RBS
Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Ford Performance Club of ACT > Ford Performance Club of ACT Owners Club Discussions
Ford Performance Club of ACT Owners Club Discussions General Chat
Old 16-04-2020, 03:17 PM   #31
Revolver
Big Member
Revolver's Avatar
Default Re: XR6 to XR6 Turbo Impossible?
Originally Posted by Fiji View Post
You can't really put the turbo on. The n/a motor has higher compression, maybe you could run 8-10psi max. Basically stock type power
Why not just do the exhaust and intake, tune on the n/a.. if you must do a cam? They will pretty much go with a stock turbo at that sort of power...
Problem is you can't wind up the boost on a turbo with your high compression engine, gearbox won't last either.
Try a centrifugal vortech on it. 8-10psi and it's unique. Plenty top end go, I've been in one. It sort of takes care of your high compression motor as the boost builds gradually peaking at top rpm. Just go fuel pump, vortech, injectors, tune and exhaust .. beaitiful
You can.
My brother is running an NA Barra with 15PSI on it. 500 RWHP on E85, 350 RWHP on 98.
Low boost is 10 PSI.
Hes looking to turn the boost up further for around the 650 mark & has sourced an FG F6 Long block to take that next step.
I may add that engine huffing 15 PSI he found at the dump, and took out top 6Cyl NA at AFD in 2019.
3rd year running in that Chassis.
But he is running a TR6060.
The Scarlet Fairlane: 94 5.0 Litre NCII Fairlane 488800kms - Retired & awaiting Resto
Premo sound
EBGT Momo Woodgrain Wheel
Scarlet Fairlane Build Thread
Project "White Knight"
93 ED XR6
Genuine ELGT wheels.
Momo wheel
Cruise
Sunroof
/////Alpine Sound.
Manual
HO Goodies
Barra swapped
PWK Build Thread
The 747 - AKA “The Dad Bus”
06 Territory Turbo Ghia in Lightning Strike
F6X Grille
Under headlight intake.
15PSI Boost - 330HP to all 4 Wheels.
Tons of factory accessories.
Revolver is offline   Reply With Quote Multi-Quote with this Post
