1000+ passes
I ran my ute at WSID on wednesday 25/8/10, the motor in it is a 408 cleveland built for a mates detomaso, a prolect that is now not going to be completed, It ran in my XY ute weighing 1620kgs 11.7 at 116mph with a full exhaust, pump gas, toploader, and slicks.
If anyone is in the market for a good cleveland its forsale for $8000 complete with carbie, dist, the lot, I will take it to the drags run it and pull it out so you now how it goes, heres a quick run down of it *Scat 4 inch crank balanced with mallory metal ( takes zero balance flywheel or flex plate ) *Steel 6 inch rods *Forged flat top 1.2 pin height pistons *zero deck *Cast 2V open chamber heads good valves, springs, guide plates, rollers,ect *Crow solid 246/256 cam *Weiand accelerator manifold *850 DP holley *Ford electronic dist *Romac balancer This motor has only done about 100klm plus 3 passes down the strip, Its a pretty good buy for $8000 as a complete going engine compared to those ebay short motors for $8400
XY ute 1600+ kgs, normally aspirated pump gas 351 std stroke, cast iron 2V heads, toploader, drag radials, 11.524 - 119.48mph https://www.facebook.com/DragRacingT...2067110055900/ http://www.cacklingpipes.com/100825_...250810_025.JPG XA coupe naturally, aspirated Cleveland, full exhaust, 98 oct pump gas, drag radials, Manual trans, 10.664 132 mph The faster youve gone the worse your attitude ![]() ![]() |
the burgerman
dam mate wish this motor was around last year what a beasst did u build a custom crossmemeber for it.how much mods to fit in eb what box does it run
looks good for 8gsss |
Thats a good deal
My mate called me today asking if i knew anyone that wanted a 393ci with 4v's that ran 10.9 in a XY for 10k, engine is built by CV and just had a freshen up so its ready to rumble.
Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc |
#4 | |||
1000+ passes
Off tap Truckie
nice useable cam you got there, well done.
T3 TS50 Brembo's,AFR 185,Platuim Rockers,Haltech,MSD,Custom exhaust
![]() ![]() 1968 KC Bedford 1970 Mk1 Escort GT 1980 Mack Superliner 120t: Project Puppy Dog! AU2 XLS Cab Chassis, 5ltr, T3 Kit, Speedy Envy's 19x8.5 |
1000+ passes
#7 | |||
1000+ passes
I'll send a txt to my mates and see if anyone is keen and ill get them to jump on here.
Who machined, assemble and balanced this engine???
#9 | |||
1000+ passes
Nothing stays standard !!
Hey mate,
Looks like your XY is pretty well setup for the drags - looking at your sig a 351 stroke cast 2v head doing an 11.5..... |
#11 | |||
1000+ passes
#12 | ||
KillerXR8
![]() Join Date: Feb 2007
and gee the ute purrs along nice now too Bruce.....
FULL X-FORCE STAINLESS EXHAUST,HERROD HP CAMS,YELLA TERRA PLENUM, GT 500 TWIN 60MM THROTTLE BODY,GT AIRBOX,K&N FILTER,ZF TUNE,CUSTOM TUNE,8" BOSTON ACCOUSTIC SUB,SONY AMP,AUTO METER D-PIC GAUGE,INNOVATE WIDEBAND AFR GAUGE,CUSTOM GAUGE HOLDER FROM STAV AT STINGRAY, KINGS SUPER LOWS,20 x 8 FPV DARK ARGENT REPLICA'S,BLACK TINT,CUSTOM MATT BLACK DECALS 2009 TWEEKD FG XR8 IN SILHOUETTE all mods done by Walter Markham from Oztek Performance
#13 | |||
1000+ passes
Thread Tools | |
Display Modes | |
