22-08-2019, 01:51 PM | #1 | ||
Was going continue this Thread,
https://www.fordforums.com.au/showthread.php?t=11479238 But It's being Locked. Here's an Interesting Comparison of 10 Dual cab Ute's & their Towing Capabilities (Or lack thereof) https://www.carsales.com.au/editoria...towing-117657/ Strange how VW won't allow Weight distribution Hitchs, Brake controllers or Driving over 80Kmh.... |
22-08-2019, 02:00 PM | #2 | ||
Experienced Member
Sorry I decided to delete my comment.
22-08-2019, 11:24 PM | #3 | ||
tldr: All the Thailand specials don't move out of their own way unloaded let alone with 3000kg on the back and 184kg of people in them.
23-08-2019, 04:22 AM | #4 | ||
Let's just see how long they last towing 3t their whole life
3 users like this post: |
23-08-2019, 07:35 AM | #5 | ||
irregular member
I would have like to have seen 0-100, 1/4 mile and lap times while towing.
23-08-2019, 09:30 AM | #6 | ||
People do buy them to tow and on that basis, it's very useful information. I've given a copy to my neighbour given he's towing a large off-road van and their Wildtrack is also pretty well packed because he'll probably be getting awful close to the limits.
4 users like this post: |
23-08-2019, 10:23 AM | #7 | ||
23-08-2019, 10:33 AM | #8 | ||
Rob
If you are towing anything over 2.5t you really need to do your due diligence when looking for a tow vehicle. Marketing is there to sell the vehicle, not to present the 'facts'. while Marketing is not 'false' it can paint a less than accurate picture, and most of the time the sales people don't have enough product knowledge to answer all the questions you need to ask.
Many are biased against these types of cars, but the reality is, if you get your weights right, they are very capable cars. Payload deficiencies have been well documented over the years, as has the max tow rating of 3.5t, but the reality is, most people tow well below that.
UA2 TREND 4WD BI TURBO |
7 users like this post: |
23-08-2019, 11:17 AM | #9 | ||
And some crack the chassis behind the cabin. Chassis not strong enough to take the weight.
https://www.google.com/search?rlz=1C...w=1366&bih=625
CSGhia |
23-08-2019, 11:45 AM | #10 | |||
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP |
23-08-2019, 11:53 AM | #11 | |||
That the 4 cylinder Dual cabs Towing capacity should be capped at around the 2500-2800kg mark.. Anything above that is asking for Trouble.. just My 2 cents.. |
23-08-2019, 12:43 PM | #12 | ||
Rob
Personal opinions are often at odds with the engineers that actually design and test them.
23-08-2019, 12:46 PM | #13 | |||
Rob
23-08-2019, 02:07 PM | #14 | ||
The current Ranger dual cab makes an interesting case in point. (Please note: all figures are for the manual version).
It has a rated GCM of 6000 Kg. That's the total weight of the trailer/van unhitched, and the total weight of the vehicle unhitched, added together. It has a rated GVM of 3200 Kg. That's the maximum allowed weight of the vehicle with everything in/on it, inclusive of the tow ball weight. Given that the kerb weight is nominally 2124Kg (with no accessories but including a full tank of fuel), that leaves a maximum theoretical payload of 1076 Kg. Note that the Auto adds 17 kg to the kerb weight and thus reduces the payload by that amount. It also has a maximum front axle loading of 1480 Kg and 1850 Kg for the rear axle. The kerb weight is stated as 1159 kg for the front axle (manual) and 965 Kg for the rear axle. Add 17 Kg to the front axle for the auto. That allows (manual) 321 Kg of payload for the front axle and 885 Kg for the rear - except that would actually put it over the 3200 Kg GVM so in practice those loadings between them have to drop by 130 Kg. It's probably not entirely accurate to say that the people add loading to the front axle as the design of the dual cab utes probably spreads at least some of it over the rear but it's fair to say that there isn't a lot of wriggle room with a 3T van.
5 users like this post: |
23-08-2019, 02:46 PM | #15 | ||
Rob
What works in rangers favour when it comes to towing is it's long wheelbase and short tow ball overhang (distance from rear axle to tow ball).
23-08-2019, 03:23 PM | #16 | |||
Former BTIKD
23-08-2019, 03:50 PM | #17 | |||
23-08-2019, 03:57 PM | #18 | ||
Rob
By trailer weight, you mean GTM, which is the weight on the trailer wheels. ATM, which is the unhitched weight, could still be around 3100, assuming 10% ball weight included in GVM of 3200.
23-08-2019, 04:52 PM | #19 | |||
Because as you correctly point out the ute can only be 2900kg (In round Figures) prior to hooking up the Trailer.. |
23-08-2019, 04:55 PM | #20 | ||
Rob
If you load it to GVM you can't hook up any trailer...
23-08-2019, 06:18 PM | #21 | |||
Cabover nut
7/8s of the tub/tray is hanging behind the back wheels (like all the rest), Looks like a great place to load up 1 ton.
23-08-2019, 07:03 PM | #22 | ||
23-08-2019, 07:36 PM | #23 | ||
Car advice is doing an 11 way comparison on dual cabs right now. Interesting to see what their results are.
I believe if you tow near your gross trailer mass occasionally it's fine, but if you're towing near it regularly you probably should look at a bigger vehicle. |
24-08-2019, 01:29 AM | #24 | ||
Experienced Member
24-08-2019, 08:44 AM | #25 | |||
Cabover nut
A bit like the US type 4 door pick ups.
24-08-2019, 09:50 AM | #26 | |||
Like this?
24-08-2019, 10:26 AM | #27 | ||
Rob
Maybe read again what I wrote...
24-08-2019, 10:47 AM | #28 | ||||
No, because 10% of the trailer's weight goes onto the tow vehicle's payload as towball down force. So a 3,000 Kg trailer has 300 kg tow ball downforce and its remaining weight is 2700 Kg, that gets added to the vehicle's 3,000 GVM. I get that you would not want to fully load these Utes with passengers, gear in the rear tub and a 3,000 Kg trailer. The whole Idea is to stay within those limits and if you want a bigger Ute, you have to pay more for a Land cruiser or Patrol. I would pull it up at a 2300 or 2500 Kg trailer as absolute max, it's more comfortable but if you had a supercab and a ffth wheel hitch, I bet you could do some pretty incredible stuff provided you stay on the black top or easy going dirt roads. My ultimate Ute would be an F150 with the Land Rover 4.4 V8 diesel (they don't make it of course) Last edited by jpd80; 24-08-2019 at 10:56 AM. |
24-08-2019, 11:08 AM | #29 | ||
Rob
I was saying if you go heavier than 2.5t then you need to do your homework re all the relevant specs. I didn't say it was asking for trouble.
24-08-2019, 12:31 PM | #30 | ||||
That's the point I've been trying to make...... Quote:
I agree with you....... |
