09-02-2009, 08:28 PM | #1 | ||
hey all . im starting to build a blow through turbo setup 2l for my escort and i am wondering what a good compression ratio is if i want to be running about 12psi boost, thanks for any input ,.
18-02-2009, 02:53 PM | #2 | ||
A blow through at 12 psi? I think your biggest problem will be what carby to use. Anyhow CR down to 7.5:1 should be OK for 12 psi.
PS Normally 4 psi is about the max for blow through carby system so I'd be interested to know what your plans are and what kit you are using. |
18-02-2009, 02:57 PM | #3 | |||
even with special floats. |
22-02-2009, 03:57 PM | #4 | ||
I once ran 8.1 with water inj and a 'Stromberg 175 CD' carb draw-through at 10 to 14psi worked well.
