Old 04-05-2006, 12:59 AM   #1
mk2_1979_escort
Default Fuel Injection for 2Litre Pinto
Hey guys hope you could throw some advice or knowledge my way. I wanna fuel inject my standard pinto engine. I looked at buying a seirra manifold along with th following;
JE Camira Delco Computer
Complete Camira Loom and Sensors
Camira EFI Fuel Pump
Camira Dizzy
Sierra Dizzy
Complete Camira Injection manifold (for parts ie Throttle Body, injectors, fuel pressure reg)
Sierra Injection manifold
Sierra Fuel Rail
Sierra Injectors
Camira Injectors
Separate Sierra Injector loom (might be of use?)
Camira Coil pack
Spark leads
Is this everything i need. What tpe of knowledge do i need to install this ? Will i get much of a performance gain. Pros, cons ?? Is it really worth it ? Fuel economy etc
mk2_1979_escort is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2006, 03:07 AM   #2
THORNSPAWN
In the Forced 'lane
THORNSPAWN's Avatar
I wouldn't bother with the camira crap, the only reason to use the delco and camira stuff is it's easier to tune on a turbo or modified engine, if you're keeping the motor standard just use the complete sierra system. It will all bolt straight on and there are only 3 wires to connect, from the injection loom, to get it all running and you don't need to modify the dizzy or anything for it to work.
As far as installing it, it's quite easy, most of the plugs only fit what they're supposed to plug into then you need to run a wire to the EFI fuel pump which mounts just infront of the tank, mount the computer inside and make up an air cleaner or airbox.
I didn't notice much more power than carby but it's heaps smoother and more economical.
Hope that helps, here's a pic in a MK2 RS2000.
XE S-Pack
4 Runner
XH11 Longreach
THORNSPAWN is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2006, 10:54 PM   #3
Aussie_Escort
Aussie_Escort's Avatar
That was on ebay wasn't it mk2_1979_escort??
Were you the winning bidder??
Aussie_Escort is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2006, 08:05 PM   #4
R0BD0G
R0BD0G's Avatar
that got reasnobly expensive so i dibed out
R0BD0G is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2006, 09:50 PM   #5
mk2_1979_escort
Nah was thinkin bout it, but then i thought just getter a bigger carby :voldar02:
Old 12-05-2006, 09:53 PM   #6
Aussie_Escort
Yeah i was watching it but it got rather expensive!
Wack a 350 holley on!
Old 13-05-2006, 03:25 AM   #7
mk2_1979_escort
Yeh 350 Holley much easier to tune than a Weber. I was thinkin of twin webers but then it just guzzles fuel and must be kept in sync with each other. The List goes on....
350 Holley is the way to go!
Old 08-06-2010, 01:36 PM   #8
TeCorty
sorry to dig up an old thread but im looking at doing this to my te cortina anyone know a place to get the sierra bits? should i go all siera or grab the camira bits as i have headwork, rather lumpy cam and a 40thou overbore
TeCorty is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2010, 04:38 PM   #9
eski666
eski666's Avatar
try euro-speed. Pretty sure there is a web site.
New engine on the way :
Weisco Pistons, Total Seal rings, Crower rods, BIG lumpy stick, TO4E with back cut exhaust wheel 1.0 rear housing 30psi!!, major head modification! Bring on the 1/4 mile :
eski666 is offline   Reply With Quote Multi-Quote with this Post
