Old 09-10-2006, 11:19 AM   #1
white_XR8
Cool Au Xr8 Engine Cover Fit in EL engine
Would an Au xr8 Engine cover fit onto a EL XR8 engine? What kidna of cutting and manipulation be needed to make it happen, does anyone Know of anyone that has done this before ?
white_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2006, 11:35 AM   #2
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
It will fit, but you need to find a new mounting point up the top of the engine, as there is a plate that says 5.0L on the top of the intake where the four allen key bolt usually go..
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2006, 12:22 PM   #3
white_XR8
Will it fit straight on? Is there any cutting involved ?
Old 09-10-2006, 01:13 PM   #4
Christiaan
Christiaan's Avatar
i THINK the bottom 2 holes line up with the cover. There could also be issues involved with the top part of the cover hitting the EGR stuff, as AU's didn't have it.
Old 09-10-2006, 02:21 PM   #5
Kenaz
Kenaz's Avatar
Could be alot of messing around, but the result would make it worthwhile. The E-series 'BBQ Plate' engine covers are pretty craptastic.
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2006, 04:29 PM   #6
Psycho Chicken
Psycho Chicken's Avatar
I've got one here, doubt it'll clear the EGR. You'll need different brackets up the front.
Psycho Chicken is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2006, 06:52 PM   #7
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
The AU one mounts to the manifold differently, and the AU one won't clear the E-Series dizzy and coil, as well as all the other reasons above.
Engine covers are for poofs btw :P
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2006, 07:40 PM   #8
Psycho Chicken
Ah coil, that's why mine doesn't want to fit properly. Meh.
Old 09-10-2006, 07:40 PM   #9
XR_Lightning
Riding The Lightning
XR_Lightning's Avatar
yeah theyre damn ugly arnt they, anyone ever seen a painted cover or a custom one, that looks better than the stock one?
ED XR6 - T5 - 1521a@112 - 3.9's - 170.2rwkw - POWERED BY METALLICA
XR_Lightning is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2006, 11:00 PM   #10
Stevo
not as ugly as the engine underneath it! even a plastic bag over that engine helps with asthetics.
there are heaps of painted/chromed/chopped covers around. some look good (if done well, and not painted weird colours)
Heritage Green EL Ghia
Black AUII XR8 Ute
Stevo is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2006, 11:04 PM   #11
XR_Lightning
yeah your right, taking the top covers off the engine isnt much of an improvement
Old 13-10-2006, 12:33 AM   #12
Psycho Chicken
Bump bump bump.
Are you talking about with the HO manifolds? I test fitted mine today now the clutch fan shroud is gone and it seems to clear the dizzy on coil fine. The coil bracket will need a bit of modifying for a perfect fit, but it fits.
Well, it fouls on the thermo fans, but a bit of hacky hacky will fix that. And I didn't have a snorkle on.
Old 30-10-2020, 11:20 AM   #13
bigwil
Default Re: Au Xr8 Engine Cover Fit in EL engine
My EB XR8 is missing the engine cover I'm thinking of getting an engine plate off a AU 5litre and just replacing the engine plate, my question is is it a straight swap will it all line up , ive seen on ebay plain plates which look ok but I prefer the AU because of the 5 litre printed on the plate
bigwil is offline   Reply With Quote Multi-Quote with this Post
