Old 12-10-2006, 05:08 PM   #1
71CORTYOWNER
71 Mk2 Cortina owner
71CORTYOWNER's Avatar
Smile engine swap
does anyone know wether a 289 windsor would fit straight into 1975 escort mk2 with out any modifications to the engine bay.
thanks
71CORTYOWNER is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2006, 06:12 PM   #2
mk2maniac
Um, no.
mk2maniac is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2006, 11:18 PM   #3
79eskimk2
there would be a fair bit of modding to do if u wanted to put any v8 in an eski, getting rid or the brake booster and master cylinder and moving it, engine mounts and moving the radiator forward and maybe cutting a chunk out of the firewall, getting a bigger gearbox tunnel, then u haveto move into the diff and tailshaft, a hwole lot of mucking around really
79eskimk2 is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2006, 11:22 PM   #4
rag top
rag top's Avatar
a 3.5 leyland V8 would be a better fit, and wouldn't affect the handling too much.
Old 28-10-2006, 05:48 PM   #5
73escort
73escort's Avatar
considering a 302 into a mk1 for our next build
to go up against an sr20det mk1
should be interesting if it goes though
The Toys
Daily - Mk1 Escort Panel Van - 2litre converted, re-trimmed interior, 4.11 diff, 4spd,
In the build - Mk1 escort 4dr, 2lt Pinto,
73escort is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2006, 12:10 AM   #6
wodahs
wodahs's Avatar
using bronco mounts and bronco sump helped me out when i did this to a cortina but it was a clevo 51 and if you want to go manual then you also gotta mod the clutch system plus brake mods and the other mods that were sugested
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
