Shockworks Ford damper specialist located in Melbourne's S.E suburbs. Website Link |
17-02-2014, 12:07 AM | #31 | ||
Anything further to report, some of us are dying of anticipation and now very tired factory suspension... ha hah ha..
Moved to Mt Isa with work and the whole family and now also with F6Concorde's Ghia Turbo in the family. Roads are certainly rougher and its finished off our first Territorys suspension. Keep up the hard work and quality, boys! |
17-02-2014, 01:53 AM | #32 | ||
Nice work mate, no work here in W.A only QLD and NZ
By the time you get back to W.A Shockworks might have some info for us .
2015 FGX XR8 5.0 S/C 645 RWKW |
17-02-2014, 09:31 AM | #33 | ||
Hey Cobramad,
Yep, development all done and first production run is being finished and then will be on our next shipment to Australia. We have pounded the Terri kit for a while now on some very crap roads with no issues with any of the components. Now we are doing some final designs for the 2WD, then we can support both models. I will post soon when stocks are available. Cheers Brett |
5 users like this post: |
30-03-2014, 04:35 PM | #34 | ||
Bumpity bump-stop bump! :-)
31-03-2014, 10:54 AM | #35 | ||
Hey Cobramad,
Yes haha I know, I know. Terri dampers are on the way from Korea and will be here in the next few weeks. We did have a delay with the rear spring but that has been resolved. If you are keen we have the development set of Terri dampers that have been rebuilt and as new again for $1200. You would have to use the factory rear spring until we get stock of the new design though. For the $1200 we can supply the front coilover with top mount and the inverted adjustable rear damper as well. We had the Terri dampers outback towing a caravan and all went very well. Sorry mate, we have been so busy developing the Ford brakes and other damper models but they are on the way and will post when we have the full kits in stock!! Cheers Brett |
09-05-2014, 10:15 AM | #36 | ||
Hey Guy's,
Finally after many months we have the Territory kits on the boat heading for Australia. They will arrive on the 14th and we will have stock on hand in the following week. Cheers Brett |
4 users like this post: |
05-06-2014, 05:22 PM | #37 | ||
Hi,
When they do come in can you post it on the Territory forum please. |
05-06-2014, 05:43 PM | #38 | |||
We have stocks of the full Terri kit available from next week. We have the kits now however, (this may sound a little strange) I want to confirm the rear spring in the new kits perform exactly the same and deliver the same heights as the prototype parts. We are doing this test in the next couple of days. I just want to be totally sure the production batch is the same as what we signed off on in regards to the rear spring. We have taken way to long getting this package ready for sale and for that we are sorry but we always test a lot before going to sale. Cheers Brett |
16-07-2014, 09:10 PM | #39 | ||
Posts: n/a
(My first time - be gentle) Shockworks have been using my Turbo Terri for development. I can confirm the research effort that has gone into refining the kit. Brett took my Turby went from OK-ish standard, to a total transformation of ride and handling. The car felt like it lost 50% of its weight, and became very light and nimble. The cornering is dead flat, it soaks up big and small bumps, AND its comfy. I'm talking BMW 5 series ride refinement. With the AWD and (upgraded) power, I have surprised RWD Porsche and Ferraris through twisty bits - true story! The dampers are perfect, but getting the mounts and springs right has taken time. Soon though, very soon. It is worth waiting for; do not be tempted by anything else.
09-08-2014, 10:00 AM | #40 | ||
I've waited so long now that there is simply no alternative..... just a bit longer.. lol
Just wondering if the dampers are rebuildable when worn? |
11-08-2014, 12:22 PM | #41 | ||
Posts: n/a
I'll ask Brett for certain, but I would say yes.
BTW Mine is in at the end of this week to get measured up for an adapter to allow for their GT front brake kit fitment. That'll be the final check for rear springs too, so.... |
11-08-2014, 01:00 PM | #42 | |||
We have the kits in stock for the Terri but I am not completely happy with the rear spring I developed as we can not lower the Terri as much as I wanted. I made some assumptions that were incorrect. All the rest of the kit is perfect but the rear spring sits the Terri at normal height. Now we have to wait for a shorter coil which we can supply to you later if you are keen for the kit. Cheers Brett |
11-08-2014, 01:10 PM | #43 | ||
Posts: n/a
...and are your dampers rebuild-able?
11-08-2014, 01:14 PM | #44 | ||
Our dampers are fully rebiuldable at the cost of $80 each. This includes all valving, seals, dividing piston, oil and anything else but that pretty much covers all the internals.
Also what we normally do is update the dampers with the latest level codes if we have made any improvements during that time. Cheers Brett |
11-08-2014, 01:14 PM | #45 | ||
Posts: n/a
And BTW, I said that I'd beaten a Porsche and a Ferrari around corners. True story, but ONLY in the wet. The RWD cars just could get their power down, so the Terri just walked away from them. Fun watching them trying to get traction - in the rearview mirror.
05-09-2014, 03:13 PM | #46 | ||
Just like to say a BIG thankyou to the Shockworks Team (brett & chris) for taking time out of their day to show & explain their AWESOME product!!!! Will defiently be buying their shocks in the near future for my TTG !!!!!!
06-04-2015, 06:09 PM | #47 | ||
Any further updates on the Territory developments???
06-04-2015, 06:18 PM | #48 | ||
Posts: n/a
Shockworks Territory dampers well and truly developed! Contact via their Facebook site might be best.
07-04-2015, 09:42 AM | #49 | |||
Cheers Brett |
09-04-2015, 05:39 PM | #50 | ||
Hey Brett
Emailed you the other week about these, just waiting for ford to finish with the DSC and check engine light fault prior to blue slipping.. I'll be placing order hopefully in the following week Cheers
Previous Fords TD Cortina 250 6cyl 4 speed (stolen) MK 2 Escort 2ltr Pinto 5 speed Celica box (written off) XE Falcon LPG Turbo 2k stall C4 Auto (Tboned) XF falcon Fairmont stocker (Expired) TF Cortina 250 6cyl (parted out) 2011 Manual GS 399rwkw (sold) 2011 AWD Titanium Seduce (sold) My Fords 1998 AU S1 V8 Fairmont Wagon Regency Red Daily Kenworth T604 36" bunk Full house C15 & 18 Gears 820hp @ 1700 2600ftlb @ 1450 |
23-04-2015, 06:30 PM | #51 | ||
Hi Brett, could you please tell how much for fitting of shocks?/when can I make a booking/fitting? Thanks again Shane
24-04-2015, 10:40 AM | #52 | ||
04-05-2015, 05:25 PM | #53 | ||
HUGE shout out to Brett & Chris (Shockworks) Just had their shocks fitted - product speaks for itself!!!!!!!!!!!!!!!!!!!!!!!!!! & thanks for putting up with a VERY FUSSY ***** (thanks Chris!!!!!!) Cant wait to get their Brakes!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!
04-05-2015, 06:20 PM | #54 | |||
Ta. |
04-05-2015, 06:34 PM | #55 | |||
04-05-2015, 06:57 PM | #56 | ||
26-09-2015, 02:36 PM | #58 | ||
Hi Brett, another thing you mentioned when you where fitting my shocks (TTG) you said that you guys where getting some updated rear spring for the territory? Is that happening??
29-03-2016, 08:12 AM | #59 | ||
Hey guys
Can these be wound up higher than factory height? Looking at some all terrain tyres and a trip to Frazer with a 200 series cruser to drag me through the tougher stuff?
30-03-2016, 10:46 AM | #60 | |||
I think we talked on the phone but yes the dampers will go higher then the factory height. We did not test how far the kit will raise the Terri but sure you can get an extra 20mm more then factory height. Let me know how you go:-) Cheers Brett |
