Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Ford Coupe Club of Australia > Coupe Restoration & Build
Old 15-10-2011, 12:01 PM   #1
timothyds
timothyds's Avatar
Default Original tramp rod mounting
hi im after some photos of the original tramp rods mounted to a car. i picked up a set and i want to make sure i mount them as per factory. close ups of the mounting points would be super thanks.
timothyds is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2011, 01:06 PM   #2
pottery beige
Default Re: Original tramp rod mounting
these any good.. 9/73 tramps..
pottery beige is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2011, 10:31 AM   #3
timothyds
timothyds's Avatar
spot on thanks!
Old 17-10-2011, 03:47 AM   #4
pottery beige
cheers big ears..
Old 08-11-2011, 09:40 AM   #5
lilmattie
lilmattie's Avatar
Is there any difference in length between sedan and coupe?
Pretty sure there were two styles of tramp rod too.. an early and a late model.
Wanted Parts
  • Control knobs for XA/B dealer-fit full length under-dash aircon.
  • VGC XA/B dashpad in black
lilmattie is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2011, 02:42 PM   #6
gregaust
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Greg always goes out of his way to provide assistance and support to members of AFF. Greg freely shares his knowledge with people who ask for help and often assists them with obtaining parts and repairs.  A great member of the AFF community. Technical Contributor: For members who share their technical expertise. - Issue reason: Always happy to offer assistance from his own experiences and often posts up photos when someone is having issues finding/locating something they are trying to repair or replace.
You need to make a nice solid steel crush tube to weld in the chassis , i've done a couple using 1" solid bar, bore a hole through and then weld in the chassis
gregaust is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2011, 06:48 PM   #7
patrol_maverick
patrol_maverick's Avatar
What's a tramp rod for?
patrol_maverick is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2011, 08:42 PM   #8
coupecouple04
Which cars received tramp rods?
coupecouple04 is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2011, 07:06 PM   #9
timothyds
timothyds's Avatar
the XB coupe
Old 10-11-2011, 07:29 PM   #10
coupecouple04
Which other cars coped the tramps from factory?
Old 10-11-2011, 08:08 PM   #11
Stefan
Stefan's Avatar
GT's and 351 cars.
Stefan is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2011, 09:11 PM   #12
Landau Stable
Landau Tragic
Landau Stable's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For his many posts on welding and fabricating for coupes
To be more specific, XA and XB GT's, P5 LTD's and Landaus. XC cop cars got a single tramp rod. XA with drum brake is usually a straight rod, and XB era disc brakes have the bent rods. Sedan and coupe are the same. The LTD units are longer bent rods.
STOLEN Cosmic blue Landau. Engine and Vin no: JG70PU12931K. Please pm me if you have any info
Landau Stable is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2011, 10:20 PM   #13
MEANXBCOUPE
injection is nice, but...
MEANXBCOUPE's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing the Helicoil article
When i had my XB gt, it came with the factory rods. After it led a early demise at Oran park, we transfered everything into a XB falcon 500.
One job was to put the tramp rods in, i measured the GT and drilled in exactly the same spot on the '500... to my shock, there was a crush tube in the chassis aready.
This is the car i have now (the green one) and have since used the same hole and crush tube to mount the top control arm of the four link. also, the XE falcons i measured, they locate their top conrtrol arm in the same position!
Proud member of the Clevo Mafia
Limetime Green '74 XB Coupe- Classic not Plastic.
Blueprint '02 Pursuit 250- Plastic not Classic (yet)
Venom '01 AUII Rebel- RIP. Gone to a better place.
Winter White '12 FG GT 335 R-Spec - something the wife thrashes daily
'05 CRF450X- For getting dirty in the, um, dirt.
MEANXBCOUPE is offline   Reply With Quote Multi-Quote with this Post
