24-09-2023, 06:51 AM | #1 | ||
Easiest way to explain is when the car got warm - half way through 'normal' - car started to lose volts. I've never had this happen before and it's got me stumped. I will ad that if I pull over, put it in park and give it a small boot full the volts kinda/sometimes come back up, and has only done so when actually driving,
Cars a NL Fairlane 4L |
24-09-2023, 08:00 AM | #2 | |||
Cabover nut
I've had all of the above happen.
3 users like this post: |
24-09-2023, 08:19 AM | #3 | ||
No point guessing. Charge the battery and load test it.
24-09-2023, 08:19 AM | #4 | |||
Not sure how else to explain it, if I start the car and let it idle to maintain the battery not a problem. But the last two times I've taken the car out when it gets to the M of 'normal' it starts to lose volts Should add that when the car just idles it barely gets to the L of normal |
24-09-2023, 08:21 AM | #5 | ||
24-09-2023, 09:17 AM | #6 | ||
So you have no access to anyone with a proper load tester, nor intelligent battery charger?
“Earth” is a somewhat unhelpful address for someone requesting assistance that may include location-based suggestions in its best form. |
24-09-2023, 09:30 AM | #7 | |||
( just trying to say there's a lot of them) I put the battery back in the car before and started it, not a problem but it barely got warm |
24-09-2023, 09:51 AM | #8 | ||
24-09-2023, 10:13 AM | #10 | ||
24-09-2023, 10:17 AM | #11 | |||
I couldn't remember where I seen /found it |
24-09-2023, 10:25 AM | #12 | ||
Experienced Member
Could be alternator or its regulator, pay to get an auto elec to test it.
24-09-2023, 10:28 AM | #13 | ||
24-09-2023, 12:49 PM | #14 | |||
Cabover nut
Did you say you only use the car twice every 2 weeks or so, I reckon unless you take it out on a reasonable long drive to charge at around 14.4V, the poor battery will be going through some stress constantly kept on a float charge.
24-09-2023, 02:07 PM | #15 | ||
Experienced Member
5 users like this post: |
24-09-2023, 03:55 PM | #16 | ||
Does the high pressure power steering line leak - if so the alternator is chock full of power steering oil and its eaten away the brushes and copper slip rings on the alternator and now its ****ed.
Get a cheap multimeter, put it on 20V DC, Start the car, Put the probes on the positive and negative terminals on the battery, you're looking for 13.8-14.4V, Then turn on all your electrical accessories - the headlights, HVAC fan on full, AC, wipers, stereo, and see what the voltage does. If it starts dropping, and it goes down to sub 13V, then the alternator is cactus and its not holding up under load and needs to be replaced. If it comes off looking like it come from the titanic, the power steering line is leaking into the alternator, you MUST replace it with a new one before doing the alternator, or 6 months later you'll be buying a new alternator again. |
26-09-2023, 09:34 AM | #17 | ||
After finding my brother's multi metre, with the car not running 12.56, after starting the car it was 14.6 but quickly dropped to 13.8 when the motor ' spuddered' ( kinda miss fired) then slowly dropped to 13.5 over 10 mins or so. I had no electrics on, besides when the thermos kicked in ( made .01 volts difference)
26-09-2023, 11:57 AM | #18 | |||
26-09-2023, 12:41 PM | #19 | |||
26-09-2023, 01:07 PM | #20 | ||
Sick Puppy
Sounds like a fingered alternator to me........
26-09-2023, 02:04 PM | #21 | ||
26-09-2023, 02:12 PM | #22 | ||
26-09-2023, 09:27 PM | #24 | ||
So your closest option for an auto sparkie is Kingaroy; I can see that probably limits your choices to just a couple.
https://www.sptools.com/product-cata...tometer-clone/ We have one of these at work, in honesty it’s pretty good for a quick guess. Quite possible that the mechanical shops in town will have similar or the same. A sparkie should have a carbon pile load tester, this really puts a battery through its paces but being a more specialised item priced into the high hundreds, it’s kind of reasonable to charge people for the results it gives. https://www.projecta.com.au/products...on-pile-tester |
26-09-2023, 09:51 PM | #25 | ||
a decent mechanic involved with RACQ could also assist
26-09-2023, 10:34 PM | #26 | ||
27-09-2023, 08:01 AM | #27 | ||
27-09-2023, 08:06 AM | #28 | ||
