Old 05-05-2018, 01:15 PM   #1
Vortex-98
Vortex-98's Avatar
Default My AU dash light came on...wats it mean
I jumped in the car today an noticed a light on ..I've never seen it before an don't know what it means,it's like a box with a fan in it??
It's on the left side third from the top...in the rows of lights left an right of the Speedo.
I don't think it's low on water light ..that's the water spray looking light down the bottom
[B]WTB (Syd)...AU 5.0 or xr8 4 speed auto transmission in good working cond /B]
Vortex-98 is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2018, 01:59 PM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Smile Re: My AU dash light came on...wats it mean
in a high series cluster it would be the
low engine coolant level warning light
so check the coolant level
uk
Old 06-05-2018, 01:43 PM   #3
Vortex-98
Vortex-98's Avatar
Default Re: My AU dash light came on...wats it mean
I topped up the coolant so it's full...I started the car an let it circulate put cap back on an took it for a run....damn things still on...is there a reset button or something
Old 06-05-2018, 02:11 PM   #4
bawagon2012
Same issue currently on my AU XR8, I think its just a faulty coolant level sensor.
bawagon2012 is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2018, 05:32 PM   #5
11ford11
common fault was the coolant sensor at bottom of overflow bottle - pull plug and bridge connection and recheck light....
Old 06-05-2018, 06:55 PM   #6
Vortex-98
Vortex-98's Avatar
Will do thanks man...hope that's all it is
Old 07-05-2018, 10:21 PM   #7
Vortex-98
Vortex-98's Avatar
Yer walked out today an checked to see if that light was still on ...yep sure was
So I unplugged the lead ..wiped it a bit an plugged back together an BAM...problem was fixed ..no more light..
