30-11-2018, 09:20 PM | #1 | ||
Hey all got my old 250 crossflow running. New fuel pump
, filter, leads, plugs, cap, new carby and set.the timing to factory specs at 4degress btdc. It has a big flat spot when u throttle to much. Backfires and blew my muffler to pieces. Any ideas on what the cause could be. Had a mechanic look at it and he was stumped. Pcv valve is missing. Redone all the hoses as per manual. All vacuum on egr advanced timing and what not hold vacuum. Can feel it when u suck on the hoses. Not sure what is a main cause for it. 1978 250 crossflow. Last edited by Topsy11; 30-11-2018 at 09:31 PM. |
30-11-2018, 11:09 PM | #2 | ||
SZ II TS Territory-Black
What sort of carby? The jets might be too big.
Kick it in the guts Barry! FWD is the Devils work |
30-11-2018, 11:17 PM | #3 | ||
Stromberge single barrel. Reco factory carby
30-11-2018, 11:36 PM | #4 | ||
Mate, I had a 78 XC Fairmont with 4.1 Litre, a long time ago. I could never get the Stromberg to work, I put a 350 Holley on it and it drove so much better. The only other thing I can think of is a vacuum leak.
30-11-2018, 11:56 PM | #5 | ||
Easy to fit a 350 holley ?
01-12-2018, 12:02 AM | #6 | ||
If your engine is backfiring and damaging the muffler, means that fuel has been accumulating in the exhaust system, so I would re check your ignition timing.
I suspect the distributor has been fitted with it being a tooth or 2 out of phase with the lead/spark plug. Peter |
01-12-2018, 12:42 AM | #7 | ||
My timing I got number 1 cylinder at tdc. Compression stroke. Marked the dizzy on the side. Rotor obviously points at number 1. Put the cap on and start number lead in order. Then when started advance the timing to 4degress btdc as written. Even if I move the timing up and down it still runs the same. Ickes well. Holds high revs well. Not backfiring as much if I punch it when the revs are up. As the timing advances at higher rpm so should I advance the timing more. Was at 14 btdc when I got it.
I dont understand what out of phase cap means. Does it mean they are not lined up to where the button should be when firing? |
01-12-2018, 04:05 AM | #8 | |||
Okay this is going to be difficult. I presume when you say the PCV is missing, that it has been blocked off or has been connect up to the crankcase, and not leaning out the fuel mixture? The PCV is there to prevent backfiring from igniting the gas/fumes inside the crankcase. You are going to need to check everything and not presume anything. It could still be a carburetor induced flat spot, but my gut feeling is it is timing. You will need to go back and put the no 1 cylinder on TDC after it's compression stroke. The correct way to do this involves removing the rocker cover. Then turn the engine over clockwise by hand until the valve rockers on the number 6 cylinder are on the rock. On the rock means that the exhaust valve rocker is just closing and the inlet valve rocker is just opening. Then check and make sure that the harmonic balancer timing mark is lined up with TDC. If the timing mark is within a couple of degrees, rotate the engine until the timing marks are lined up. It is now on Number 1 compression stroke at TDC. If your harmonic balancer timing marks are out by too much it will mean the harmonic balancer has slipped on it's rubber. For an engine this old it is a high probability.It is also where many a mechanic have come undone, they have presumed the timing marks where correct. Now go to your distributor and with the cap off, see if the rotor lines up with the number one spark plug lead. If the rotor lines up correctly, continue, if not get back to me with your results so far. Now disconnect the coil lead from the distributor cap and earth it to the engine block such that there is a small gap between the lead and the engine block, You will need to see it when it sparks. Back off the retaining bolt that holds down the clamp holding the distributor housing. You will need it loose enough to be able to rotate the distributor by hand. Turn the ignition key to the run position, don't crank the engine. Now rotate the distributor left and/or right, make sure you can make the coil lead spark. If you get a spark, rotate the distributor housing as far as you can in the direction of rotation of the rotor. Now rotate the distributor housing in the opposite direction to rotor rotation until there is a spark at the coil lead. Clamp down the distributor housing at the point where you get the spark. The rotor should be pointing to the number one spark plug lead position in the distributor cap. If not then something is wrong and may require the distributor to come out and be repositioned. Your engine should now be statically timed. Put the engine back together, fit timing light, start engine and reset timing to the desired 4 Degrees advance as specified. Get back to me with how you went. It maybe simpler in the above operation to remove all the spark plugs to make the engine easier to turn by hand, it's up to you. Don't turn the engine over by hand with the ignition switch in the on position, it may start, and it may result in blood loss. The engine may have been at the 14 degrees BTDC, because the previous owner could not time the engine correctly. Peter |
01-12-2018, 08:44 AM | #9 | |||
01-12-2018, 12:10 PM | #10 | ||
Make sure you float level is not too low, that used to be the prime cause for a lot of flat spots in early stromberg Falcons...also check accelerator pump functions properly.
01-12-2018, 05:49 PM | #11 | ||
Thanks Pete,
Bit more involved in checking my number 1 lead is actually pointing at number on the rotor than I thought. Your instructions make perfect sense. After I find true top dead center the rotor should be pointing at the number 1 lead. As i did check through the spark plug hole and had it at top dead center and used.the plug that the rotor was pointing at as number 1. So no matter what after finding tdc the rotor will always point at number 1 lead.if it's not the harmonic balancer may have moved and not be in the correct position and checking with it sparking the way you suggest is truly the perfect way. I will do just this. To make sure it fires at the right time as well and get back to you. As for the carby it puts a big squirt of fuel down its throat when I push the throttle. The.only part electrically I have not changed is the coil. Pcv is on it's way which I will connect as well but the hose is just sitting in the crank case hole for.the minute.i will get onto this as soon as I have time in the next day or 3 |
01-12-2018, 07:34 PM | #13 | ||
Topsy, because the engine runs perfectly except for the back fire when you try to accelerate hard,I,m pretty certain that you don,t have an initial timing problem. If the dizzy advance is working either your coil, plugs or leads are faulty.As you say you have a healthy squirt of fuel from the throttle pump so that eliminates that problem.
02-12-2018, 08:32 AM | #14 | ||
Back to basics
Is the vacuum advance working? And are you getting vacuum to the advance? You say your plug leads are new? But just check the resistance (should be between 4,000 - 6,000 ohms per foot (30cm) Silly question but when you threw the plugs in did you check the gap? Or use the factory set Gap? From memory I think they are fairly close at about 0.8 but you’ll need to check as the last time I worked on a cross flow six the year started with 199 Also check your point gap I won’t even Hazard a guess on that as I used to do them by eye
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
02-12-2018, 11:17 AM | #15 | |||
8 cyl .016" 6 cyl .018" Not always dead nut perfect, but more often than not was and never failed. |
02-12-2018, 11:24 AM | #16 | ||
A 351 will solve all your problems!
3 users like this post: |
02-12-2018, 12:19 PM | #17 | ||
02-12-2018, 12:42 PM | #18 | |||
Sent from my SM-G935F using Tapatalk |
02-12-2018, 12:45 PM | #19 | ||
02-12-2018, 12:52 PM | #20 | |||
02-12-2018, 01:02 PM | #21 | |||
02-12-2018, 02:34 PM | #22 | ||
So after all that retiming. It's the same. So I'm guessing not timing after all. When I reply the vacuum advance on the dissy after setting timing the idle goes up and so does the timing to around 10 btdc. Besides that I'm guessing I may just put an electric dissy in and go from there.
02-12-2018, 02:43 PM | #23 | ||
https://www.youtube.com/watch?v=V1fN...&feature=share
https://www.youtube.com/watch?v=3smv...&feature=share Here is some vids. Of the timing and the flat spot. I dont throttle.to hard or it goes bang or dies on its butt Sent from my SM-G935F using Tapatalk |
02-12-2018, 02:48 PM | #24 | ||
However after I timed this to 0 then started it was running I initially at maybe 6 degrees atdc was running like crap until I advanced it. Is that nornal
02-12-2018, 05:57 PM | #25 | ||
Sounds fair, like I said I always eyeballed them
02-12-2018, 06:21 PM | #26 | |||
The very least amout of advance should be what is stated in the manual. Those settings were very conservative and matched with the low cr and retarded valve timing of the day made for lethargic engines. I am assuming you have a stock camshaft. I know a lot of things are being presented. List them and try 1 thing at a time and cross things off the list. Pretty much everything that has been listed are possibilities. I have my own order of things to try, but I want to avoid the "too many cooks in the kitchen" scenario. After you have gone through the list of tests here and if the problem persists, then I'll add my 2 cents if there is anything still to test. Hang in there. Make sure Peter has a chance to review your results vs tests. |
02-12-2018, 06:29 PM | #27 | |||
02-12-2018, 07:01 PM | #28 | |||
02-12-2018, 07:05 PM | #29 | ||
All you need to know is it holds vacuum and that it moves the points contact mechanism when vacuum is applied.
02-12-2018, 07:07 PM | #30 | ||
