31-05-2007, 12:49 AM | #1 | |||
You can't stop the signal
Hey all, how are we?
I'm just after some clear definitions on the above two terms, "unopened" and "street trim", and what can be done while staying within those guidelines. "Unopened" - obviously heads can't have been off. But what can be changed? Intake/exhaust manifolds? Rockers? Cams? (pretty sure that’s a no) injectors? and stuff like that "Street trim" - pump fuel, street tyres, full exhaust. What about the interior? Only got to be street legal? Thanks for your responses Cheers
31-05-2007, 01:58 AM | #2 | ||
Unopened generally means just that. The exception ( in the other camps opinion ) is valve springs. Injectors would be fine too. Extractors are ok as its bolt on but inlet is an iffy. Any thing else that doesnt bolt up externally generally isnt unopened ( cam, heads, etc.)
Street trim the way it came out. No spare wheel, streetable tyres (with tread), pump fuel and full exhaust running cats and muffler/s. My 2c
A philosopher is a person who finds a problem for every solution . :Reverend: 95 EF XR8, Advance headers, Vortech V2 t trim blower, Ported Cobra Manifold, Capa Switch Chip Eliminator. 307 rwhp 395 ft/lb 13.2 @ 105mph Now NA- AFR 165 heads, 1.6RR, Ported Cobra 269rwhp 14.2 ... needs stall and 4.11's 1977 CL Chrysler Panel Van, 360, 727 torqueflite auto soon to be restored. |
31-05-2007, 02:12 AM | #3 | |||
Virtuous Bogan (TM)
Unfortunately there is no definition, but IMO street is pretty much what schnoods said, but I would allow slicks or atleast something better than your usual tyres. Other than that everything else that you would normally drive around in down to the shops. As for opened/unopened, I cant believe that even exsists. The only category you need is engine, so V8 n/a, I6 n/a , I6 Forced, V8 Forced.
31-05-2007, 10:02 AM | #4 | ||
KITTY Crew Member
I have apparently been opened, when I put in the performance enhancing billet pump gears (Can of worms anyone?)
FOR SALE BAII Super Pursuit 0083 Awsome power by XTREME FORD TUNING 500rwkw New ALLOY Block Awesome exhaust by THE EXHAUST CENTRE MIDLAND Awesome Kenne Bell Supercharger setup by AGRO! and Bluepower Racing Developments Now with full DOT approval and Permitted for road use
31-05-2007, 10:13 AM | #5 | ||
THIS IS SPARTA!!
i think this whole unopened ect ect is more tuning shop braging rights to get an "edge" in sales.
31-05-2007, 12:04 PM | #6 | ||
Unopened is a term that gives an even playing field for tuners to prove their tuning ability.
A unopened motor from the factory will be very similar to the next unopened motor so if a tuner gets better results, it shows his ability. if a motor has been rebuilt or modified it can show that the combination is good or bad and the tuning is still important for results but not as important as a unopened motor to prove results as a perecntage of overall gains. Changing to oil pump gears on the Boss, although itself does not help with power, but it allows the owner to rev his motor higher with confidence which can help with 1/4 mile times, also how do you police that cam timing has not been altered, Chris proved that by changing cam timing that the motor can be made to go quicker over the 1/4 Changing valve springs on a turbo motor helps the motor run more boost by stopping valve float, which is not a problem at normal boost levels. Changing valve springs on a LS1, brings back lost power from weak factory valve springs which cause valve float at higher revs after they have softened with age.
31-05-2007, 12:46 PM | #7 | |||
RIP Craig - 13/11/08
31-05-2007, 12:49 PM | #8 | |||
If you got two cars out there from two different shops and one car is consistently quicker and faster (don't have to win - the driver makes a difference there) the punter watching or reading the forums will i think go to the shop that runs quicker, isn't that human nature?? Why do we "strip" the car for racing? Well been there done that in a full weight manual BA XR8 ute and it's extremely difficult to get these cars to hook up on a drag strip in street trim, there's no fun in pedalling the car all the way down there. The best i could achieve in "FULL" street trim was 13.14 with a passsanger. The next week with 4.10 diff gears and only slicks and front runners being the changes it went 12.58 and then a week later in sydney it went 12.49. Bring it home and take off exhaust, tailgate, pass seat, 90/10 shocks, towbar and lighten it by about 110kg and the times drop to 12.15. It's alot more fun running in a race set up than it is in full street trim. It's horses for courses, whatever takes your fancy if you want to run in full street trim that's fine but it's a lot more fun when you set it up for racing. And as i have said many times before until there are rules drawn up and we have an indepentent scrutineering these cars well it's run what you brung and do as you please. |
31-05-2007, 12:53 PM | #9 | ||
KenneBell Australia
Our scene is following the LS1 scene fairly closely - this is where a lot of it comes from.
Bluepower Racing Developments Proud Australian Distributors of Kenne Bell superchargers The Quickest, The Fastest, The Baddest Boss Blower of all. www.bluepower.com.au |
31-05-2007, 01:46 PM | #10 | ||
Solution Was Boost 4?, 6 & 8
If we are following the lead of others like the XR6 Turbo lead this would mean unopened isn't really unopened.
The rules are simple make them up us you go along, don't have any rules keeps it even more simple. You can have all the rules in the world in the end it comes down to one thing, Honesty. Never loose the site for most of us its the enjoyment is the drag racing regardless of ET, the mods or opened or unopened sometimes this goes with to much politics. I remember when Rod got bagged for removing a highlight lens and was called a cheque book racer for importing 2 drag radials for $1400 the understanding has come along way since then. Run what yah brung hope its enough and just go out and have Fun
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW Last edited by SpoolMan; 31-05-2007 at 01:52 PM. |
31-05-2007, 01:56 PM | #11 | ||||
THIS IS SPARTA!!
I'm not an angle when it comes to chasing ET's, everyone would have seen me stripping everything out of my ute at the AFF drag meet. |
31-05-2007, 02:39 PM | #12 | ||
so how much would you knock off your ET by stripping out the interior on a sedan?and
how much more MPH would you gain?
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17. |
31-05-2007, 03:18 PM | #13 | ||
Rule of thumb was you would gain 1 tenth for every 100 lbs of weight you reduced the car by.
With Street cars you would be lucky to remove approx 100 kgs with the normal removal of exhaust and seats and tailgate
31-05-2007, 06:13 PM | #14 | |||
31-05-2007, 07:45 PM | #15 | |||
KITTY Crew Member
01-06-2007, 12:41 PM | #16 | |||
Thanks all. You've cleared some things up for me.
Thanks craig, thats probably the best summary of unopened/opened i've heard Cheers
02-06-2007, 12:51 AM | #17 | ||
trying to get a leg over
I was reving mine to 6800 before i had oil pump gears fitted, and i am not reving any harder now, just peace of mind.
But my motor was opened when Ford replaced the cam chain tensioners under warranty.
Cameron ------------------------------------------------------ |
06-06-2007, 12:31 PM | #18 | ||
Bear with a sore head
My understanding of something being opened is any engine that has had any replacement or modification of a factory component that enables it to rev higher, obtain more power and or reliability which requires lubrication to operate. I mean, unopened by definition is just that, so that obviously includes oil pump gears and valve springs. But in the circles of LS1, valve springs is not to be considered as opened. It apears that we are following the same trend over here, with oil pumps gears on BOSS' and more so valve springs on turbos being considered unopened.
As for street trim, I don't think any weight is alowed to be removed? Even removing the spare, although not illegal, is still remvoing weight from it's original factory quoted weight. WIth tyres as long as they are street legal treaded tyres then they are fine. I don't beleive the M/T streets are actually legal to drive on as I thought the name was derived from a "street" class DOT radial. But I could be totally wrong... |
06-06-2007, 01:00 PM | #19 | |||
since the beginning
BF F6 10.80@131mph Street Trim
10.47@135mph Race Trim, Std Factory Turbo Always Autotech |
06-06-2007, 02:00 PM | #20 | |||
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW |
06-06-2007, 05:58 PM | #21 | |||
The unopened deal in the LS1 scene is a joke IMO. They have classes that i reckon make sense except for the valve spring deal. We should or could consider these for any future events. The classes are BOTS - BOSS- LSSR - LSSS - LOF - Details below LS1, LS2, L76 & L98 BOLT ON TRUE STREET (BOTS) "Cars Racing in True Street Trim" TYRES: Street Legal RADIAL construction tyre - as big as the FACTORY placard allows No Drag Radials BODY: Full stock silhouette with all body panels remaining 'as stamped' and road legal lighting operative. Additional bodykit optional. Aero mods free (ie. utes MUST run rear gate, sedans retain headlight) Factory seats and full interior must be retained Spare wheel, tool kit, all must be retained A/C heater motor in place. Window mechanism retained ENGINE: Unopened engine (minimum idle vacuum to be checked) Valve Springs Free Single throttle body inlet manifold Full exhaust system with pipe(s) exiting in factory location Full size stock radiator Air Filter (of some type) MUST be retained 98 Octane pump unleaded only PCM: Management type Free, calibration Free TRANSMISSION: Stock transmission fitted as described on build tag Internal gearbox modifications (eg stall converter, upgraded synchros) free. Gearbox ratios to remain standard Differential ratio and operation free SUSPENSION: Shock absorbers and springs free OTHER: No power adders Vehicle must have original ADR compliance tag affixed, and carry an identifiable Holden VIN Number Minimum Raceweight - excluding driver - 1600kg LS1, LS2, L76 & L98 BOLT ON STREET STRIPPER (BOSS) "Stripped Down Bolt On Class" TYRES: Any tyre allowed to a maximum of 275mm BODY: Body specification free Interior free ENGINE: Unopened engine - requirement (minimum idle vacuum to be checked) Valve springs free Single throttle body inlet manifold Air Filter free Exhaust free Fuel free PCM: Management type Free Calibration Free TRANSMISSION: Stock transmission fitted as described on build tag Internal gearbox modifications (eg stall converter, upgraded synchros) free. Gearbox ratios to remain standard Differential ratio and operation free SUSPENSION: Shock absorbers and springs free OTHER: No Power adders Vehicle must have original ADR compliance tag affixed, and carry an identifiable Holden VIN Number Minimum Raceweight - excluding driver - 1400kg LS1, LS2, L76 & L98 SUPER STREET RADIAL (LSSR) This category is for the more serious drag racer using radials BODY: Body specification free Interior free PCM: Management type Free Calibration Free TYRES: Radial tyres are the only type of construction allowed. BFG Drag Radials, M/T Drag Radials and Nittos are all acceptable. TRANSMISSION: Maybe be either Manual or Automatic CHASSIS: All cars must have the original chassis only, no modifications permitted. SUSPENSION: All cars must retain stock style suspension and factory locations. No fabricated control arms, 4 Links, ladder bar rear ends or chassis connectors. Standard wheel tubs must be retained unaltered. Outer lips may be rolled. OTHERS: Must have current registration. LS1, LS2, L76 & L98 SUPER STREET SLICK (LSSS) This category is for the more serious drag racer using slicks BODY: Body specification free Interior free PCM: Management type Free Calibration Free TYRES: Slicks and front runners TRANSMISSION: Maybe be either Manual or Automatic CHASSIS: All cars must have the original chassis only, no modifications permitted. SUSPENSION: All cars must retain stock style suspension and factory locations. No fabricated control arms, 4 Links, ladder bar rear ends or chassis connectors. Standard wheel tubs must be retained unaltered. Outer lips may be rolled. OTHERS: Must have current registration. Safety Notice: Any vehicle running an ET of 12.5 or better and or trap speeds in excess of 110mph whilst using cross ply slicks will be required to use cross ply front runners. LS1, LS2, L76 & L98 OUTLAW & FRIENDS (LOF) Any LS1, LS2, L76 & L98 powered, four wheeled, vehicle that does not meet the BOTS, BOSS, LSSR or LSSS rules. |
06-06-2007, 09:53 PM | #22 | ||
I have a BA MK1 XR6T that i had a tune done on.It made 244rwkw with just tune,the tuner said the valve springs were crap but i went and raced.The best time was 14.0 which is no real better then stock as i was losing alot of power in top end.i got valve springs done and a retune which only made 5more rwkw but was able to keep power up top..i raced after this and did a 12.8..
So to me i think its fair enuf getting valve springs done on a MK1 considering how much it affected the times |
06-06-2007, 11:38 PM | #23 | ||
Well done on the times
Your post makes it clear how much a performance benefit the valve spring change is on the T. If you had been running standard boost, the springs would not be needed hence is why they are a performance mod rather than a reliability issue. Don't get me wrong, if I owned a T, I would be changing them so I could run more boost, I just wouldn't call it unopened.
07-06-2007, 09:07 AM | #24 | |||
In the MK1's with some of them it is a reliability item as when you do raise boost a little you get valve float when you give it a hit on the streets and not only at the track..It must have been a reliability issue with the mk1's as from my understanding they changed the springs on the the mk2 and BF.. Coming from a turbo side can I ask why alot of the BOSS guys change the diff ratio??Is it a reliability thing or a perfromance gain??? |
07-06-2007, 02:42 PM | #25 | |||
[SIGPIC][/SIGPIC]
07-06-2007, 02:55 PM | #26 | |||
07-06-2007, 03:07 PM | #27 | |||
07-06-2007, 03:19 PM | #28 | |||
Your allowed valve springs under xr6turbo rules puts your car on a even field with the BF. We have 2 Boss motors that are different inside the engine, I can just see the unopened rules allowing the Boss 260 new valve springs. Cars that have no interior and no exhaust should be classed as race cars, yes saving weight improves your ET but isn't like the unopened rule, changing valve springs etc, helps your ET. IMO. Quote from Budget Racer ''I don't want to win I just want to race''.
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW Last edited by SpoolMan; 07-06-2007 at 03:25 PM. |
07-06-2007, 03:25 PM | #29 | |||
I don't see how it can be any clearer. |
07-06-2007, 03:27 PM | #30 | |||
[SIGPIC][/SIGPIC]
Thread Tools | |
Display Modes | |
