Old 29-12-2012, 11:48 PM   #1
AusJas
Default Parrot MKi9200 BA
Hi Guys,
My partner got me a Parrot MKi9200 for Christmas along with the ISO2car (86120) cable to suit my 03 BA XR, what she did not realise until I opened everything is that the ISO2car documentation had in small print that it will not suit some vehicles with amplified systems, and as my BA has premium sound it is amplified....
Before I even think about installing the Parrot, I thought it better to check with you guys if this ISO2car cable will work with the BA premium sound...or will I need a different ISO cable, or will it need to be direct wired in? Wy couldnt you guys have a shop up my way lol
Any assistance greatly appreciated....cheers
AusJas is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2012, 01:50 PM   #2
foxtrot3
foxtrot3's Avatar
Default Re: Parrot MKi9200 BA
Hi. The parrot hands free kit works well with the BA/BF falcons. The power earth and mute wires all connect to a four pin plug behind the fuse box. Use either the grey grey/black OR the white white/black speaker output wires to the 2 pin plug also behind the fuse box. For music streaming use the white (l) and red (r) line out wires to the aux in plug behind the fuse box. Red to orange, white to white and the black and brown wires join together and then connect to tha last 3 wires in the aux plug. you then turn OFF mute when streaming in the parrot and switch on aux in by pushing AM twice on the radio. Cheers MD
HI
I'M MICHAEL
foxtrot3 is online now   Reply With Quote Multi-Quote with this Post
Old 31-12-2012, 09:21 AM   #3
AusJas
Cheers Michael, so I am guessing that means the ISO plug is no good to use then.....?
Old 31-12-2012, 02:38 PM   #4
foxtrot3
foxtrot3's Avatar
Hi. Seeing there is no iso plug on the falcon there is not a lot of need for one but if it is a small adaptor harness it may be preferable to cut it up to make it fit the ford than the harness supplied with the parrot. Cheers MD
HI
I'M MICHAEL
Old 31-12-2012, 02:52 PM   #5
Mitch_
the iso2car harness should work and clip straight in to the plugs under the dash
Mitch_ is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2012, 05:08 PM   #6
AusJas
Thats what I thought also mitch, but it says not suitable for amplified systems, but is for the El through BF models with an 8+8 pin, so just wanted to chec k first...ASL install these I think
Old 31-12-2012, 05:45 PM   #7
foxtrot3
foxtrot3's Avatar
Hi. the BA/BF uses a plug mounted to the dash which the icc locks into. this plug is fixed in its location and the layout in nothing like an iso plug. See here for the BA/BF plug http://www.fordforums.com.au/vbporta...?articleid=571 .
See here for iso plug and socket http://www.google.com.au/imgres?star...37&tx=53&ty=70 .
See here for BA/BF phone plugs http://www.fordforums.com.au/vbporta...?articleid=566 .
iso2car cables are used between car radio and factory wiring to enable the connection of iso completable hands free kits. As yet no one does an iso2car for the BA/BF because it doesnt need one.
see here. http://www.strike.com.au/products/KRAM-Cables . Cheers MD
HI
I'M MICHAEL
Old 31-12-2012, 07:38 PM   #8
AusJas
Thanks Michael, that made it very clear lol...
the only confusion now is slight differences;
I have 2 line outs Right (blue+ and green-) and Left (white+ and brown-) to which I would say blue to orange and white to white, join green and brown together and then join them to the last 3 wires in the aux plug, is that correct....?
Old 31-12-2012, 09:26 PM   #9
foxtrot3
foxtrot3's Avatar
Hi. Trust parrot to change something, If they have changed that, then check first that you can still turn off mute when streaming in the parrot menu and if yes then go with what you said. I know that they changed the 9000 about 18 months ago and removed the disable mute when streaming function but it was going to continue on the 9100. If you cant turn off the mute then you wont need to hook up these wires but streaming will only be in mono. Cheers MD
HI
I'M MICHAEL
Old 02-01-2013, 08:22 AM   #10
FADI75
Sponsor
Hi Guys,
hi
we can supply you with the plug and play cables $75.00 plus $15.00 freight
please call 0397991444 to arrange a phone order
cheers
fadi75
AUTHORISED FORD REPAIR CENTRE
email: info@aslautomedia.com
Old 03-01-2013, 07:56 AM   #11
AusJas
Hi Fadi,
Very keen if it is to suit premier sound system and not the iso2car cable that I have already got?
Will give you a call today....
BA XR8 - BOSS 290, BIG Mouth CAI, RDA high flow system
2007 Territory Turbo Ghia
Old 04-01-2014, 01:52 AM   #12
michaelmichael
Do these plugs also refer to the territory?
michaelmichael is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2014, 09:11 PM   #13
foxtrot3
foxtrot3's Avatar
Hi. If it has the same ICC as a BA/BF falcon. Cheers MD
HI
I'M MICHAEL
Old 15-12-2016, 03:04 PM   #14
< R i C o >
08 Territory AWD Ghia
Originally Posted by FADI75 View Post
hi
cheers
fadi75
Hey Fadi,
Do you guys still have the BA/Territory plug and play cables at that price? Or is it cheaper for members?
< R i C o > is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2016, 08:44 AM   #15
FADI75
Sponsor
Originally Posted by < R i C o > View Post
Hey Fadi,
Hi
Please see link below, ASL is having a 15% off this month
http://www.aslautomedia.com.au/parro...iring-harness/
cheers
fadi75
Old 22-11-2017, 09:41 PM   #16
arnast
Is there a wiring diagram for what you have explained?
arnast is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2017, 09:47 PM   #17
< R i C o >
Cool Re: Parrot MKi9200 BA
I would honestly recommend not bothering and just get the adapter you're going to save yourself a major headache and it's worth shelling out the $75 just for that.
Buy yourself an early Christmas present 🎁
Old 22-11-2017, 09:51 PM   #18
< R i C o >
oh and they're at %15 off at the moment for Christmas too!
Old 23-11-2017, 08:53 AM   #19
arnast
No thanks..i'd rather spend a few hours wiring it up than spend $80 on something that probably cost's them $10 - $20 to make besides that i just don't have the money to buy one.
Old 23-11-2017, 10:22 AM   #20
FADI75
Sponsor
hi
Not a problem, good luck
fadi75
Old 23-11-2017, 11:20 AM   #21
arnast
All i need is a wiring diagram Michael explained the wiring here but i am trying to find out if someone has a wiring diagram for it.
Old 23-11-2017, 11:33 AM   #22
< R i C o >
You don't need the wiring diagram you need the pinout to know what the colours are.
Old 23-11-2017, 12:12 PM   #23
arnast
Attachment 97723
A wiring diagram makes it easier for me to follow what Michael wrote..
