is open source, so why not apply your skills to improving that...?
06-03-2013, 05:58 PM | #8 | ||
subscribed- could someone also link me the correct plug i device im really keen to learn all this atm just a bunch of numbers
06-03-2013, 06:43 PM | #9 | ||
Formerly TassieTE50
Weekend Warrior 1982 XE Falcon, Atomic Green, 351C, T5 Manual, 18 x 8 18 x 9 Gold MC Racing Wheels On-Order 2016 Mustang GT est. delivery Feb. 2016
10-06-2013, 01:40 PM | #10 | ||
Hi Guys,
just letting you know that ForScan version 2 beta is ready for download. http://www.forscan.org/download.html I have,nt done a test on it yet cheers Keith |
10-06-2013, 07:11 PM | #11 | ||
Formerly TassieTE50
Had a quick 5 min play tonight. Seems much more stable (for the quick play I had).
When connecting, it recognizes that its connected to an AU and asks for what spec you have, basically either Low, Mid or High. If I get a chance this week I'll take some screen shots and put up. Matt
3 users like this post: |
12-06-2013, 02:39 PM | #12 | ||
I've just upgraded to the new version and had a play. It immediately seems more stable. I still had a few hiccups but for the most part it's very usable now.
I was able to run two of the self-test sequences, with only the key-on, engine-off test refusing to run. |
13-06-2013, 08:18 AM | #13 | ||
Yeah I tried the new version the other day. Real time data seems more stable (its able to recover from an error instead of locking up) and there are pids for the other modules now too like bcm and abs.
AUII XR6 VCT Ute 5Spd Liquid silver FG Mk2 G6E Turbo Petroleum 13.300 @ 106 |
13-06-2013, 09:31 AM | #14 | ||
Haven't downloaded the latest version as yet, but will do soon. Just thought I'd share my experience with the earlier version on the two AU's I've got:
1. AU II factory dedicated gas wagon. The software seems to work quite well on this vehicle, just drops out occasionally. Can read memory codes, KOER error codes, KOEO self test, KOER self test and live data seems quite stable. 2. AU I XR8: It recognizes the ECU and gives memory codes, but seems to drop out as soon as I turn on the engine. It's strange how it works well on one car and not the other. Could this possibly be caused by some wiring issues on the XR8 (the car runs fine otherwise)? Cheers, Volker |
13-06-2013, 05:56 PM | #15 | ||
I think the difference is the AU1 and AU2. I believe there are some differences between the OBD protocols.
BUILD AU II FAIRMONT GHIA HERS AU II Fairmont Ghia 7" DVD/GPS Radio 19" Wheels HIS FG XR8 Ute Lux Pack Tech Pack Touch Screen GPS |
20-06-2013, 11:34 PM | #16 | ||
The Dude
I'm trying on a 99 S1 xr6 using forscan and I'm connected to the vehicle but it says "cant identify the vehicle contact developer". any one had this message?.
21-06-2013, 11:43 AM | #17 | ||
The Dude
21-06-2013, 08:46 PM | #18 | ||
Formerly TassieTE50
I'm not sure but being an early AU maybe they are not compatible?
Has anyone else of this vintage managed to use the software?
23-06-2013, 12:44 PM | #19 | |||
EXR-699
I have the USB working with my series one AU Xr 1999 Use the Forscan software, set everything for automatic and it should be sweet I spent close to 5 hours in 40 degree day sorting this out. If you get stuck, PM me, i will try and help
Go Pedal = Fun Pedal AU XR8 Tickford 200kw Visit my Blog lovemyfalc.blogspot.com RIP - AU1 1999 XR6 VCT, Forever in my heart. |
22-06-2013, 03:26 AM | #20 | ||
It seems that it should work in the AU1 - the link below may help you
http://www.fordforums.com.au/showthr...+Tool+AU1+1999 cheers Keith |
27-06-2013, 12:04 AM | #21 | ||
POWAAHHHH!!!
Hey all u awesome elm scannerz...
Was wondering if best to buy the usb or bluetooth version? Also is FORScan free? Is it available as android app? Anyones input appreciated... |
28-06-2013, 07:31 AM | #22 | |||
Formerly TassieTE50
I have both Bluetooth and USB. I personally prefer the USB but that's just me. At this stage there is no Android/iPhone apps. Matt
27-06-2013, 10:32 PM | #23 | ||
Got Ghia?
an older version of forscan...
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold 2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers |
25-07-2013, 05:28 PM | #24 | ||
Lacking Imagination
I noticed on the 'LAUNCH' OBDII Tool that works with the AU's, that there is an option for Clearing KAMs.
I was wondering if anyone knew the code for this which i could use manually?
My 11 Second AU Fairlane 364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W |
17-10-2013, 04:21 PM | #25 | ||
Awesome thread and info. Just bought an ELM327 and with FORScan works perfectly.
However, is there a database somewhere with what the correct values should be for many of the PIDs? I'm trying to identify bad o2 sensors, and while I'm getting the readings fine through the live data feed off FORScan, I don't know if the readings are good or bad as I've got nothing to compare them to. Would be helpful for many of the other areas as well.
Current: 2000 AUII XR8 manual ute. 1966 XP Pursuit ute. 2012 Honda Euro manual (daily drive) Past: 1984 XE Falcon sedan 4.1L. |
17-10-2013, 07:37 PM | #26 | |||
Formerly TassieTE50
17-10-2013, 08:10 PM | #27 | |||
Auto Nerd
Normal narrow band O2 sensors will switch above 0.5v and below 0.5v in closed loop. The reason they switch is that the computer will adjust the pulse width of the injectors once it receives a signal from the o2. <0.5v equates to lean and >0.5v for rich. It switches from rich to lean in order to obtain the ideal stoichiometric. This would be the first sign of life when inspecting the o2. To check o2 response, pull a vacuum line somewhere. You want to see voltage drop towards zero. To check computer response, you will need to identify the signal wire of the o2. There will be 2 heater wires reading battery voltage and a ground that should be <100mv. This will leave the signal wire. By using a test light, jump battery ground to the signal wire to simulate a lean signal. You should hear a change in RPM as the computer tries to add extra fuel to the mix. Hope this helps. |
17-10-2013, 07:50 PM | #28 | ||
5.6L x 2 pilot
My guess without seeing the software or the hardware, is that this data you are seeking will vary between ECUs or families of ECUs. With my Quarterhorse tuning, I rely on a strategy file - which is effectively a memory map between the software and the ECU memory locations of each PID. Strategy files vary between the different ECU families, so my guess, no one database, if it existed will cover all ECUs and PIDs.
For the sake of $10, I have bought a ELM327 to check it out. I know my tuning software has the ability to report OBDII functionality which requires a strategy loaded. I will report back when and if I can find out more when my scanner turns up. Cheers Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
17-10-2013, 08:23 PM | #29 | ||
5.6L x 2 pilot
Great post Evgeni.
Further to that, I have read that the reason the ECU will swing the mix rich to lean is to maintain the functionality of the catalytic converters. They go rich/lean to maintain the oxygen levels outputted. The swing will only go rich or lean by about 3% from stoich. Those with a ELM327 and Forscan will see this in their Short term fuel trims at idle. Cheers Stu
17-10-2013, 09:15 PM | #30 | ||
Thanks heaps Stu and Evgeni.
My readings were between 1.7 and 1.74 in closed loop, so something's definitely a miss there by the looks. Way rich. I'll do the more thorough testing Evgeni suggested and stop hijacking this thread!
