Old 13-02-2005, 04:28 PM   #1
DavO
DavO's Avatar
Default 2.0Lt Motor
I recently got myself a 2.0lt pinto for my escort how ever it has a cortina sump on it (can i use that or do i need to source a escort 1?) and my other problem came when i went to take the head off, there are a weird type of bolt holding the head on, does any1 know what type of socket/thing i need to undo the bolts and what size it is?
Thx David
DavO is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2005, 04:44 PM   #2
THORNSPAWN
In the Forced 'lane
THORNSPAWN's Avatar
The head bolts are 10mm spline bits about $10 a set at supercheap
The sumps should be the same
XE S-Pack
4 Runner
XH11 Longreach
THORNSPAWN is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2005, 08:02 PM   #3
champsky
THCC Motorsport member 1
champsky's Avatar
yeah should be a straight fit if ya talking about a MKII eski
did that to my last escort put a TE 2L innit and she went like a rocket aye :P
might have to source another one if i cant fix my current pinto :P
Southcyde Designs<------click here :
Member of the MTAS
Founder of TTM (team twink motorsport)
Founder of the AFFDDPS (Australian Ford Forums Drink Driving Punishment Squad)
champsky is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2005, 09:32 PM   #4
DavO
DavO's Avatar
soz for keep asking questions but i got some more
a guy at my dads work said that the 1600 trans tunnel isn't bigh enough to fit the 2ltr bellhousing for the gearbox and that u need to source a RS2000 bellhousing and even that needs to be trimed a little to fit. Is that true??
its a mk2 1600 and i really want to know exactly what i need to change to be able to bolt up the 2ltr after its been rebuilt.
thx david
Old 16-02-2005, 07:50 PM   #5
rag top
rag top's Avatar
Manual trans tunnel is the same size - 2.0, 1.6, 1.3. The auto trans tunnel is bigger than the manual trans tunnel.
Current Rides:
2000 AU 5L XLS ute; 1970 Mustang project
Old 17-02-2005, 08:03 PM   #6
DavO
DavO's Avatar
how hard is it to make about 110-120hp @ wheels from the 2lt?
ATM
I'm balancing crank
new pistons, rings etc
new cam, rocker arms etc
(what size cam would suit my wanted power for street use?)
Is a port and polish needed to make that power?
how big of a port job would be needed?
What type of carb would be recomended?
thx David
Old 19-02-2005, 02:47 PM   #7
rag top
rag top's Avatar
Get yourself a copy of the David Vizard book on modifying the 2ltr. It will answer all your questions, and give you a few extra ideas...
Current Rides:
Old 19-02-2005, 04:40 PM   #8
The MaDDeSTMaN
No longer driving a Ford.
The MaDDeSTMaN's Avatar
Yup, I'll second that, you might also find these threads interesting: http://www.fordforums.com.au/showthread.php?t=683
http://www.fordforums.com.au/showthread.php?t=658
Good luck, and keep us informed on how it's progressing, ok?
Originally Posted by russellw
For those who get their jollies attacking other people let me remind you that we will not tolerate this here. If you want to do that then I am sure your presence would be welcomed elsewhere.
The MaDDeSTMaN is offline   Reply With Quote Multi-Quote with this Post
