Old 24-04-2014, 02:25 AM   #31
mcfly94
mcfly94's Avatar
Default Re: slight hesitation on takeoff?
mm might replace mine when I do a service, mine has a little idle issue normally not noticeable! did you use a genuine vdo?
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2014, 09:11 AM   #32
HULK_I6T
Just bought an ebay cheapie.. $60 delivered
Works fine..
Not that hard to change, just need a 7mm socket and long extensions, 3 bolts
Need to also remove airbox to get your arm under there and air intake from throttle body.
It's an hours job max.
I went on a good drive the other day. piece of mind with a new coil. If hate for it to fail a few hundred km from home
Years back on an el falcon I had one just go cold on me whilst driving. Just conked out under load..
HULK_I6T is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2014, 09:35 AM   #33
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Hey f6, does your au feel stronger down low since replacing the coil or did it fix just the hesitation?
cheers, Maka
Old 26-04-2014, 09:51 PM   #34
HULK_I6T
cheers, Maka
Na feels the same.. Just fixed the hesitation
Old 26-04-2014, 10:14 PM   #35
Maka
Maka's Avatar
Ah ok, thats what i thought too. Thanks for clearing that up!
cheers, Maka
