Old 01-11-2018, 04:01 PM   #31
ghezzi
ghezzi's Avatar
Default Re: Race Brakes Sydney are here to help.
Yeah, my BA suffered terribly with (stock) brake fade coming down a mountain with 2 harleys on the back. Low gears all the way and pray hard. Bendix pads and cooling ducts fixed the fade but rotor consumption could be measured weekly.
FG with ABS has been fantastic on the stock pads and rotors, it's why I'm hesitant to change to DBA/Bendix etc.
Just been across the Simpson in my brother's PK Ranger with big wheels/tyres, slipping clutch and no brakes, the FG's pedal feels brilliant by comparison.
Might be cheaper to leave mine alone and drive the Ranger once a month.
Now with half a million km's +
ghezzi is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2018, 06:04 PM   #32
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Originally Posted by ghezzi View Post
Hope you have a good holiday, just had 3 weeks of myself.
Chasing a firm pedal with short travel on my 2012 FGII ute. Tradie EcoLPi tonner.
Stock steel 16" wheels, bilsteins and braided brake lines. At 270k due for my last machine of the original discs and a new set of stock pads.
Previous BA ute would consume a set of (front) DBA discs and 2 sets of Bendix Metal King pads every 50-60K, and I don't drive the FG any different. Don't know if there was a technical problem with the BA, but I'm keen to keep the stock disc/pad on the FG.
My problem is I hate the long spongy pedal of Aussie made cars, I want the feel of my Brembo equipped motorcycles. Short and firm, but with great feel. So would that require some change in the master cylinder piston size, the brake booster, or the pedal box?
The problem is we can't compare your bike brakes a to your car brakes as they are so different. If you go bigger in bore size on the master cylinder for a firmer pedal you will need more pedal force to pull you up plus $$$$$$$.
You can try different brake pads and fluid but i am sure it wont ever get as good in firmness as your bike sorry.
MATTHEW PEARCE
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 30-08-2019, 02:27 PM   #33
KRISL
KRISL's Avatar
Hi all.
Im looking at replacement opinions for rotors on my fg gtp.
I would like two piece all round with nice looking slotts as the car is headed to be street/show/ family car,
But it seems off the shelf, its looking like
Front end, dba t3 5000 series (2 piece)
Rear end, to have matching t3 slots is the
dba t3 4000 series (1 piece only avaliable)
Any input in this big steep would be helpfull
Its a must to keep existing brembo 6 and 4 pot setup
Current 2009 FG GTP
Sold
2003 boss 260 xr8 daily driver
1991 eb1 xr8 once a year driver, factory cassette player
KRISL is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2019, 06:42 PM   #34
data_mine
GT-P With An Ego
data_mine's Avatar
can't have two piece rears because of the hand brake is a drum style.
the DBA 5000/4000 is what I run on my GT-P. with some good pads, is a great upgrade from the factory setup.
let Matt help you choose pads, the right pad for you will depend on your usage.
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw.
2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw.
2008 SY F6X in Silhouette, stock for now nope.
Ford Performance Club of ACT
data_mine is online now   Reply With Quote Multi-Quote with this Post
Old 31-08-2019, 07:39 AM   #35
Sturmer
Hi Matt,
I drive a BF MKII Ute with 16" steelies, it's an XL and to my dismay has NO ABS!!! (in this day and age... I didn't even think to check!)
Anyway, I can see that if I upgrade to the 328mm disc I'll need new rims and I'm on a budget.
I'm in my 50's and I drive like a grandpa now, but I was disappointed when I fitted speed sleeders to the ute and did three crash stops and found the brakes starting to fade already. The stock brakes are pathetic...
My question is, is it worth it (will I notice the difference) fitting stock sized slotted rotors and better pads, or am I better off sourcing a set of 17" or 18" rims and fitting the 328mm slotted rotors?
AND
Did the G6 have the bigger rotors, as I'm looking at a set of rims off a wrecked vehicle?
thanks for your time.
Sturmer is online now   Reply With Quote Multi-Quote with this Post
Old 31-08-2019, 07:41 AM   #36
Sturmer
HI Matt,
I'm in my 50's and I drive like a grandpa now, but I was disappointed when I fitted speed bleeders to the ute and did three crash stops and found the brakes starting to fade already. The stock brakes are pathetic...
and
did the G6 have ther bigger rotors, or was it only the G6T that had them?
Old 31-08-2019, 09:05 AM   #37
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Originally Posted by Sturmer View Post
Hi Matt,
AND
The front upgrade is 322mm and takes the same pad as the 298mm kit but with the larger rotor and a good set of pad is a better option. All Turbo and V8 Fords in BF and FG have the 322mm set up. You could also try the DBA T2 rotors and the dba XP all round as we have found that a good improvement on the RTV cars.
Originally Posted by KRISL
Hi all.
We could custom make two piece rear rotors for you but the cost may put you off as if you were going to do it you would also go bigger rears. If there was interest we would do it.
MATTHEW PEARCE
Phone 02 9609 1101
Old 31-08-2019, 09:20 AM   #38
Sturmer
thanks for the reply. I'm going to leave the rear rotors stock and I was after stock sized, better (read adequate) performing rotors and pads so they fit my stock wheels...
Old 02-09-2019, 09:38 AM   #39
FLOORED
Race Brakes Sydney
FLOORED's Avatar
BF MK11XL rear rotors are 303mm solid.
You can get the top of the line DBA T3 slotted rotors and there DBA SP street brake pads for about $470 delivered Australia wide.
MATTHEW PEARCE
Phone 02 9609 1101
Old 03-09-2019, 05:03 PM   #40
KRISL
KRISL's Avatar
Email sent to race brakes. In regards to rear two piece. Waiting for reply. Rodger, Over
Current 2009 FG GTP
Sold
Old 03-09-2019, 06:19 PM   #41
FLOORED
Race Brakes Sydney
FLOORED's Avatar
haven't seen it
MATTHEW PEARCE
Phone 02 9609 1101
Old 03-09-2019, 06:26 PM   #42
KRISL
KRISL's Avatar
haven't seen it
sales@racebrakessydney.com.au ??
Current 2009 FG GTP
Sold
Old 10-09-2019, 11:13 AM   #43
Biggav
On the search for cubes..
Biggav's Avatar
Morning, afternoon or evening...
Just wondering if you sell the E series brake upgrade kits still and what would be the cost on these please and thank you?
FG G6ET - Daily Driveway Ornament...
Current Projects
ED SOHC 3v 5.4 Cammed 5.4 3V Garage Ornament Project
Project Brimstone XE Wagon Phase 6 powered by Coyote
Long Gone Projects
EA Falcon SOHC 4.0 237rwhp
BA 3V 'The Taxi' DJR320 Kit, G6ET Wheels, Lunati Voodoo Cams 320rwhp
Biggav is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2019, 12:08 PM   #44
FLOORED
Race Brakes Sydney
FLOORED's Avatar
$2450 for the front kit complete with exchange uprights. Twin piston 330m slotted kit
MATTHEW PEARCE
Phone 02 9609 1101
Old 16-10-2019, 09:11 AM   #45
Mechan1k
Mechan1k's Avatar
Hi Matt.
Just wanted to get pricing and availability on FG rear 303mm solid rotors and pads.
Not sure if I could be bothered with slotted though on them ... and the factory items actually managed to make it to 220,000km with no issues.
And if you have them anything in stock to pick as as soon as i can .... please.
As a side note.
Had no notification it was going to do this until it started grinding on the way to work this morning
As I mentioned though .... 220,000km from OE is pretty decent in my book.
(my fault though .... has been a while since i checked them)
Thanks in advance
Old 16-10-2019, 09:18 AM   #46
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Originally Posted by Mechan1k View Post
Hi Matt.
As a side note.
Thanks in advance
Bugger and i can have plain rotors here today if you want them. Just ring me 02 96091101
MATTHEW PEARCE
Phone 02 9609 1101
Old 16-10-2019, 09:23 AM   #47
Mechan1k
Mechan1k's Avatar
Thanks Matt .... I'll call you soon
Old 31-10-2019, 01:57 PM   #48
jring16
jring16's Avatar
Hi Matt, how much for braided brake lines and new pads all round for a 4/pdr brembo set up on a FG GS sedan
jring16 is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2019, 03:27 PM   #49
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Is that a Brembo/PBR set up ? $288 delivered thanks
MATTHEW PEARCE
Phone 02 9609 1101
Old 31-10-2019, 05:06 PM   #50
jring16
jring16's Avatar
yer my bad mate. That price was with the pads all round as well?
Old 31-10-2019, 05:30 PM   #51
FLOORED
Race Brakes Sydney
FLOORED's Avatar
No but now me bad lol.
Brake pads would be an extra $260 to $360 depends on brand but the cheaper option quoted is the DBA SP STREET Pads and the dearer is the new Project Mu NS-EP brake pads.
MATTHEW PEARCE
Phone 02 9609 1101
Old 31-10-2019, 06:57 PM   #52
jring16
jring16's Avatar
Bugger, thought it was a bit to good to be true
I'll go with the DBA pads and brake lines, I'll send you a PM
Old 22-11-2019, 05:47 PM   #53
EV1LXR
EV1LXR's Avatar
hi i need a price for brake pads for 4pot brembo fronts and standard back for bf f6 typhoon
BF XR6 N/A MODS: PACEMAKERS 4490's, 100CELL HIGH FLOW CAT, CAT BACK EXHAUST, Herrod CAI
BF F6 Typhoon: Fully opt. Standard except for filter and turbo line
EV1LXR is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2019, 09:17 AM   #54
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Prices range from $120 to $220 each set but most popular are the Project Mu pads still and would cost about $350 for both sets. These are less dust as well.
MATTHEW PEARCE
Phone 02 9609 1101
Old 17-12-2019, 11:40 AM   #55
DartAUxr8
DartAUxr8's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Excellent article on AU IRS rebuild.
Hi Matt,
hoping that you may be able to help me with some information on some rotors that i have in my shed.
they are the same with the exception of the rotor thickness part numbers as below with the only difference being the AA and AB.
i believe the AA are AU falcon but not sure on the AB set being thinner.
brake rotor part # 84222C026 AA
brake rotor part # 84222C026 AB
Cheers Shane
AU XR8 series II
N/A 6 speed manual
426HP 730Nm
1/4 mile: 12.44 sec @ 110.42 MPH
Build thread
http://www.fordforums.com.au/showthread.php?t=11410574
DartAUxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2019, 05:32 PM   #56
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Originally Posted by DartAUxr8 View Post
Hi Matt,
Cheers Shane
I will check with a mate in Ford but some measurements might help me find them thanks.
MATTHEW PEARCE
Phone 02 9609 1101
Old 17-12-2019, 06:29 PM   #57
05_ENFORCER
05_ENFORCER's Avatar
Hi Matt, I am in need of 2 x DBA 42108S discs and a set of ceramic low/no dust pads for the rear of my Territory (Modified 6/4 Brembos).
Can you PM me a price please mate?
Wangara. W.A 6065
2015 FGX XR8 5.0 S/C 645 RWKW
05_ENFORCER is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2019, 05:40 PM   #58
DartAUxr8
DartAUxr8's Avatar
Thanks Matt.
i forgot to mention that they are rear rotors both with elliptical grooves and the thin one is only 10mm thick.
AU XR8 series II
N/A 6 speed manual
426HP 730Nm
Build thread
Old 18-12-2019, 06:28 PM   #59
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Thanks Matt.
Could be
AU REAR Series 1 DBA501 287MM X 10.5MM
Eliptical slot disc sounds like could be rear BA which is 303mm x 16mm DBA505
MATTHEW PEARCE
Phone 02 9609 1101
Old 31-05-2021, 10:13 PM   #60
So what's Race Brakes view on the issue discussed in this thread https://fordforums.com.au/showthread.php?t=11489913 ? i.e. should brake caliper and slide pin bolts be reused?
