Shockworks
Old 18-12-2018, 08:21 PM   #1
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Default AU coolant tank.
Hi guys, as I understand the OEM coolant tank with sensor is now obsolete.
I have a few questions, I see you can get aftermarket Dayco branded ones with a sensor, has anyone experienced the quality of these products ?
And you can still buy the OEM ones without the sensor hole, but you need to terminate the plug, if doing so, will that make the dash warning light remain on ?
or is it just a case of leaving the plug there and there is no ill effect ?.
Old 18-12-2018, 09:10 PM   #2
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
Default Re: AU coolant tank.
If the sensor plug is unplugged (or not plugged correctly) the dash warning light will just keep flashing, to get rid of it the globe needs to be removed from cluster.
The aftermarket header tanks are fine, they just don't have Ford on them.
PridenJoy is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2018, 09:20 PM   #3
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Thanks mate, I am trying to clean my original one up but they just don't come up near enough to clean enough for my liking, sure they do improve but I am OCD and want it to be clean as.
Old 18-12-2018, 11:47 PM   #4
superroo
You can't stop the signal
superroo's Avatar
Or put a 180 ohmn resistor across the plug in the engine bay.
Old 19-12-2018, 12:19 AM   #5
BlueBear
Shockwave
BlueBear's Avatar
Bought an ebay one a few years ago, quality was fine.
Getting the old sensor out was the biggest issue I had, (I reused it) but yours may be OK
Makes a huge difference to the under bonnet appearance.
Cheers,
BlueBear is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2018, 08:40 AM   #6
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Cheers,
Thank's mate, do you remember what brand it was ?
And how does the old sensor come out and did it need sealing when placing into the new tank ?.
Old 19-12-2018, 10:57 AM   #7
BlueBear
Shockwave
BlueBear's Avatar
Sorry, don't remember the brand or seller.
The sensor is just a 1/2 turn and pull out, just mine wouldn't come out, ended up cutting the old tank up to get it out. I think the plastic must have deformed from the heat over the years.
The new one I got had a new rubber seal with it, so just fitted my old sensor straight up.
Worked fine, no leaks.
Have fun.
Old 19-12-2018, 02:25 PM   #8
PridenJoy
Dayco is a good brand. I had it in my ute.
https://fordforums.com.au/showpost.p...95&postcount=2
Just use an adjustable angle grinder key to undo the sensor.
Old 19-12-2018, 02:52 PM   #9
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Thanks mate, thats the brand I was looking at.
Old 19-12-2018, 04:15 PM   #10
Bill M
Bill M's Avatar
Dayco was an OE Ford Australia supplier of many parts.
AUII XR6 VCT ute
23 years and still going strong!
Old 19-12-2018, 05:13 PM   #11
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Has anyone ever looked at the OEM Ford one without the sensor as they are still available and then possibly adapting the sensor to it as the provision for it is there ?.
Old 19-12-2018, 06:35 PM   #12
FTE-063
FTE-063's Avatar
I have a spare one hanging in my garage wall as a spare it's a genuine ford one
with sensor all cleaned I was keeping it for my next car but since your looking for one
make me an offer and it's yours
And by the way Dayco are good as I've got one in the XR8 no drama's at all 2.5 years still going
FTE-063 is offline   Reply With Quote Multi-Quote with this Post
