Old 18-12-2006, 10:54 PM   #1
hydrulictelstar
Default clock not working on my 88 ford telstar tx5 ghia
hey how do i fix the clock on my tx5 all fuses are ok the clock still works cause i hooked it up on my 88 ke laser ghia what could be wrong with it oh and now the interior lights arent working when its switched on door i just have 2 problems and i cant work it out i have the wireing diagram from point A to point B and cause i dont understand how to read it i cant fix it and i just need a quick resolve
hydrulictelstar is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2006, 11:55 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
you start at the battery and if you have not got a coloured wiring diagrame use colouring in pencils to follow the wire to the clock etc
if the fuses and relays are ok etc
the earth symbol is sort of like an antenna
I think you may just have an earth problem so first thing to do is check all of them
then the relays make up a continuity light out of a trailer bulb and wire or other such device at hand
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2006, 06:32 AM   #3
hydrulictelstar
i rember now when i checked for power with a test light the memory wire for the clock wasent working
Old 19-12-2006, 07:55 AM   #4
hydrulictelstar
where do i find the rear dimister relay on the tx5
Old 19-12-2006, 01:13 PM   #5
dirty hands
Over Thinker
the rear demister on my book a model earlier is with the electric windows and door locks diagramme cant see a relay it may be in the switch itself
Old 19-12-2006, 06:45 PM   #6
hydrulictelstar
i will post the diagram for it
Old 19-12-2006, 06:51 PM   #7
hydrulictelstar
Old 19-12-2006, 07:06 PM   #8
dirty hands
Over Thinker
demister found it relay number 44 right hand corner top ish
just an on off switch thats why you dont leave them on long you switch it off after the window has cleared
just a thin copper wire using 12 volts and it has a fuse named circuit breaker
Old 19-12-2006, 07:50 PM   #9
hydrulictelstar
and u push a purple button on it
i tryed and pulled it apart this morning and still nothing
Old 19-12-2006, 07:55 PM   #10
hydrulictelstar
as far as i know when i did pull the dash apart and i hooked the clock back up it was working then a couple of days it stoped working i checked the acc with a tester and it was switching on and off i hooked the memory wire up and no power thats as far as i can rember wat i done
Old 19-12-2006, 10:28 PM   #11
dirty hands
Over Thinker
are we talking demister i think the wiring contacts may have a dry solder
joint
you can get a new demister fitted by an auto electrician
the clock you said worked fine in the other car no power can you follow the wire back to the relay i think you will find the relay needs replacing as it is a non repairable part
with that relay not working it stops the current to most of the right hand side components of the wiring diagamme
Old 19-12-2006, 10:41 PM   #12
hydrulictelstar
joint
i was thinking of going to the wreckers and get a car that has all engine fuses and the inside fuses and relays and just replace the whole lot and see what happens i geuss
Old 19-12-2006, 10:45 PM   #13
hydrulictelstar
and allso to i checked that my cigret lighter isent working either
Old 19-12-2006, 11:46 PM   #14
dirty hands
Over Thinker
finding an electrical fault is the most frustrating thing about cars
all you can do is focus on finding the power wire and the earth then check each device in turn
cig lighter is in that loop as well
you could buy a loom but you will need to check that it is all ok as well
luckily your car is still drivable :
Old 20-12-2006, 06:33 AM   #15
hydrulictelstar
i just hope i can fix this is it common for tx5 ghia to do this or not even thow it will pass for a blue slip without the clock and such but i would like everything to work on the car for further more **** ups in the futur
Old 20-12-2006, 07:32 AM   #16
dirty hands
Over Thinker
not a common problem found in a ghia about the same as an indicator flasher or fuse blowing under normal use
check that fusable link at 45 as well
you are looking for the relay with theses colour wires
black white stripe and a black yellow stripe one side
2 black blue stripe the other side
Old 11-01-2014, 12:54 AM   #17
toothless
toothless's Avatar
Default Re: clock not working on my 88 ford telstar tx5 ghia
my old user name when i joined aff
phat ltd in the making very lowly
toothless is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2014, 08:37 AM   #18
foxtrot3
foxtrot3's Avatar
Hi. Did you check the fuses under the bonnet as well as the ones inside? Clock and cig lighter share a fuse with the interior light and a fault in any one of these will stop each of the others. Same fuse also provides power to the radio/cass memory wire on some telstars and if the radio has been changed the fault may be behind the radio, Check the color of the memory feed wire and if there is a spare wire there which is the same color try connecting it to the memory wire ( this gets left off when people cut the plug off, from new there were 2 wires crimped into the same terminal). Cheers MD
HI
I'M MICHAEL
Old 11-01-2014, 11:40 AM   #19
toothless
toothless's Avatar
yes it was the one wire behind the radio that made the interior light and clock and cigerate lighter to work
from memory because i have not owned one for awhile it needed two power source from it
Old 15-01-2014, 08:52 PM   #20
dirty hands
Over Thinker
ok changed the names
tricky you been around nearly as long as me
your making up for it 1400 posts plus
good on you
