Old 03-11-2019, 08:14 PM   #1
stefcio007
Unhappy Rain Tray Leaking
Hi everyone,
I just noticed today that my rain tray is leaking directly over the rear of the engine.
Doesn’t seem normal, has anyone else had this happen?
What should I do? I already had it leaking before from the clip end directly over the battery and put some silicone over the clip on the outside that stopped it leaking through.
Is it a design flaw? Or is my rain tray stuffed?
2006 Territory SY Ghia (AWD)
Old 04-11-2019, 08:05 AM   #2
russellw
russellw's Avatar
Default Re: Rain Tray Leaking
I'd be surprised it it's stuffed but check that the actual drains aren't blocked as if water can't get out of the tray then it will overflow.
Old 04-11-2019, 08:01 PM   #3
stefcio007
The drains are clean.
Turns out the rain tray is split into two parts with some kind of sponge in between both that gets compressed when it’s bolted down.
Seems really bizarre. It only gets through if the water falls in the lower part of the tray, which would happen if water comes down from the windscreen.
Is there supposed to be a seal between the windscreen and the tray? I’ve just got a gap which is where I think the water is coming from.
Old 05-11-2019, 08:23 AM   #4
russellw
russellw's Avatar
By the look of the parts manual, yes there should be a seal between the windscreen and tray.
Old 05-11-2019, 12:00 PM   #5
stefcio007
Something like this will do?
Unless the OEM part is cheap?
https://ae01.alicdn.com/kf/Hf5e6b4f7...pg_640x640.jpg
Old 12-12-2019, 09:15 PM   #6
stefcio007
I ended up figuring out there is a channel that the rain tray sits in. Albeit I have a small gap in the centre because I can't get my hand further enough under the rain tray to get it to sit snugly. I'm going to fill the small gap with some black silicone and call it a day.
Old 31-07-2020, 07:01 PM   #7
stefcio007
Had a through look at the rain tray and surrounds today and took it all apart.
Turns out it's intentional, by design, for the water to drain in to the engine bay as there is a piece on the lower part of the rain tray that has holes there to let water through, seems odd but it's how it is.
