Old 30-01-2018, 08:24 PM   #31
ivorya
Mad Scientist!
ivorya's Avatar
Default Re: Oil change
Originally Posted by rondeo View Post
Also in the present:
https://www.nulon.com.au/products/fu...ent-engine-oil
Check specifications and the cautions tabs.
Response this afternoon from Nulon Technical department.
"The clause for DPF is only for DPF's that don't suit the oil spec. This oil, suits your car spec, so it's ok to use"
ivorya is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2018, 10:10 PM   #32
NZ XR6
Sounds like they're even more confused than we are.
The basic problem is that Ford specify the wrong oil. It should be a mid-SAPS oil meeting ACEA C2 or C3, but instead they specify a petrol / non-DPF diesel oil.
Peugeot specify a C2 oil for the same engine in their cars.
The oil manufacturers are never going to go against the Ford spec, but I'd love to know what they really think.
I used to have regular DPF regens using the Ford recommended Castrol oil. I can't remember the last regen - maybe a year ago?
Sent from my SM-G9208 using Tapatalk
MB Mondeo TDCi wagon, sea grey, on MAK Invidia 16" wheels.
NZ XR6 is online now   Reply With Quote Multi-Quote with this Post
Old 31-01-2018, 10:46 AM   #33
Highway cruser
Just wondering how you know when it's doing a regeneration? As they don't have an idicator from factory. The guy that had my car previously fitted an led indicator that comes on when doing a regen cycle so I know every time mine does it.
Highway cruser is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2018, 10:55 AM   #34
NZ XR6
I can usually hear a change in the engine sound and the instantaneous fuel consumption goes up. At low speeds the radiator fan spins fast and is quite noisy.
I really should get an OBD2 adapter.
Old 31-01-2018, 02:06 PM   #35
rondeo
I don't see how high SAPs oil would cause more frequent regenerations, it's the soot from the fuel which blocks the DPF and has to be burned off; not the ash, which is incombustible.
My understanding was that the ash from a high SAPs oil would build up pretty slowly and DPF would just need replacing sooner.
I might give this a go next time:
https://www.fuchs.com/au/en/special/...c-2-sae-5w-30/
It also has the PSA approval.
rondeo is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2018, 02:32 PM   #36
Highway cruser
There are fuel additives that are designed to help clean the dpf. I've recently put one in and it seems to have reduced the frequency of the the rengeration cycles. It's suppose to put chemicals on the dpf that lowers the burning temp of the carbon or increases the burning temp when active. Can't remember which way round. The end result is,it's suppose to help clean the filter, which at the moment it seems to have done.
Old 01-02-2018, 04:16 AM   #37
NZ XR6
Maybe the diesel has improved? I nearly always use BP Ultimate, perhaps the additives actually do something?
All I know is that since changing to the Fuchs Titan ProFlex, the engine appears to have stopped doing DPF regens. It will be interesting to see what happens with the Penrite oil.
Old 01-02-2018, 04:19 AM   #38
NZ XR6
The DPF incorporates a catalyst to reduce buildup on the DPF and reduce the temperature needed for the regen.
Which additive did you use?
Old 01-02-2018, 04:24 AM   #39
NZ XR6
Old 01-02-2018, 05:56 AM   #40
Highway cruser
Think it was this one. http://www.supercheapauto.com.au/Pro...ae-Stop/347774
Old 01-02-2018, 02:28 PM   #41
ivorya
Mad Scientist!
ivorya's Avatar
Originally Posted by cobrin View Post
I use this one
I went a bit crazy last year and the year before so I now have thirty litres of the stuff and ten litres of the C-4 variant.
For your Kuga can you give the Spec's on the vehicle?
What's your technique on accurately getting the 5-6L oil out of the big 10L container?
Old 01-02-2018, 04:36 PM   #42
cobrin
Challenge Accepted!
cobrin's Avatar
You don't actually need to measure per se, a case of good funnel wide opening and outlet and pour directly from the drum. If the drum is full then it's opening is at the top (to avoid glugging) and rotate the drum as it empties. When within a good safe starting range I'll run it for 30sec, check the level and pour in to the upper level....donski
I work from the dipstick more than measured amounts, it's a tad more site specific.
Works well for me without any mess but you do have to be on the ball when pouring.
Had though about a drill powered pump but again more nonessential crap:
https://www.bunnings.com.au/craftrig...-pump_p6320813
Undecided replacement...
[SOLD] -2009 MB Mondeo Zetec TDCI- [SOLD]
cobrin is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2018, 07:24 PM   #43
ivorya
Mad Scientist!
ivorya's Avatar
Thanks.
I was thinking about getting this to help.
http://www.kmart.com.au/product/wate...-litres/725801
Removing the spray tip. Fill till 5-6L, just pour in.
Old 01-02-2018, 08:40 PM   #44
NZ XR6
Keep an empty 5 l oil container, fill it from the drum, and that will get you about half way up the dipstick. Top up from there after running the engine.
Old 02-02-2018, 08:27 PM   #45
rondeo
The watering can is a good idea.
Another good idea is a plastic storage box
to put the watering can in
otherwise you get insects and dust stuck on the oil.
I have been using a 2 litre measuring jug
1 litre a time (challenge: count to 5)
which has an open mouth
unlike an oil container.
I keep count with gravel
and fill to half way up the hatched part of the stick.
The upper mark means the maximum allowable
and the lower means the minimum.
The ideal is in the middle?
So 5 litres goes in and top up is usually about 250ml.
If the phone rings I look at the gravel
when I get back.
Old 03-02-2018, 02:38 AM   #46
cobrin
Challenge Accepted!
cobrin's Avatar
Well granted it is a safe working range and it's not like it's a hell of a lot more, but I don't know why you'd (not specifically you) not choose the top mark. With emissions standards as they are the oil is the new dumping ground, everything is being dumped in it, on top of lubrication and cooling duties.
Old 03-02-2018, 09:28 AM   #47
ivorya
Mad Scientist!
ivorya's Avatar
I've also seen this, http://www.supercheapauto.com.au/Pro...05040/SPO82384
which i've also seen at Gasweld for $21.
Might see if supercheap will match the price!!
Old 03-02-2018, 01:50 PM   #48
rondeo
$36 is a bit steep?
Looks good.
Opening size would be OK at 10cm plus
so no need to use funnel.
I keep a funnel, 2l jug and rag
in a plastic box.
As for the dipstick
On the max line
it's nearer to overfill
which theoretically means
higher crankcase pressure
and more weeping at crankcase seals,
unless crankcase pressure is regulated?
The difference between the min and max marks
I think is 1 litre.
Old 03-02-2018, 03:24 PM   #49
cobrin
Challenge Accepted!
cobrin's Avatar
it's still within a safe operating range, dont know why you think it means higher crankcase pressure and more oil leaks, it'll essentially be identical. Emissions systems keeps everything in check.
Old 03-02-2018, 04:18 PM   #50
rondeo
The owner manual suggests
keeep the oil level between the limits.
Surely the best approximation to that
is the middle.
I could be wrong
about the crankcase pressure,
if two pistons are going up
and two are going down
at the same time
it shouldn''t make a difference.
Anyway, can't do much harm
I've done that for the last 40 years
without problems.
Or am I a tad obsessive?
Now that I think of it
isn't it just as obsessive to put it at the full mark?
Old 03-02-2018, 04:28 PM   #51
Highway cruser
Crank case should be at atmospheric pressure or very close to it. The crank case is connected to the inlet before the turbo so any blow by can be recirculated back into the intake. If the motor is in good order there should be little to no oil or blow by. If the crank case is being pressurised then there's an issue.
Old 05-02-2018, 04:30 PM   #52
NZ XR6
Well, that didn't take long - regen on the motorway today. I'll reserve judgement as the car has done mainly short trips since mid-January, but this is not a good start.
Old 05-02-2018, 05:51 PM   #53
Highway cruser
Having the led indicator on the dash I know that mine regens about every 80-100km on the high way. Not having done an oil change on it yet, but knowing that the previous owner used valvaline synpower fe I don't see that would be out of the way. I would expect that the fuel would contribute far more to the regen frequency than th oil. At the end of the day if oil particular matter is clogging the dpf then that would indicate that the motor is burning the oil. As far as I know modern motors don't normally burn that much oil. If the motor is breathing heavily then this would increase the amount of oil being burnt, however I don't believe these motors breath that heavily. I also believe that the 2.0L level 5 immissions motors have an oil separator built into the crank case breather system which should remove the vast amount of oil going back into the intake system meaning virtually no oil is being burnt.
Old 05-02-2018, 06:13 PM   #54
Highway cruser
I've just checked on the specification on the valvoline synpower fe, and while is designed specifically for these motor's and the ford standard it doesn't state that it's dpf safe. This seams to be a case of meeting the requirements for ford but not Peugeot. They do an Env c-2 as well as a mst c-3 which meet the Peugeot requirements and are dpf safe. So depending on cost I will also look at these as an alternative to the Penrite.
Old 05-02-2018, 09:56 PM   #55
cobrin
Challenge Accepted!
cobrin's Avatar
They all do, MA MB and MC have oil/air separators.
Old 06-02-2018, 02:04 PM   #56
rondeo
I bought one at Total Tools for $24.
http://www.tridon.com.au/products/To.../428375/305040
Almost perfect! Can be capped at both the filler and the spout to keep bugs and dust out during storage.
Re regens I think mine does at around 350km intervals, used mainly at 100km/h.
Engine uses hardly any oil between changes, no need for top-ups.
Using Nulon C3 changed at 15000km.
Done about 170000km each on two cars
Av fuel 6.2-6.4. Some fuels not so good- 6.7.
No mechanical failures except turbo vacuum solenoid on both cars. $100 each.
Old 06-02-2018, 07:16 PM   #57
NZ XR6
That’s a lot of regens. I’d encourage you to use a good C2 or C3 oil and see if it changes.
I could not believe how much difference the Fuchs Pro Flex made - no regens and about 5% better fuel consumption. I suspect I will end up changing back to it.
Someone else here has mentioned that the oil shouldn’t affect regen frequency. Sorry, but my experience for the last year is that it does.
Old 06-02-2018, 08:25 PM   #58
ivorya
Mad Scientist!
ivorya's Avatar
I ended up buying the Nulon 10L C3 and used a cheap 1L container to transfer the oil, bit cheaper. Just happy now that i have a dedicated Diesel oil in the engine and to know that many are using this oil without issues.
Thank you to everyone for supplying lots of knowledge in this area.
Old 06-02-2018, 08:27 PM   #59
ivorya
Mad Scientist!
ivorya's Avatar
Hey NZ,
Have you put the C4 Penrite in your engine yet?
Any noticeable changes? Nosier, economy, regens etc?
Old 06-02-2018, 09:51 PM   #60
Highway cruser
As I've only recently brought the car and haven't serviced it yet, when I do in about 2,000km I will be using either a C2 or C3 oil. It will be interesting to see what effect it has on the regen cycles.
