13-02-2005, 04:28 PM | #1 | ||
I recently got myself a 2.0lt pinto for my escort how ever it has a cortina sump on it (can i use that or do i need to source a escort 1?) and my other problem came when i went to take the head off, there are a weird type of bolt holding the head on, does any1 know what type of socket/thing i need to undo the bolts and what size it is?
Thx David |
13-02-2005, 04:44 PM | #2 | ||
In the Forced 'lane
The head bolts are 10mm spline bits about $10 a set at supercheap
The sumps should be the same
XE S-Pack 4 Runner XH11 Longreach |
13-02-2005, 08:02 PM | #3 | ||
THCC Motorsport member 1
yeah should be a straight fit if ya talking about a MKII eski
did that to my last escort put a TE 2L innit and she went like a rocket aye :P might have to source another one if i cant fix my current pinto :P
Southcyde Designs<------click here : Member of the MTAS Founder of TTM (team twink motorsport) Founder of the AFFDDPS (Australian Ford Forums Drink Driving Punishment Squad) |
15-02-2005, 09:32 PM | #4 | ||
soz for keep asking questions but i got some more
a guy at my dads work said that the 1600 trans tunnel isn't bigh enough to fit the 2ltr bellhousing for the gearbox and that u need to source a RS2000 bellhousing and even that needs to be trimed a little to fit. Is that true?? its a mk2 1600 and i really want to know exactly what i need to change to be able to bolt up the 2ltr after its been rebuilt. thx david |
16-02-2005, 07:50 PM | #5 | ||
Manual trans tunnel is the same size - 2.0, 1.6, 1.3. The auto trans tunnel is bigger than the manual trans tunnel.
Current Rides: 2000 AU 5L XLS ute; 1970 Mustang project |
17-02-2005, 08:03 PM | #6 | ||
how hard is it to make about 110-120hp @ wheels from the 2lt?
ATM I'm balancing crank new pistons, rings etc new cam, rocker arms etc (what size cam would suit my wanted power for street use?) Is a port and polish needed to make that power? how big of a port job would be needed? What type of carb would be recomended? thx David |
19-02-2005, 02:47 PM | #7 | ||
Get yourself a copy of the David Vizard book on modifying the 2ltr. It will answer all your questions, and give you a few extra ideas...
19-02-2005, 04:40 PM | #8 | ||||
No longer driving a Ford.
http://www.fordforums.com.au/showthread.php?t=658 Good luck, and keep us informed on how it's progressing, ok?
