20-06-2012, 11:34 AM | #31 | ||||
Solution Was Boost 4?, 6 & 8
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW |
20-06-2012, 11:51 AM | #32 | ||
KenneBell Australia
great time bud, car sounded strong all day.
Chris
Bluepower Racing Developments Proud Australian Distributors of Kenne Bell superchargers The Quickest, The Fastest, The Baddest Boss Blower of all. www.bluepower.com.au |
20-06-2012, 12:48 PM | #33 | ||
[QUOTE=SpoolMan]Ivan remove the hardcover and it may get you there, 50kg easy in the hard cover..
My hardcover is actually very light, I've had it off a few times, I would say about 10kg, the tailgate I havnt tried, and i believe that may carry quite a bit of weight. Will take the weight off once my personal goal is reached (10.5x).
Daily driven workute....10.33 @ 136mph
Gtx3582 Stage 2 Nizpro kit. HEADSEX TUNED |
20-06-2012, 12:50 PM | #34 | |||
20-06-2012, 02:08 PM | #35 | |||
[QUOTE=xr6t_ute]
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW Last edited by SpoolMan; 20-06-2012 at 02:15 PM. |
20-06-2012, 04:54 PM | #36 | ||
Maybe not worth the trouble then... see how i go.
21-06-2012, 12:53 AM | #37 | |||
21-06-2012, 10:59 PM | #38 | ||
Slicks were alot cheaper for me, got them for a bargain off a forum member.
21-06-2012, 11:19 PM | #39 | |||
22-06-2012, 11:01 AM | #40 | ||
What oil are you using in your BTR?
Also how firm do you have the shift set for street use? Do you use a external tranny cooler? Cheers Matt |
22-06-2012, 11:49 AM | #41 | ||
Not sure on the oil, whatever Bayswater transmission use, pressures on the 4 speed is pretty much at its limit, the changes are very firm and quick, its like that for street and strip.
I have an external cooler setup in front of my foglight, its been there for 4.5 yrs. Heres a vid of my 10.63 run. http://youtu.be/ZxO3FypP400
23-06-2012, 12:04 AM | #42 | |||
[QUOTE=xr6t_ute]
Toolkit 4.6kg Spare wheel 23.5kg Tarp and supports 3kg Spare tyre mount 2.8kg Tailgate liner 2.5kg Tailgate 15kg Tray liner 18.2kg Tub 132kg Tub braces 4.4kg |
23-06-2012, 09:37 AM | #43 | ||
Bolt Nerd
Wow.. some impressive weight savings there for utes.. Interesting!
Spooly, when you emptied out your yellow F6 did you weigh all the stuff you took out?
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4 Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD 2 wheels.. 2015 103ci HD Wideglide.. SOLD SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida! (Ex Blood Orange #023 FPV Pursuit owner : ) |
23-06-2012, 09:55 AM | #44 | |||
light weight wheels, exhaust and front seat are the big weight losers, the after market stereo I wasn't going to remove (only the sub). Rod could have went further eg: door motors, aftermarket stereo, door trims etc, but it has to go back together. Remove the weight from the axles its worth double, the OP's Ute was on steel rims so weight wise this is worse than the factory alloys and he can improve on this time if he can loan a set of drag lites..
[SIGPIC][/SIGPIC]
23-06-2012, 11:32 AM | #45 | ||
Bolt Nerd
Yep.. unsprung weight, so removing the brembos too
23-06-2012, 12:21 PM | #46 | ||
I thought it was the other way around. My factory steel rims are lighter then my factory alloy rims. Talking 16 inch rims the alloys are also wider then the steel rims.
Must be different weight factory alloy and steel rims due to size etc. You could also look at removing the handbrake drums or what ever they are called. |
23-06-2012, 07:28 PM | #47 | |||
23-06-2012, 07:56 PM | #48 | ||
There is 43lbs to be saved going to 15 x 6 prostars and 195/65r15's on the front. Another 50lb changing from leather seats to Jaz'z
Mine is under 1500kg, now I just need your power |
23-06-2012, 08:04 PM | #49 | ||
Getting it to 1500kg is pretty good going. You dont need much power if youve dropped 300 +kg.
23-06-2012, 08:42 PM | #50 | ||
You always need "much power"
24-06-2012, 12:47 AM | #51 | ||
Yeh and power starts costing alot more than you anticipated..lol, and ends up being like a piece of string, how far do you want to go? When are you going to be happy enough with the power you have?
24-06-2012, 11:49 AM | #52 | ||
slicks are lighter than radials also, we went from a 28x10.5'' slick to 275 MT ET Street we seen about 6kg difference each side.
24-06-2012, 12:20 PM | #53 | |||
24-06-2012, 01:32 PM | #54 | ||
24-06-2012, 02:58 PM | #55 | ||
I swapped over calipers with the guy I bought the rims off, saved me a few hrs grinding and trying the wheel on.
26-06-2012, 03:34 PM | #56 | |||
Brisxr6t
Peddle car with racing stripes E.T 10.85 @ 124 |
17-11-2012, 02:47 AM | #57 | ||
Went to Calder tonight.. New Pb 10.44 @129 stock turbo
17-11-2012, 06:47 AM | #58 | ||
Well done again Ivan heard you did a 1.4 60ft??? If so that's impressive in a heavy leaf sprung ute!! Gives me some hope of do it!!
blueprint ba turbo ute,powerglide, Old set up -9.9@140 1.57 60ft 720rwhp New set up 1003.4rwhp yet to be run! Tuned by Forced performance and tuning. |
17-11-2012, 10:24 AM | #59 | ||
Very nice ! That's cranking for a streetcar
1998 AU VCT Ghia - Stock as a rock - Wifes car 1991 Toyota Soarer TT - 11.72 @ 116.7mph 2004 Ford Escape XLT V6 - Family Ride . |
17-11-2012, 10:44 AM | #60 | ||
RNS10S
