21-05-2023, 04:02 PM | #1 | ||
Hi. I recently bought a second hand Sony stereo and Bluetooth module from a 2013 Zetec.
Was wondering if this model did Bluetooth music streaming, as it doesn't appear to have the option available at the moment. Is it something I can get working using Forscan? Or is the hardware just not there? Also, the Bluetooth module has an old style micro USB port in it. If I fit a USB extension lead to this would I be able to play from USB sticks? Thanks! Last edited by AlanM; 21-05-2023 at 04:12 PM. |
21-05-2023, 06:11 PM | #2 | ||
Challenge Accepted!
yes they all did if optioned with BT, is BT turned on in the settings, and it's paired correctly?
As for the usb slot I believe it can be used, at lest that was my understanding way back when.
21-05-2023, 06:27 PM | #3 | ||
Thanks, yeah, the phone works through BT, but there's no option for audio streaming, not on the phone or the stereo as far as I can see.
I've seen on YouTube where pressing the CD/Aux button brings up the BT audio option, but on mine it just toggles between the CD and Aux input. I hooked up the OBD2 and laptop and looked at Forscan, but in the configuration menu the audio module doesn't appear, so I guess there's nothing I can do in that direction. |
22-05-2023, 12:03 PM | #4 | ||
I have the Sony unit factory-fitted in my Titanium, and yes it plays Bluetooth, iPod, USB, aux-in and CD sources.
Inside the glovebox there are Aux-in and USB-A sockets. I'm lucky enough to have the genuine iPod harness cable that has the 30-pin dock connector at one end and plugs into both those sockets at the other (I understand these cost a pretty penny to replace from the dealer), connecting our old-timey iPod that basically lives in the car. I know from the manual I can also plug a USB storage device into that USB socket and play music stored off of that. The source selection works as you described, pressing the CD/Aux button cycles through the available options e.g. CD > iPod > B/T. I'm surprised you're not seeing the B/T come up if you've successfully bonded the phone to the unit, on mine it just comes up waiting for media to be played. I will note that it's not the most intuitive system, for instance you can only have one active connection and if it connects to the wrong device I have to tap Phone then Menu to change to the one I want, then go back to music. I'm not sure what the micro-USB socket on your Bluetooth receiver could be. As I said, my car has a USB socket that can take a flash drive (or iPod with the dongle), but it's a USB-A not micro-USB socket. I somehow doubt my USB-A socket is connected into a micro-USB plug to feed into the stereo, but I'm not certain how things are wired up behind the dashboard. I'm guessing it's more likely to take a microphone for phone calls. I do need to replace my cabin filter sometime (which is a glovebox-out operation) so if I find time for it I'll try to have a look at where it's plugged in for you... |
22-05-2023, 12:08 PM | #5 | ||
Sorry for double post. Does your scantool support the Ford-proprietary MS-CAN ("medium speed" CAN) interface? Many of the non-drivetrain modules live on that network, you need a special kind of OBD2 tool to talk to them.
22-05-2023, 02:02 PM | #6 | |||
I'll keep mucking around with it, but yeah, there's definitely only CD and Aux options when I press that button. I'll probably get a micro USB - USB A cable and give it a try anyway. |
23-05-2023, 11:02 AM | #7 | ||
BT music works fine on my 2012 MC ZETEC wagon. It occasionally craps itself and wont connect but when it does that I get a 'BT searching' message when selecting BT input via the CD/Aux button, so sounds like yours in missing the feature rather than a connection/bonding issue.
A mate had a XR5 focus with what looked like this exact same head unit but it couldn't play music over BT. Maybe your car got this inferior HU from the factory, or it's been changed by someone since?? Either way it sucks. BT music is probably the biggest reason to go for a ZETEC over an LX IMO. At least you get the better sound system I guess. If you've got the 3.5mm AUX input jack and the USB port in the centre console then best bet might be to put an aftermarket BT receiver in there. Or, just a hardwired connection to your phone. |
24-05-2023, 04:55 PM | #8 | |||
With the newer one there's also the option of sharing media, but it won't stay switched on when I switch it. So maybe there is some setting in the stereo that needs changing, or maybe it's something missing from the harness? |
24-05-2023, 09:58 PM | #9 | ||
Something I find a little amusing. The female voice of the base model Ford stereo sounds quite cheerful and positive.
The Zetec lady sounds like she's got better things to do than talk to me! |
25-05-2023, 12:33 PM | #10 | |||
I've got no idea what's going on really but definitely could be a difference in the car if you're trying to put a zetec head unit into an LX (if I'm understanding correctly). The Sony HU in my Zetec ties in with the dash display for some info/setting/functionality (eg. changing HU time, selecting phone contacts, selecting audio inputs etc) so without the appropriate dash the HU may be somewhat crippled. Why have you changed the head unit? I'd be tempted to change to get a new fascia that can accept a double Din unit and get a kenwood, sony etc with carplay/android auto. |
25-05-2023, 03:20 PM | #11 | |||
Nearby someone was wrecking a Zetec, so I got the bluetooth module from them, hooked it up to my stereo and with an app on the phone could see it was transmitting bluetooth, but I couldn't get my phone to pair. I also couldn't unbond the existing phones, 5 of them using my head unit. So I offered $50 for the Sony HU, that or I'd just put the BT module back. They accepted, so I wound up with the Zetec BT module and Sony. Even if it doesn't stream music, it's got some advantages, a good one being it can voice dial straight out the directory, with the old stereo I had to pre-record names and numbers. I really like the complete hands free voice calling capability, the lack of which puts me off fitting most aftermarket units. The stereo itself seems OK, but the Ford CD 6000 always surprised me with how good it sounded, for a stock base model stereo. With the clock, when I installed the Sony, it automatically got the right time from the car, so no issue there. Last edited by AlanM; 25-05-2023 at 03:27 PM. |
26-05-2023, 11:52 AM | #12 | |||
Ever tried using the voice assistant on you phone? 'Hey Siri call mum' works like a charm for me. I've never used the handfree capability of the car. |
26-05-2023, 03:25 PM | #13 | ||
Yeah, but that doesn't turn the music down when there's an incoming call, and in reality it's not really hands free initially.
27-05-2023, 08:45 PM | #14 | |||
The CD6000 sounds pretty good to me. I'd like to be able to stream from the phone, but not badly enough to venture into aftermarket stereos. I should sort out a BT module for the minijack input, it would be nice to have music and navigation through the stereo. Sent from my SM-S906E using Tapatalk
27-05-2023, 08:52 PM | #15 | |||
And yeah, I hesitate to go with an aftermarket stereo because there's a fair chance it wouldn't sound as good as either the Ford or Sony unit. (Which have pretty similar sound quality IMO) |
29-05-2023, 02:17 PM | #16 | |||
It's very hands free. I can do all the necessary stuff such as make calls, send messages, play music, start navigation on the phone all with voice prompts and never touching the phone. |
30-05-2023, 06:27 AM | #17 | |||
It's on longer trips where BT media streaming would have been good, especially if I'm using a navigation app too. But I can do it by wire, even if it doesn't allow all the functions. Thanks for your help, knowing the Zetec does have the capability means it's worth tinkering with it when I feel inclined. |
30-05-2023, 02:01 PM | #18 | ||
Well to be clear I've never used siri to actually answer calls because I use the controls on the car, or I just touch the phone to answer (which is legal to do if the phone is already in a cradle).
Siri can do it but needs to set it up to announce calls. https://support.apple.com/en-au/guid.../16.0/ios/16.0 |
