Drag Racing Discuss Drag Racing here be it dirt or tarmac. Sponsored by Sydney Dragway. |
#151 | ||
Clevo Mafia Inc.
![]() Join Date: Dec 2004
Same names and same old bs and nitpicking. Time a few here try constructive criticism and leave the schoolyard BS at the door.
#152 | ||
#153 | ||
N/A BOSS 390+
It takes two to tango,we do have respect but to those who respect others.Cant see the point in going down the constructive road when you just get banned for varied opinions.Just my thoughts.
![]() ![]() FPV GT 03 /341 RWKW OF N/A POWER. XB GT 73 /OLD FORD MUSCLE ALL AUSSIE MUSCLE |
#154 | |||
I hate ricers
We'll make the car go quicker, I can guarantee that. That engine is still well underdeveloped in many area's. The engine still sports stock 208 heads for crying out loud! Hardly exotic by any means and probably not the best choice on that combo but its what brad bought so that's what I had to work with. The cam is under 260 @ 50 too. Yeah,it's a real race engine....you guys keep telling yourselves that. There is so much potential left in that combo and we've just started playing with it too. |
3 users like this post: |
#155 | ||
It ll get there russ nothing happens overnight
And you guys are doing nothing wrong you just need the track time |
#156 | ||
Just have fun! measuring hp always ends up as a ****ing contest.
#157 | |||
Just like Russ, Greg, Jamie & a bunch of other fella's I cant remember right now Which is a F&*^ken shiitload more than I can say for you & your mate XT302 have done Where are your cars? All you can offer is to insinuate we are telling porkies about the dyno Do me a favour & dont post on threads I start
'68 XT Fairmont, 9.48@141.6 '69 Capri '95 triumph speed triple, '10 Fat Bob My XT Fairmont http://www.fordforums.com.au/showthread.php?t=11298079 My capri track car http://www.fordforums.com.au/showthread.php?t=11492523 |
#158 | |||
if you are within 1/10th and 1-2mph (day with similar air, temp etc) you are doing extremely well and the car is setup very well. |
#159 | ||
How does removing the front sway bar improve the ET?
#161 | ||
So a better 60'?
#162 | ||
If their are weight transfer issues then yes gains could be had.
#163 | ||
By weight transfer issues do you mean traction problems?
#164 | ||
It well help get more weight over the rear tires so if one has traction issues this is a cheap place to start at as a traction aid.
Do you feel the converter has more in it but you are not confident in it hooking up? |
#165 | ||
Done diddly squat to XTGT, Rhino, TC cortina, XY ute we tried it on.
It's my call pizzoff, and I just called it |
#166 | |||
It hooks up well now so we havnt tried anything The caltracs were just set to a base setting, the shocks were set to number 3 & we set the ET radials to 18lbs So i guess if I did put a bigger converter in it there is scope for adjustment if the bigger hit off the line caused loss of traction So is there any point undoing the front sway bar if the car hooks up?
#167 | |||
#168 | ||
how much does the car weigh? what do you think the car should be 60'in?
i dunno bout you guys but that is a pretty damn good 60' as it is, even if u pick up 1/10th in the 60', it doesn't explain your 22-23mph back half, you should be at least up around 27mph. |
#169 | |||
russxr67 I hate ricers Join Date: Jan 2005 Location: perth Posts: 3,854 Re: 393 build I'm doing it because I can't leave them as is. Sure, they will produce the mumbo needed but i'm trying to finesse the ports a little to make the combo better than what it could be by using them OOTB. Not doing a full port so to speak either,just working on giving the ports some texture and some mild port work. Manifold is getting the same treatment but a little more extensive. No point on porting the heads if the manifold can't keep up. Cheers, Steve.B |
#170 | ||
Hey Steve
Your glass is defineately half empty aint it mate
#171 | ||
